I have been talking with shell regarding a suitable oil for my old push rod engine, which is a 4.9L F150.
I have been using a conventional 10w30, which is what Ford specifies for that engine. I don't want to use the high mileage oils or synthetic oils! The engine is very strong and smooth but with a lot of tappet noise. To remedy the tappet noise I have been adding Lucas oil conditioner or stabilizer, which I typically never do. But she seems to like the thicker oil and quiets down to where you can nearly hear the old engine run. She now has 141k on the clock.
As I said I have been talking with Shell/Rotella, describing the engines reaction to the 10w30 as I did above. Shell lubricious expert was brought into the discussion and I ask him his thoughts about going to a heavier weight oil (10w40 or 15w40) which it seems to enjoy.(eliminating the Lucas oil Stabilizer) and going to diesel oil which has the zinc and phosphorus the push rod engine needs.
The shell lubricity expert came back saying they would not recommend going to a heavier weight oil sine the manufacturer defined 10w30. He would recommend going to a Rotella T4 10w30, which contains higher levels of phosphorus and Zinc which is what the engine needs, if I didn't have a Catalytic Converter.
I responded with, being a 96 it certainly has a Cat. So given that it is entirely stock with Cat what would be his recommendations to eliminate the tappet noise that is so prevalent with Straight Valvoline 10w30 and no Lucas.
He said as what is best for the longevity of the engine would be Rotella T4 10w30, but as far as the potential plugging of the Cat, it would be somewhat uncertain, but he though it would be the lesser of two evils.
So that's where I'm at! Do I just continue with10w30 with a Lucas oil stabilizer additive, do I go to a heavier 10w40 conventional oil, do I go with a diesel oil that give me the zinc and phosphorous with a weight of 10w30 or go to 15w40 diesel oil? It's a tough question. I would appreciate hearing your thoughts.
