Originally Posted by Fitz98
I also have a startup noise like you describe, sounds like after 1 cycle of the pistons it is gone, which I thought was just oil leaking down. It makes me cringe every time. It does it each day, worse when left to sit for a couple days. I park my truck front up up on a slight incline if that matters. Another thing I notice that it is worse as the summer is getting hotter here in Florida. I notice you are in CA, so maybe it is temperature related? I also have a bad knock sensor that eventually needs replacement, don't know if it is related or not.
I also just had my driver side Cat converter cut out of my '03 Suburban. Sounded like a rapping rod.
Not saying that is what your problem could be, but mine started very gradually, initially only slight sound coming from what seemed drivers side engine compartment at cold startup and went away when it heated up. It got worse each day and eventually I had it removed. Inside the honeycomb material came loose and was broken. Maybe you are hearing a piece of that material against the cat converter housing?
You could tap the converter with a hammer to see if you can duplicate that noise.
I had the same cat noise in my 03 Avalanche, which is a suburban with a bed.
