Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
Dexron 6 or Dexron VI ???
by brages - 11/21/19 04:53 PM
PP on great deal for Canadians this week
by Jimmy_Russells - 11/21/19 04:40 PM
Ford Maintenance Schedule
by borgward - 11/21/19 04:22 PM
hotshot fr3 oil additive?
by dogememe - 11/21/19 02:27 PM
Turtle Wax Hybrid Ceramic
by Toros - 11/21/19 02:01 PM
Need earbud recommendations!
by cwilliamsws6 - 11/21/19 01:50 PM
Corslayth, oildud, Kylefl1, JDee71, trgfunds
69936 Registered Users
63 registered members (4WD, burla, Aero540T, Astro14, BlakeB, 3 invisible), 1,444 guests, and 20 spiders.
Topics297,753
Posts5,121,896
Members69,936
Most Online3,589
Nov 2nd, 2019
Rate Thread
Page 1 of 3 1 2 3
Sil glyde drying out ? #5252149 10/28/19 12:51 PM
E
E150GT Offline OP
E
Does sil glyde dry out easily or is this something else ?
At about 50k on my Mazda I relubed the slide pins on the front brakes. This weekend I replaced the pads at 72k. The bottom slide pins on each side were stuck. I pulled all the pins and they weren't Dry but not super greasy. I am wondering if I am going to have to pull the pins at 20k intervals or just use something else like super lube.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 68k 5w30
2006 Buick Lucerne CXL 3.8 40k 5w30
Re: Sil glyde drying out ? [Re: E150GT] #5252179 10/28/19 01:46 PM
spasm3 Online Happy
Online Happy
The are 2 versions of syl-glyde. One is a grease , one is marked as for brake use.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 16400 miles m1 0w40
Re: Sil glyde drying out ? [Re: E150GT] #5252180 10/28/19 01:47 PM
H
hallstevenson Offline
H
I had some Sil-Glyde that was old but when it came out of the tube, it "felt" fine. Used it on our new-to-us car not long after we bought it when I just serviced the brakes. Sometime later, I replaced the pads and rotors and the slide pins were fine, still lubricated and slid fine, but the pads were literally glued to the caliper and piston from where I lubed the backs of the pads. I had to use a screwdriver or small pry bar to break them free !
Re: Sil glyde drying out ? [Re: spasm3] #5252195 10/28/19 02:14 PM
B
Bottom_Feeder Offline
B
They are the same product in a different tube.
Re: Sil glyde drying out ? [Re: E150GT] #5252415 10/28/19 06:49 PM
H
HangFire Offline
H
If the pins are dry, the problem is likely the pin seals or boots. Even the slightest misalignment or crack and you'll have a problem, especially with the bottom pins. Sometimes too much grease causes a hydraulic blowout of the boot just as you tighten it down. You also want to avoid air gaps inside. That may mean a trial fitting and adjustment of the grease quantity, but pay careful attention to the boots.
I don't use Sil-Glyde on the backs of pads any more, as my FSM's recommend a Moly grease for that purpose.
Various musings: http://hangfire.net
Re: Sil glyde drying out ? [Re: E150GT] #5252423 10/28/19 06:54 PM
R
Rand Online Content
Online Content
R
I use sil glyde on the pins and have not had stuck pins, however not that great on pad ears and back.. I use pastelub for that.
https://goodson.com/products/bpl-2400-pastelub-brake-lubricant
Re: Sil glyde drying out ? [Re: Bottom_Feeder] #5252429 10/28/19 06:58 PM
O
Oro_O Offline
O
Yes.
Quote
Yes +1.
Even good grease will get washed out and contaminated with road water intrusion - can be nasty stuff. I note this is a Subaru and I don't have intimate experience, but IME, Japanese vehicles in general are weak on this point. Not my only data points, but for example: I have a three decade old Audi that's still good w/boots, brakes, and it lived most of it's mileage in New England. I have two younger, same mileage Japanese vehicles (Lexus, and Acura/Isuzu) that have lived entirely in non-salt PNW and both have had problems with the pin "hats" leaking and seizing.
Re: Sil glyde drying out ? [Re: E150GT] #5252499 10/28/19 08:02 PM
Silverado12 Offline
The grease I use is marked specifically for pins and it's a dark color. Nothing like Sil- Glyde.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Sil glyde drying out ? [Re: E150GT] #5252522 10/28/19 08:26 PM
M
maxdustington Online Content
Online Content
M
Yeah, it's not that great. It doesn't last that long in the rust belt, but I am shocked that you are having issues with it. I always thought winter driving washed it out. You really need to put a lot on there to make it last.
Get real silicone paste. I recently got some 3M but I have not reached any conclusions on it's longevity.
99 Toyota Tercel CE 5EFE/C151
Re: Sil glyde drying out ? [Re: E150GT] #5252592 10/28/19 09:51 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Wonder if in some applications moly paste or moly/marine anti seize would be better, since the particles might remain..
Re: Sil glyde drying out ? [Re: E150GT] #5252910 10/29/19 09:23 AM
T
Tundragod Offline
T
FYI. Two weekends ago, I switched my all season tires to Winter tires so I decided to check the caliper pins since the wheels were off anyway. 1 pin at bottom rear right was rusty frozen (had to pound out). Bottom rear left was rusty but not frozen, yet. The rubber boots were fine. The rest of the pins(6) needed re-lube as well and some had small rust spots. I lubed all pins last year, 09/08/2018. What this telling me is that, at a minimum, check caliper pins and lube it every year. Salt water will get in there. I will be checking and lubing them when Winter wheels coming off in the Spring.
12 Highlander limited, 08 Accord EXL 4, 04 MDX Tour, 02 CRV EX, 1995 Virago.
Re: Sil glyde drying out ? [Re: maxdustington] #5252944 10/29/19 10:17 AM
P
painfx Offline
P
I wonder the Sil Glyde from Napa vs 3M silicone, which would last longer and be better for the slide pins.
Re: Sil glyde drying out ? [Re: E150GT] #5252955 10/29/19 10:31 AM
J
JTK Offline
J
Rear caliper components take a horrible beating on rust belt vehicles no matter what lube you use.
I've used Sil glyde as long as I've been on BITOG for pin lube. For me, I've found I have to clean and re-lube them every 1-2yrs or they stick.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Sil glyde drying out ? [Re: Tundragod] #5254577 10/30/19 09:47 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Good reminder for folks to check. I know I never do...
Honestly it may sound stupid, but we’re here to learn... I’m not sure I know how... each caliper is different. Does one actually unscrew or drive out the pins, or just pull back boots when they’re present? Ive repaired, replaced and lubed these things when doing brake jobs, but this is slightly different.
Re: Sil glyde drying out ? [Re: E150GT] #5254579 10/30/19 09:53 PM
spasm3 Online Happy
Online Happy
I used up my sil-glide, on my last brake job. I'm considering trying either the 3m grease or Mission.
Page 1 of 3 1 2 3
