Coronavirus
by buster - 01/23/20 08:04 PM
Used vehicle shopping
by 53' Stude - 01/23/20 08:01 PM
Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Wix 51269 I think cut open
by Mightymouse - 01/23/20 04:08 PM
What oil for a new VW Beetle?
by widetrax - 01/23/20 03:52 PM
Lossless audio music
by Cujet - 01/23/20 03:38 PM
Castrol Edge on Rollback at Walmart
by Matt1980 - 01/23/20 03:35 PM
Regretted Selling a Car?
by RDY4WAR - 01/23/20 02:14 PM
3 American Volunteers lost in Oz fires....
by Shannow - 01/23/20 02:13 PM
Need a tire pressure gauge
by nomas - 01/23/20 02:11 PM
Why Waffle Sipes - but very little depth
by Cressida - 01/23/20 02:05 PM
Personal finance book in Spanish
by czbrian - 01/23/20 01:03 PM
SQL Basics?
by tom slick - 01/23/20 11:08 AM
Unused PRO-TEC 101 oil filter cut open / Wix 51515
by rollinpete - 01/23/20 10:32 AM
Mailman1995, DougCFL, Sayafi, SeanSkiVT, 02COBRA
70512 Registered Users
117 registered members (2009Caraman, 4WD, 2003f7, 53' Stude, 15 invisible), 2,435 guests, and 18 spiders.
Topics300,476
Posts5,176,754
Members70,512
2014 F150 intermittent low oil pressure alert at idle only #5249268 10/24/19 06:47 PM
1
10WSmuckers Offline OP
1
95k miles on a 5.0L V8. Engine runs like a top with a steady diet of Motorcraft 5W-20 synthetic blend whenever the oil change reminder comes on. This issue started a week after the last oil change and at that time I did not use Motorcraft oil but rather Mobil 1 that was on sale. The FL500-S filter is the only filter I have ever used on it as well. Digging more into it, the alert will come on the dash when the engine is idling in gear. The slightest kick of the gas pedal will bring the pressure back to normal on the gauge cluster. This will not happen all the time but it seems to fix itself after an extended period. Any time the alert is on the dash the engine does not have any noticeable sounds or even a decline in performance. No ticking, knocking, sputtering or misfiring at all. So am I looking for a bad pressure switch or even a filter that's stuck in bypass? I am lost I will admit.
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5249274 10/24/19 06:54 PM
CT8 Offline
I doubt the filter stuck in bypass could cause a low oil pressure. Could be the sender. check it out with a meter by the factory method
2015 F150 2.7
2018 F350 6.2
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5249277 10/24/19 06:58 PM
U
UncleDave Offline
U
original owner?
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5249290 10/24/19 07:23 PM
B
Blkstanger Offline
B
Change out the sending unit. If all else seems good it's probably a bad sender
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5 Castrol Edge EP 5w30 Fram Ultra.
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5249291 10/24/19 07:34 PM
T
tundraotto Offline
T
What is the oil level now? What oil grade was put in?
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5249299 10/24/19 07:46 PM
czbrian Offline
We replaced the sending unit on my dad’s 2011 f150 5.0. Similar symptoms but had twice the miles as yours. No issues since. Initially thought it was the filter or oil but it kept happening off and on.
2019 Honda Pilot
1998 Chevrolet C1500
1995 Chevrolet C1500
2018 Mitsubishi Outlander PHEV
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5249317 10/24/19 08:13 PM
P
perfect_oil Offline
P
Perhaps change back to Motorcraft and see what happens.
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5249377 10/24/19 09:23 PM
bdcardinal Online Content
Online Content
The senders are incredibly cheap, I would try that first.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5249386 10/24/19 09:37 PM
TheLoneRanger Offline
I changed out an Explorer sender/switch last week, with the same symptoms as you describe.
It's very unnerving to have oil pressure fluctuate like that when you're out of town and many miles
from home. This is the third oil pressure switch I've changed on various Fords in the last few
years. I don't think they last very long...
Some days you eat the bear, some days the bear eats you.....
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5249428 10/24/19 11:11 PM
Z
ZeeOSix Offline
Z
The Mobil 1 might be just enough thinner at operating temperature to trip the low pressure sensor at idle in gear. I'd try a new sensor first as others suggested. An oil filter in bypass won't change the oil pressure down stream of the filter.
This being a 2014, I'm assuming it doesn't have a computer controlled variable output oil pump.
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5249466 10/25/19 03:04 AM
B
billt460 Offline
B
........ Digging more into it, the alert will come on the dash when the engine is idling in gear. The slightest kick of the gas pedal will bring the pressure back to normal on the gauge cluster....
What is the pressure it is showing on the gauge cluster when the light comes on?
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5249635 10/25/19 08:01 AM
R
ragtoplvr Offline
R
change to 5W30
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: billt460] #5250155 10/25/19 07:37 PM
1
1
The gauge drops to zero every time and the engine isn't cutting out or making noise.
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5250245 10/25/19 10:06 PM
That's exactly what mine did. The slightest rpm rise would bring the pressure back. I can almost guarantee it's a defective switch.
If you remove the wiring connector to the switch, you'll find oil seeping from the switch, not enough to drip, just enough to wet
the connector. That's confirmation of a faulty switch.
Re: 2014 F150 intermittent low oil pressure alert at idle only [Re: 10WSmuckers] #5251403 10/27/19 02:48 PM
W
wtd Offline
W
My 14 Mustang doesn't have a oil pressure gauge but periodically I get a message in the message center about low oil pressure and I only have 31,000 miles on the car. The last time I was under the car, I unplugged the connector to the sensor that is mounted in the oil pan and plugged it back in. The message has not come on since. I've used 5W-20 Motorcraft and the Motorcraft FL500s filter since the car was new.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
