Rolla07
Thread starter
Originally Posted by tcp71
The vensa is a camery wagon. LT tires would be ridiculous on that vehicle and make it extremely harsh. Wider than stock tires make for worse ability in the snow as they tend to float and slide more. Winter tires are often narrower than summers to cut through snow and slush better. A set of Nokian Hakkas on steel rims and you are off to the races.
Thats what I originally was considering but they run 100$ more per tire than AT3s..so 460$ more for a set with our taxes...thats a big chunk of change. If the AT3s are as good as even mid quality winters, id go for them.
