Coronavirus
by buster - 01/23/20 08:04 PM
Used vehicle shopping
by 53' Stude - 01/23/20 08:01 PM
Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Wix 51269 I think cut open
by Mightymouse - 01/23/20 04:08 PM
What oil for a new VW Beetle?
by widetrax - 01/23/20 03:52 PM
Lossless audio music
by Cujet - 01/23/20 03:38 PM
Castrol Edge on Rollback at Walmart
by Matt1980 - 01/23/20 03:35 PM
Regretted Selling a Car?
by RDY4WAR - 01/23/20 02:14 PM
3 American Volunteers lost in Oz fires....
by Shannow - 01/23/20 02:13 PM
Need a tire pressure gauge
by nomas - 01/23/20 02:11 PM
Why Waffle Sipes - but very little depth
by Cressida - 01/23/20 02:05 PM
Personal finance book in Spanish
by czbrian - 01/23/20 01:03 PM
SQL Basics?
by tom slick - 01/23/20 11:08 AM
Unused PRO-TEC 101 oil filter cut open / Wix 51515
by rollinpete - 01/23/20 10:32 AM
Mailman1995, DougCFL, Sayafi, SeanSkiVT, 02COBRA
70512 Registered Users
119 registered members (2009Caraman, 4WD, 2003f7, 53' Stude, 15 invisible), 2,454 guests, and 18 spiders.
Topics300,476
Posts5,176,754
Members70,512
Page 2 of 2 1 2
Re: My latest battery load test [Re: Char Baby] #5249029 10/24/19 01:59 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I don’t know what maintainers you’re talking about.
Mine take CV charge up to the 14.4-14.7V range, while current decays (which is what I noted that I observed), before transitioning over to a temperature compensated float voltage.
Of course current will be lower at float voltage, since there’s less over potential. My point was if you’re still seeing amps of current at 14.4-14.7V, and it’s starting to rise, that energy is going somewhere slowly (high impedance short). Otherwise it should decay. The energy can’t go nowhere.
Re: My latest battery load test [Re: Char Baby] #5249469 10/25/19 03:19 AM
W
wrcsixeight Offline
W
A maintainer which seeks to bring battery to and then hold it at 14.7v for a period of time, and then drops to a temperature compensated float voltage is obviously much better than a single voltage max 13.6v maintainer.
But its foolish to believe 'ALL' maintainers out there, are 2 or 3 stage 1.5+amp capable chargers seeking to hold 14.4 to 14.7v for a period of time before reverting to float.
How many amps the maintainer has available in order to seek 14.4 to 14.7v, is a big issue.
Both batteries I am now using both deep and shallow cycling regularly, now require way more than 1.5 amps to reach 14.7v. The one starting my engine now, for the last year, has required more than 1.5 amps to reach and maintain 14.7v when fully charged.
so a 1.5 amp maintainer, even if it is seeking 14.7v, will never get either of these batteries to 14.7v, as the one battery requires 4.7 amps to get to and be held at 14.7v and the other requires 5.4 amps when they are very near or at full charge.
Both these batteries are end of life, and have many hundreds of deep cycles on them and thousands and thousands of engine starts and are both a month shy of 6 years. They have delivered many hundreds of KWH over their lifetime, whereas the average starter battery will have delivered a tiny fraction of that when they are too weak to do their job.
They could indeed have 'high impedance shorts'
As I've watched these batteries age I've seen that amps stop tapering at higher and higher levels when fully charged, then starts rising, along with battery temperature.
They are still being cycled and charged.
One of them is still easily able to start my engine, the other, I'll not bother trying. It hasn't since June 2015.
A 1.5 amp maintainer placed on either of these two batteries would not be able to get them near full charge, even if it was a maintainer capable of seeking 14.4 to 14.7, which not all do.
ALL lead acid batteries, as they age, will require more and more amperage to be held at the same voltage when they are fully charged. These 'tail' amps at absorption voltage, are indicative of age/ condition and when the battery requires more than 1.5 amps to reach 14.5v, and the maintainer only has 1.5 amps available, then the battery will not reach 14.5v and as such it will likely not be able to achieve full charge.
Some say a failing battery will take out an alternator. I don't know how much a shorted cell sucks up. But the extra 4 to 5 amps my alternator now has to produce to maintain my aged battery at 14.7v is not going to push my alternator or external voltage regulator over the edge.
I got plenty of alternator temperature data( and voltage regulator temperature data) at different output and speeds. 18 more amps of output ( blower motor on high) at 65mph makes the alternator stator 2.5 degrees hotter. Under 25mph is a different story.
So trying to fully charge a battery with a maintainer is unwise.
Can some maintainers achieve full charge given enough time?
Sure, on a newer healthy and generally smaller battery.
Can every 'maintenance' charger sold since they came out, achieve full charge of a depleted battery when given enough time on a larger mid life battery, NO.
Easily Provable with a hydrometer, but few to none bother. I have, I do, Its obvious. When one wants to see 1.280 on all cells and sees 1.255 instead, the battery is NOT fully charged, no matter what voltage it might hold. If 14.7 or higher voltages applied and held, never raises specific gravity over 1.255, then the battery is sulfated, and is fully charged to its maximum remaining capacity.
I've not used the impedance testers.
I've not used carbon pile load testers, but few can actually load half the CCA figure of the battery and hold it for 30 seconds.
According to the SAE J537 CCA test, the fully charged battery is to maintain more than 7.2v after 30 seconds when loaded to half the CCA rating of the battery, not 10.5v as stated in another thread....
https://batteryuniversity.com/learn/article/how_to_measure_cca_cold_cranking_amp
Half the CCA figure of a battery, is a big amperage number, asking the battery to deliver this, for 30 seconds, is very hard on the battery.
A true load test is damaging to the battery, to some degree.
The voltage the battery can maintain under load, ANY load, is a load test.
Obviously bigger loads are more revealing.
My starter draws nearly 1800 watts when i last measured it.
Its rated to output 1400watts.
1800 watts at 10 volts is 180 amps.
1800 watts at 11 volts is ~163 amps
1800 watts at 12 volts is 150 amps.
The voltage as the battery ages keeps dropping when starting the overnight cold engine.
Higher amperage causes more voltage drop on the cabling leading from battery to starter.
Each time I start my engine therefor is a 150 to 180 amp load test.
Seeing how low voltage falls each overnight cold engine start, as the battery ages, at different temperatures and state of charge, is very enlightening, and I have been doing this for many years now.
This equals Thousands of observations of voltage maintained during engine cranking. The voltage falling lower and lower during engine starting, has been a steady decline over the nearly 6 years I've been using this battery.
One does not need to purchase an impedance tester, or a carbon pile load tester, or take their battery to an autoparts store to have it tested.
They can simply watch a voltmeter every time they crank their engine instead. An analog needle would be better than a digital voltmeter which samples voltage 2 times a second or has a delay.
When voltage drops to a certain level while cranking the engine, it is obvious the battery is weak, or perhaps just undercharged, and one should recharge and try again hoping to see a higher voltage held while the starter is spinning, or begin shopping for a battery, and carrying their fully charged jumperbox, or cables, or just replace the battery. I am carrying a fully charged jumper battery, and have been, for nearly a year. Glad I did not buy a new full size battery a year ago, as this one can obviously still do its job.
The money saved by not buying a carbon pile or impedance tester can be put toward a good quality maintenance charger and the hardware to easily/conveniently plug it in, or a bigger battery.
That said if I owned either, I'd definitely use them, as another data point, but neither are going to tell me what my other observations of performance, already have.
But I'd rather spend that money elsewhere.
Re: My latest battery load test [Re: Char Baby] #5250105 10/25/19 06:42 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
The strange part of all your logic is this - power supplies can current limit at a set voltage. So even a chintzy little maintainer could get the voltage up to where you want, question being if it can handle the total power... something in there is a limiting step... but doesn’t mean that some low rating supply couldn’t give it... we’re talking a few watts max.
Whether or not the battery will stop absorbing current and decay to a lower amount is a different story...
Volts drive amps, not the other way around. You need overpotential to overcome the internal impedance on charge. You just can’t push more current without more voltage.
But a power supply can current limit and give whatever voltage it is designed for.
Re: My latest battery load test [Re: Char Baby] #5250153 10/25/19 07:35 PM
W
wrcsixeight Offline
W
I am building a 24vdc fan to have infinite speed control from 8 to 28 volts. At 8 volts this fan draws 0.16 amps. At 28 volts it draws 2.45 amps.
I am using a power supply that can either lower or raise the output voltage from the voltage it is fed.
This power supply has a current limiting potentiometer.
If i limit current to 2.0 amps when powering this fan, Then i cannot get more than 25.4 volts. No matter how much higher i crank the voltage potentiometer.
If i limit the voltge to 25.4v and crank the current pot as high as it will go. 10 amp on this particular supply, Then voltage stays put and fan speed does not change and amperage rises no further.
If i instead lower the current pot with voltage pot still set at 25.4, Then voltage falls with the current being limited as this fan requires 2 amps.at 25.4v and 1.2 amps at 21 volts. I can limit max voltage achievable by the current potentiometer. This power supply will go as high as 36 volts. I dont ever want the fan to see 36 volts. So i use the current potentiometer to limit amperage to 2.45 volts, then voltage cannot ever exceed 28 volts when powering this fan.no matter how high i crank the voltage potentiometer.
Its the same thing with a battery. A new healthy battery when fully or near full charge might require 1 amp to attain 14.7v.
A mid life battery might require 1.75 amps to attain and be held at 14.7v when fully charged.
A 1.5 amp limited source will then on this battery never be able to achieve 14.7v.
An un loaded.power supply /charger might be seeking a constant voltage of 14.5,but hook it to a 12.2vbattery and the voltage at power supply and at battery terminal falls to much closer to battery voltage, Than the power supply set voltage.
As the battery charges. The shared voltage rises. Slow.with fewamps available much faster with higher amperage available.
But if there is only 1.5 amps to work with, and the fully charged battery requires more than 1.5 amps to reach 14.7v.
Then it will never reach 14.7v.
There is no flaw in my observations. There is a glaringly obvious misunderstanding on your part about the relationship between voltage and amperage when charging batteries. Or powering a load.
Thats the problem with book learning and no experience, combined with insecurity and ego.
Guess ill be taking a vacation or something more permanent now.
I Waste way too much time here anyway.
Re: My latest battery load test [Re: Char Baby] #5252600 10/28/19 10:03 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
A motor and an electrochemical system are not the same thing.
A motor in the case you describe has a set resistance, inductance, back EMF and torque.
V=I*R+L*dI/dt+E
Where I is related to the motor’s torque and E to the angular velocity (RPM).
In a battery, it’s related to the thermodynamic characteristics of the reaction (feasibility at conditions), and the kinetics of the reaction.
Vt=I*R+Voc
Voc is set by thermodynamics of the half cell potentials. So while in your motor case, EMF is related to angular momentum, and varies with speed, in the case of a battery, Voc varies with what the relative ratios of the reagents are inside.
Because in the battery, amps are a quantity of charge, related by coulombs and time, we can know exactly how many atoms can be reacted with these parameters, we can actually track the quantities of reagents and thus the electrochemica potential change with time. Thus why state of charge and voltage are linked.
With the battery, you can drive the electrochemical potential higher, and restrict the reaction rate, because the I term is going into the chemical reaction. With insufficient voltage you can’t overcome polarization, but with sufficient voltage you can then meter in just how many moles of electrons you wish to dose to change the reagents.
With the fan, the I*R term is dissipated by shaft work, so insufficient torque and the motor can’t keep up the angular velocity thus less back EMF... vicious cycle. The linkage in the battery isn’t the same.
Re: My latest battery load test [Re: Char Baby] #5254599 10/30/19 10:27 PM
T
The_Nuke Offline
T
“They can simply watch a voltmeter every time they crank their engine instead.”
The usage of ‘simply’ in that sentence is incorrect...or at the very least ill-advised.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.65 (215mm)
Page 2 of 2 1 2
