Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
19 registered members (3311, Compagnion, blufeb95, bbhero, BlakeB, Cdn17Sport6MT, 2 invisible), 902 guests, and 16 spiders.
Topics301,684
Posts5,200,467
Members70,756
Page 1 of 3 1 2 3
SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission #5252440 10/28/19 07:08 PM
discountdon Offline OP
I have 180,000+ miles on a Honda BVGA 5-speed Automatic Transmission behind the 3.5L SOHC V6, unknown service if any, has some shudder, some flares, the flashing 'D' light on the gear indicator, some clunking into reverse sometimes. Originally added a bottle of Lubegard Red, it eliminated pretty much all the shudder and flares. So I did a drain & refill 2x with Valvoline MaxLife Full Synthetic ATF. Obviously the original factory ZF-1 fill was blackened and very dirty to say the least. The transmission either didn't really like the thinner viscosity ML or maybe I disturbed alotta clutch material debris, and the flashing 'D' came on more frequently. A third or 3x drain & refill was done with Valvoline Import Full Synthetic ATF, much higher viscosity and the tranny liked it much better, the flashing 'D' only came on twice. All 3x drain & refills where done within 500 miles.
Auto-RX Plus was ordered, mainly for this. After some research and thought I decided to go SEAFOAM TRANS TUNE before starting the RX. So this morning I drained about 16 oz of existing ATF and added 16 oz of Seafoam TT. 50 miles in today, I can feel a slight improvement, as in smoother shifting. I reason I went this route because Seafoam TT has been around much longer, purports to be safe, and other anonymous users on the interwebs testify it's effectiveness. I'm not looking for a hail-mary as my tranny isn't 100% shot.
I'm thinking a double pronged attack using solvents and esters in two separate steps, with some minor overlap unavoidable. The end goal is to end up having the tranny completely filled wiith OEM Honda DW-1 ATF with LG Red at a concentration of between 1-2 oz per quart.
My question is how long should I keep the Seafoam TT before dumping it?
SF says as a preflush, drive at least 30 miles, and it can be left in as a conditioner, with it having such a Low Flashpoint... I can just keep it in for say for the next 300 - 1000 miles and it will eventually complete burn off right and leave me with 16 oz less in volume right??? I'm mainly using the third party universal ATF as prolonged carrier for this cleaning regime! Currently I'm just trying to figure how more many drain & refills before I start the RX, as Seafoam TT does have isopropanol in it.
Will remnants of solvent and alcohol interfere or compete for space with RX? I know I gotta do at least another 1x (or maybe 2x) drain & refill before I start the second phase on RX for 1000 miles - then more drain & refills - YAY!
Your thoughts? Or am I just wasting jugs and jugs of good ATF?
THANKS for READING!
sick
Valvoline Import ATF +SEAFOAM TRANSTUNE | 5W-20 +AUTO RX PLUS
sailing 3rd party additives are the elixir to driveline immortality
planned obsolescence WWFis traitorous to the world
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5252453 10/28/19 07:28 PM
K
kschachn Offline
K
Wow, just wow. I have no idea how you could ever decipher what you did or didn't do. If there is a problem with shuddering and flaring with the proper ATF then Seafoam isn't going to fix it.
Remembering your previous posts is there anything you don't add a plethora of additives to?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5252466 10/28/19 07:33 PM
M
Mad_Hatter Offline
M
I've got no "advice" as I've seen or heard of more tranny's being ruined by a chemical flush than fixed, but maybe at this point you've got nothing to lose... (this is because most people I've seen resorting to a chemical flush are doing so on a worn tranny on it's last leg)
Good luck...
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5252467 10/28/19 07:33 PM
T
tdpark Offline
T
flashing D is usually 3rd and 4th pressure switches going bad. Easy and cheap fix as they are right next to driver side tire. Get the codes read if you can otherwise you are shooting in the dark.
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5252472 10/28/19 07:37 PM
M
Mad_Hatter Offline
M
Q: if the Lubegard eliminated all the shudder/flare, why did you drain it? Lubegard has additives that'll "replenish" a degraded fill... sure it'll be dirty but if it's running, why bother with a D&F??.. it's not like you're expecting to get another 100k out of it are you?
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5252495 10/28/19 08:01 PM
V
vwmaniaman Offline
V
I used Berrymans B12 in the powerglide of a Corvair I bought at Amoco that they got from the owner for an estimate. It wouldn't shift into 2nd gear. Used 1/2 a bottle in it and drained it after it worked and drove about 50 miles and changed the fluid. Never had another problem with it.
Don't waste your time on a slipshod repair.
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: tdpark] #5252506 10/28/19 08:13 PM
Like many here on BITOG, we go OCD!
crzy
cheers
+1 absolutely, all very well detailed on odyclub & piloteers forumz
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: Mad_Hatter] #5252512 10/28/19 08:16 PM
Because it was wicked dirty. After the initial 3x drain & fill, they never came back, currently I have no LG Red.
I actually am expecting to get another 100k *wink *wink, the motor is strong and smooth, chasis straight.
smirk2
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: vwmaniaman] #5252516 10/28/19 08:20 PM
+1 PROPS for thinking outside the box, going against the grain and professional recommendations! Sure it was risky, but the rewards you harvested.
Kind of like back in the day when B-12 had instructions for engine flush, like 15 minutes at idle.
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5252521 10/28/19 08:25 PM
I also contacted the manufacturer regarding what I can expect or an idea of evaporation of the Seafoam TT, just out of curiosity, which really was my main question I had. I post the reply from them if any soon.
What I'm doing isn't exactly shocking nor drastic, it's just back to back treatments very close together.
If was desperate, I would run KREEN in the tranny shocked shocked shocked
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5252542 10/28/19 08:56 PM
J
joegreen Offline
J
I don't have experience with the 5 speed but i do with the 4 speed baxa in my 2002 Accord 4cyl. My transmission has flaring issues. I tried amsoil, castrol import, dex 6, type f, and dw1. I tried the Honda fluid last because i find it hard to believe that it has to have honda fluid like alot of people say. Anyway so far i really like the dw1. It seems to shift best with it. Now as far as the seafoam transtune i would not worry about how long it says you can keep it in there. I put a can of transtune in and the transmission got much better. After running it a while i drained out some fluid and added another can. The transmission felt even better. I started to get concerned about the transtune thinning out the fluid so i left it as it was. I ran the transtune for 30k-40k miles and never had any adverse effects.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5252593 10/28/19 09:51 PM
demarpaint Offline
Wow. I’d be worried after adding all of that. I would have stuck with LG red OE fluid and a couple of 1000 mile runs then drain and fill.
IMO the transmission is not long to this world.
God Bless Our Troops
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: demarpaint] #5252597 10/28/19 09:56 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
+1
A few gentle flushes would either do it good or bring on the inevitable...
Ive heard of old transmissions doing well with use of trans-x solvent, but it’s always just chance.
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5252644 10/29/19 12:36 AM
M
Mad_Hatter Offline
M
smirk2
I know LG makes a "flush" but it doesn't contain any solvents and I think Amsoil makes a similar product. The LG product is all detergents and dispersants in esters, so it takes a "softer" approach than solvent based flushes. I woulda tried that first..but anywho, moving forward.
Keep us posted, I'm curious to see how it works. If the engines still runs smooth maybe it's worth trying to keep that tranny running. I know at some point you have nothing to lose, right?
Re: SEAFOAM TRANS TUNE just added to Fragile Honda 5-speed Automatic Transmission [Re: discountdon] #5252728 10/29/19 05:59 AM
H
HangFire Offline
H
discountdon,
Your transmission shows the classic symptoms of the 4/5 and 4/5 shift sensors going bad, a common and inexpensive repair, I did mine (at 100K miles) for less than $100, and the Blinking D, shift flares and clunking into Reverse went away for another 100K miles. The transmission was toast 214K miles.
Replacing the sensors is about as hard as an easy spark plug replacement.
Various musings: http://hangfire.net
Page 1 of 3 1 2 3
