More Dog pics
by Marco620 - 11/16/19 11:48 PM
which weather site is most accurate?
by WhyMe - 11/16/19 11:25 PM
mopar coolant
by boombie10000 - 11/16/19 11:11 PM
2015 Honda CR-V loud engine noise
by FordBroncoVWJeta - 11/16/19 11:10 PM
Old Vise info
by A310 - 11/16/19 10:18 PM
2003 Ranger Radiator Replacement: Which Coolant?
by chucky2 - 11/16/19 08:55 PM
ATV axle removal
by supton - 11/16/19 07:45 PM
High speed chase
by P10crew - 11/16/19 07:28 PM
Oil for Daily Beater Camry
by Speak2Mountain - 11/16/19 07:18 PM
Green coolant, future availability ?
by rubberchicken - 11/16/19 06:11 PM
Weird tire wear
by ledslinger - 11/16/19 04:50 PM
Why does Ford resell lemons?
by avacado11 - 11/16/19 04:07 PM
Slow initial response to loading web pages
by JHZR2 - 11/16/19 04:06 PM
Motorcraft FL-910S
by PW01 - 11/16/19 03:54 PM
Walmart ammo clearance
by redbone3 - 11/16/19 03:35 PM
GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
billad67, Diverdown, natas, matt3540, ChrisWild
69886 Registered Users
51 registered members (69Torino, 928, bdcardinal, bbhero, BarryinIN, Black_Thunder, 2 invisible), 1,273 guests, and 20 spiders.
Topics297,525
Posts5,117,377
Members69,886
Most Online3,589
Nov 2nd, 2019
Replacing 1 Tire With A Smaller Size, Temporarily? #5248339 10/23/19 06:34 PM
K
Kevinmcc2 Offline OP
K
Hey all, my friend needs a new tire since he hit a pot hole and blew the sidewall out. I have an extra used tire but it is slightly different size.
It will be going on the rear of the vehicle and the car is FWD front wheel drive. (Hyundai Elantra)
His tire size = 195/65-15. The spare I have laying around is 195/55-15. He wants to use it for a temp solution until winter but was wondering if this is safe or not?
Re: Replacing 1 Tire With A Smaller Size, Temporarily? [Re: Kevinmcc2] #5248348 10/23/19 06:49 PM
A
atikovi Offline
A
It will be fine. Space saver spares are much smaller than that.
Re: Replacing 1 Tire With A Smaller Size, Temporarily? [Re: Kevinmcc2] #5248394 10/23/19 07:31 PM
E
eljefino Offline
E
There's a decent chance your load rating will be less than his car requires.
Rear axle won't see that, but it's still an engineering/ legal liability.
195-65-15s are stupid cheap, $40, that he'd blow half that paying to mount and unmount.
Re: Replacing 1 Tire With A Smaller Size, Temporarily? [Re: eljefino] #5248407 10/23/19 07:49 PM
F
FordBroncoVWJeta Offline
F
He's almost better off going to Walmart and buying a cheap douglas in that size. Probably $60ish before tax vs $25ish for your tire.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Replacing 1 Tire With A Smaller Size, Temporarily? [Re: FordBroncoVWJeta] #5248428 10/23/19 08:07 PM
slacktide_bitog Online Content
Online Content
approved
Re: Replacing 1 Tire With A Smaller Size, Temporarily? [Re: Kevinmcc2] #5248547 10/23/19 11:12 PM
K
K
Walmart it is, didnt realize how cheap Wally World sold these for.. $44 bucks per.. Thanks all
Re: Replacing 1 Tire With A Smaller Size, Temporarily? [Re: Kevinmcc2] #5248594 10/24/19 04:14 AM
G
gfh77665 Online Content
Online Content
G
I once had a car with 4 different sizes on it. It was not as bad as it seems. All four tires were within one height and one width size. IIRC, they were 225, & 235, and 70 & 75 widths. The car drove and handled perfectly with this mis-matched set on it for the duration.
Keep in mind that even exactly same sized tires vary in height a bit, both when new from the factory, and then as tread wear occurs. In fact, when a tire is still usable but worn, it is likely more closer to the next size down. Most vehicles can easily tolerate small variances in tire height.
Re: Replacing 1 Tire With A Smaller Size, Temporarily? [Re: gfh77665] #5248605 10/24/19 05:01 AM
L
Linctex Offline
L
Been there, done that.
When you are young and short on cash, you do what you need to.
You won't win any autocross races, but.............
Re: Replacing 1 Tire With A Smaller Size, Temporarily? [Re: Kevinmcc2] #5248666 10/24/19 06:15 AM
M
Miller88 Offline
M
That's a temp solution that will end up being a permanent solution.
But it will work. People successfully drive a lot of miles on donut spares without issue.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Replacing 1 Tire With A Smaller Size, Temporarily? [Re: Kevinmcc2] #5248697 10/24/19 07:09 AM
JohnnyJohnson Offline
Temporarily is that a week, six months or when it causes you to wreck?
2004 Corolla 136904
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76703
Out: T6 5W-40 XG9100 73705
In: Rotella Dino PH9100 11-3-19
Re: Replacing 1 Tire With A Smaller Size, Temporarily? [Re: Kevinmcc2] #5248854 10/24/19 10:06 AM
G
GoldDot40 Offline
G
Running different sizes on axles that don't have gear boxes is one thing, but running them on axles that pull the vehicle is begging for problems....especially running different diameters on the front of a front wheel drive. Some vehicles may even attempt to engage traction control if equipped.
Same thing if running one short tire on the rear of a rear wheel drive. Might be OK with an open differential, but not with a clutch type locking unit.
Equal Opportunity Offender
