Aye everyone, I just replaced the hose from my power steering reservoir to pump and discovered a leak between the pump to pressured line. I replaced the lil rubber O ring with OEM on the pressured line and although the leak is dramatically less it still leaks a small ring around where it connect. Any ideas? Could the pressured line have a nick in it causing the leak? It's for a 03 Civic LX btw
