So, I changed out the transfer case and the differential fluids on my '03 Montero with 30k miles on it. The magnetic drain plugs on the differentials had quite a bit of metal on them and the fluid was very black. I was surprised the fluids looked so bad at only 30k miles. The transfer case fluid actually looked much better than the diffy fluids.
I put in Redline Fluids.
I drove around for in 4WD for 30 minutes to warm up the fluids. Checked the diffy fluids with a meat thermometer. They were both 120F. The transfer case was 115F.
