Originally Posted by CapriRacer
The OP - Overkill - was complaining about the OE tires on his Ram - and he mentioned that they were the same make and model as on his SRT.
I wonder what affect Fiat is having on the tire qualification process. It's always been my opinion that Pirelli tires tend to be slippery in the wet, and for the longest time, you'd be hard pressed to buy a new Italian car without Pirelli's on it. I've always made the connection.
But that is not what is going on today. Both the car business and the tire business are now global in nature. The fact that you can buy a Ford and it might come with a Japanese brand tire speaks to that.
So are Chrysler products now coming with tires that are tested in Italy and it's those test surfaces that are driving the wet traction? Similar to the way Japanese car manufacturers use test surfaces in Japan and those tires have poor wet traction in the US?
Plus, OE tires aren't made cheaply or out of cheap materials. They are designed to the vehicle manufacturer's specs which usually call for Low levels of rolling resistance in order to get good fuel economy - and that means wear and/or traction have to be sacrificed.
The result is tires that don't perform up to the consumers expectations. And while the OEM don't pay very much for tires, it's because of the sheer volume of tires they buy and the ease of shipping - a steady flow from point A to point B for years. That greatly reduces the hidden cost.
Basically an infomercial on Pirelli by TFL Truck, but worth a watch IMO.
https://www.youtube.com/watch?time_continue=1&v=xkpsVoKlrIg
