which weather site is most accurate?
by WhyMe - 11/16/19 11:25 PM
mopar coolant
by boombie10000 - 11/16/19 11:11 PM
2015 Honda CR-V loud engine noise
by FordBroncoVWJeta - 11/16/19 11:10 PM
Old Vise info
by A310 - 11/16/19 10:18 PM
2003 Ranger Radiator Replacement: Which Coolant?
by chucky2 - 11/16/19 08:55 PM
ATV axle removal
by supton - 11/16/19 07:45 PM
High speed chase
by P10crew - 11/16/19 07:28 PM
Oil for Daily Beater Camry
by Speak2Mountain - 11/16/19 07:18 PM
Green coolant, future availability ?
by rubberchicken - 11/16/19 06:11 PM
Weird tire wear
by ledslinger - 11/16/19 04:50 PM
Why does Ford resell lemons?
by avacado11 - 11/16/19 04:07 PM
Slow initial response to loading web pages
by JHZR2 - 11/16/19 04:06 PM
Motorcraft FL-910S
by PW01 - 11/16/19 03:54 PM
Walmart ammo clearance
by redbone3 - 11/16/19 03:35 PM
GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
Weird fuel leak
by BeerCan - 11/16/19 01:02 PM
billad67, aka_Claus, Diverdown, natas, matt3540
69886 Registered Users
64 registered members (Black_Thunder, bbhero, alarmguy, bilibako2, 2015_PSD, BlakeB, 4 invisible), 1,434 guests, and 17 spiders.
Topics297,524
Posts5,117,358
Members69,886
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
2018 crv.. 9k engine replacement #5248285 10/23/19 05:32 PM
Firehawk409 Offline OP
So our 2018 crv needed a new engine. They ordered a brand new short block from Honda. The dealer said they filled it with just synthetic oil.. Im assuming honda oil. So do engine replacements not get the ff "break in" oil everyone talks about?
1994 Pontiac Firehawk #409 LT1 M6 slow
2005 Pontiac GTO LS2 M6 slower
2006 Honda Civic I-VTAC slowest
Re: 2018 crv.. 9k engine replacement [Re: Firehawk409] #5248292 10/23/19 05:41 PM
JohnnyJohnson Offline
More Honda QC?
2004 Corolla 136904
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76703
Out: T6 5W-40 XG9100 73705
In: Rotella Dino PH9100 11-3-19
Re: 2018 crv.. 9k engine replacement [Re: Firehawk409] #5248295 10/23/19 05:42 PM
L
Leo99 Offline
L
If the original engine got the magic oil and only lasted a few miles, I wouldn't worry about the new engine not having it.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: 2018 crv.. 9k engine replacement [Re: JohnnyJohnson] #5248296 10/23/19 05:43 PM
Originally Posted by JohnnyJohnson
More Honda QC?
Eeh.. Whatever. They found an issue and fixed it quickly and without fuss. Im happy. Treated much better then GM has ever treat us.
Re: 2018 crv.. 9k engine replacement [Re: Leo99] #5248299 10/23/19 05:48 PM
The problem had nothing to do with the engine oil as far as I can see at this moment. We had a vtec solenoid go bad at 5k which caused the oil pressure to drop. Replaced solenoid but I told them my concern of the pressure drop. They said everything sounded fine.. No biggie for me. I got 8yrs/120k warranty. So 4k later the engine had a very slight knock noise.
Re: 2018 crv.. 9k engine replacement [Re: Firehawk409] #5248300 10/23/19 05:51 PM
P
paoester Online Content
Online Content
P
They do. Its the high moly assmbly lube that makes the factory fill oil "magic for break-in", so factory short blocks would have it. Use Toyota house brand 0w20 oil if you want to continue the magic high moly concentration effects in perpetuity.
2019 VW Tiguan S 4Motion, Pennzoil Platinum 0w-20, VW Mann oil filter
Re: 2018 crv.. 9k engine replacement [Re: Firehawk409] #5248309 10/23/19 05:59 PM
Bud Offline
I would say yes, but best bet would be to ask your service dept.
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: 2018 crv.. 9k engine replacement [Re: paoester] #5248310 10/23/19 06:01 PM
Thank you.... That's what I was thinking would be the case.
Re: 2018 crv.. 9k engine replacement [Re: Firehawk409] #5248311 10/23/19 06:02 PM
double vanos Offline
Agreed. No worries here, I suspect your replacement engine has some Honda specified assembly lube which is probably moly enriched. Even if the new engine was shipped dry, your dealer should have used a Honda spec’d oil.
Motor on....
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: 2018 crv.. 9k engine replacement [Re: Bud] #5248318 10/23/19 06:04 PM
I did.. Which is why I posted here. Service manager said all they do is fill it with synthetic oil that they use for oil changes and no one ever asked him that question before. He said he would talk to his parts guy tomorrow about it to see if it's something they could order.
Re: 2018 crv.. 9k engine replacement [Re: paoester] #5248358 10/23/19 06:53 PM
H
hallstevenson Offline
H
Yeap, they will fill engines at the factory with the same engine oil that we buy, just that they get in larger packaging (probably totes).
Re: 2018 crv.. 9k engine replacement [Re: Firehawk409] #5248359 10/23/19 06:54 PM
super20dan Offline
honda isn't a Toyota
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: 2018 crv.. 9k engine replacement [Re: Bud] #5248393 10/23/19 07:31 PM
M
Mainia Offline
M
10% chance you will get a knowledgeable answer to that question. 30 years ago you would have a 70% to get
a knowledgeable answer.
Re: 2018 crv.. 9k engine replacement [Re: Firehawk409] #5248401 10/23/19 07:43 PM
splinter Offline
An '18? Seems whatever recipe that was baked in previously cooked up a little too ripe.
Upside is its replacement will also be covered under warranty. Honda Motor Company ftw,
PUP 0W-40
Total Quartz 5W-40
M1 5W-50
Past performance is no guarantee of future results.
Re: 2018 crv.. 9k engine replacement [Re: splinter] #5248404 10/23/19 07:47 PM
Go back a few replies. I explained why I think it happened.
Page 1 of 3 1 2 3
