S&W 38 Special
by BlueOvalFitter - 02/23/20 07:23 PM
Oil Life Monitor question
by Mark72 - 02/23/20 07:06 PM
Any member a tax accountant ?
by mjk - 02/23/20 07:00 PM
Driven oil delivered after 6 months
by luna - 02/23/20 06:48 PM
M1 209 VS M1 209A
by BlueOvalFitter - 02/23/20 06:19 PM
Sig P516 - my take
by stockrex - 02/23/20 05:45 PM
Advise for Euro E36 M50 engine
by Lucase483 - 02/23/20 05:43 PM
Those with 5.3's weigh in
by Speak2Mountain - 02/23/20 04:26 PM
wix 2019 sienna oil filter cartridge fitment
by s2krunner - 02/23/20 02:19 PM
Urban Carry G3
by Gebo - 02/23/20 02:16 PM
Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
MTD Snowblower issues
by 97prizm - 02/23/20 01:19 PM
OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
wjamyers, L00btech, Lucase483, Chaucha, UofA
70790 Registered Users
121 registered members (2K2AcuraTL, 2015_PSD, 53' Stude, 97prizm, 55hambone, 4WD, 8 invisible), 2,558 guests, and 22 spiders.
Topics301,845
Posts5,203,836
Members70,788
Page 2 of 3 1 2 3
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: tdpark] #5252788 10/29/19 06:54 AM
G
Gebo Offline
G
Originally Posted by tdpark
flashing D is usually 3rd and 4th pressure switches going bad. Easy and cheap fix as they are right next to driver side tire. Get the codes read if you can otherwise you are shooting in the dark.
Several have mentioned this potential fix. I'd do this. Should take care of the flashing "D".
Next I'd dump the current mix in the transmission and be doing a bunch of drain and fills with Honda DW-1. I wouldn't use any more additives or non-OEM fluids in the transmission.
The correct fresh ATF may fix the shudder.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5252804 10/29/19 07:13 AM
M
mk378 Offline
M
Flashing D light means that the computer has stored a code, which you should investigate before buying any more stuff.
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5252805 10/29/19 07:15 AM
B
BAJA_05 Offline
B
Agreed with dumping all in the tranny now & going with Honda DW-1 paired with Lube Guard Red. Of course, posters mentioned about fixing the sensors also. My Acura has strictly Honda DW-1 & Lube Guard Red, likes/luvs that combo.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPPP 0W20 & FU (114K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5253825 10/30/19 05:18 AM
discountdon Offline OP
So I got a response from the manufacturer for my question:
"Due to heat you will loose the lighter ends of Sea Foam and some volume but the cleaning oil that will dissolve and prevent varnish formation as the fluid ages will remain in the fluid many miles"
I personally think Seafoam's line of products are overpriced, they are always 2x to 2.5x more expensive than Berryman's B-12 Chemtool. They both probably have less than $0.35 worth of raw materials inside their little cans. Their marketing in the additive industry to maintain such high prices and volume is nothing short of impressive, worth to teach in business school assimilate
Valvoline Import ATF +SEAFOAM TRANSTUNE | 5W-20 +AUTO RX PLUS
sailing 3rd party additives are the elixir to driveline immortality
planned obsolescence WWFis traitorous to the world
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5254473 10/30/19 07:16 PM
H
HangFire Online Content
Online Content
H
OK, so why do you go on and on about an additive (first positive and now negative) and refuse to address the probable mechanical issue that has been pointed out to you by 3 forum members?
This seems to be a common thing with new low-post forum members.
Various musings: http://hangfire.net
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: HangFire] #5301248 12/21/19 11:53 PM
Originally Posted by HangFire
discountdon,
Your transmission shows the classic symptoms of the 4/5 and 4/5 shift sensors going bad, a common and inexpensive repair, I did mine (at 100K miles) for less than $100, and the Blinking D, shift flares and clunking into Reverse went away for another 100K miles. The transmission was toast 214K miles.
Replacing the sensors is about as hard as an easy spark plug replacement.
I know... those sensors and solenoids are cheap and externally mounted too! I'll get them replaced before this spring.
Also I've ordered the external inline filter from WIX:
https://www.wixfilters.com/Lookup/PartDetails.aspx?Part=1871906
The filter just takes a 24mm open ended wrench and two 10mm bolts to undo, after taking the air intake hose, battery tray, and maybe also the plastic engine cover off to access it...
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: HangFire] #5301249 12/21/19 11:54 PM
Maybe because the OP is broke??? blush
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5301257 12/22/19 12:19 AM
[Linked Image]
[Linked Image]
Left sample was collected from a drain & fill after around 350 miles after the 16 oz of Sea Foam Trans Tune was added, it's dark and opaque and has the strong smell of isopropanol!
Right sample was collected from another drain & fill after around 375 miles to slowly remove all the SF TT. Less isopropanol smell to it.
After each subsequent drain & fill, the magnetic drain plug was cleaner and cleaner...
I will do two more drain & fills spaced out. I haven't been driving the vehicle much... No flare ups nor shudder to report, but I've experienced only one single hard 1-2 shift during this entire interval.
Sea Foam Trans Tune is doing its thing, its safe duh, no leaks... its updated 09/11/2019 SDS:
hyrdocarbon blend < 95% (most likely pale oil & naptha blend)
isopropanol 67-63-0 < 25%
I'm thinking K&W Trans-X is similar, but with stop leak chemicals...
I was also looking at K&W Trans-X SDS out of curiosity:
64742-52-5 distillates (petroleum), hydrotreated heavy naphthenic 76.2543%
67-63-0 isopropyl alcohol 10 - 20%
1330-20-7 xylene 5 - 10%
108-88-3 toluene 3 - 5%
123-42-24-hydroxy-4-methylpentan-2-one (diacetone alcohol) 1 - 3%
100-41-4 ethylbenzene 1 - 3%
banana
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5301270 12/22/19 01:05 AM
L
LeakySeals Offline
L
All seafoam products are chemically the same. Just different labels and marketing. The transmission got a drink of pale oil, naphtha, and isopropanol. I would dump that ASAP. Isopropanol does not belong in the transmission.
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: LeakySeals] #5301281 12/22/19 02:20 AM
absolutely, I'm planning to do at least two more drain & fills and maybe a third one for good measure spaced out...
anyways the pictures posted doesn't tell the whole story from both a lighting standpoint and also the old fluid had been sitting/settling contaminants.
the first drain & fill after initial treatment was definitely much more dirtier than the pictures show... as expected and going to plan smirk
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5301489 12/22/19 10:01 AM
W
Wolfshead Offline
W
Hi ,I have never used Seafoam. Questions are How much Seafoam to add to a sometimes "groaning " p/s on a non leaking '03 Dodge Caravan ? How about a 1960's Mopar 727 that "sometimes" has a harsh 2nd. to 3rd. shift ? (about 9 qts. capacity) any thoughts ? Thanks and Happy Holidays Everyone !
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5301494 12/22/19 10:07 AM
dogememe Offline
For all the time and money you've spent on additives and ATF you could have fixed the real problem.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: Wolfshead] #5301496 12/22/19 10:08 AM
dogememe Offline
None. Seafoam does not belong in anything. Let it stay on the shelf at the parts store where it can hang out with its friends Lucas and Slick(50).
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5301641 12/22/19 01:44 PM
Honda/Acura models equipped with a four- or five-speed automatic transmission may overheat the converter. Insufficient flow to the TCC release circuit at low RPM allows the lockup piston to drag on the cover, generating heat. This heat glazes the TCC lining and overheats the fluid. Eventually the slip rate cannot be controlled due to lining failure, resulting in code P0740. To prevent this problem, Sonnax offers a drop-in converter charge regulated pressure regulator valve 98892-04K. This valve allows more flow to the converter and cooler circuits, increasing converter charge during low pump output conditions, and includes an internal checkball to prevent converter drain back when the vehicle is off. The same valve design will assist converter charge and TCC apply pressure during low-output/high-load demand situations.
Beyond the Pressure Regulator: Keeping Cool While Investigating Mystery Honda Overheat
https://www.sonnax.com/tech_resourc...ile-investigating-mystery-honda-overheat
Overheated Honda Converters/740 Codes
https://www.sonnax.com/tech_resources/7-overheated-honda-converters-740-codes\
8-page Transmission Report: Overheating Honda Converters, Vacuum Testing and More
https://www.sonnax.com/tech_resourc...honda-converters-vacuum-testing-and-more
Honda 740 Codes: Torque Converter Forensics
https://www.sonnax.com/tech_resources/24-honda-740-codes-torque-converter-forensics
https://www.piloteers.org/threads/flashing-shift-indicator.18363/page-14
https://www.odyclub.com/threads/honda-transmission-problem-root-cause-and-a-fix.52345/
shocked2
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: mk378] #5301872 12/22/19 06:55 PM
I dont have an OBD-ii scanner I'll try one of the big box auto parts stores to see if
I dont have an OBD-ii scanner but, I'll try one of the big box auto parts stores to see if they can pull a transmission module code, I know higher end scanners can do that...
Page 2 of 3 1 2 3
