Originally Posted by geeman789
This whole BUT THE WARRANTY argument gets tiresome. Car makers want proof that you actually changed the oil. They look at the dipstick and the used oil's appearance. Check for an assembly plant oil filter ... Maybe they pull a valve cover and take a peak, if the owner's story seem off.
They DON'T pull an oil sample, have it analyzed, then extrapolate the winter grade by using the 100 c and 40 c viscosity curve, then chemically analyze the formula to determine if it meets THEIR brand specific oil spec., then deny the warranty because they have determined that you used an 0w20 where a 5w20 was recommended. Really, they don't ...
They don't have to lift a finger to find out I don't have the right oil in my '19 VW Tiguan.
VW 508 0w20, by requirement, must have a easily visible green-blue color. I have thought the dye might wash out with age, yet VAG put that requirement there to rat us out.
Would a dealership deny an engine warranty claim (for example, if the timing chain stretched, or I lost a rod bearing) if they found out I'm being naughty & currenlty putting in Pennzoil Platinum 0w20 because I had it left over in my stash?
I do plan to get with the program and use VW 508 in the future, since its a great spec.
