2003 Ranger Radiator Replacement: Which Coolant?
by chucky2 - 11/16/19 08:55 PM
ATV axle removal
by supton - 11/16/19 07:45 PM
High speed chase
by P10crew - 11/16/19 07:28 PM
Oil for Daily Beater Camry
by Speak2Mountain - 11/16/19 07:18 PM
Green coolant, future availability ?
by rubberchicken - 11/16/19 06:11 PM
Weird tire wear
by ledslinger - 11/16/19 04:50 PM
Why does Ford resell lemons?
by avacado11 - 11/16/19 04:07 PM
Slow initial response to loading web pages
by JHZR2 - 11/16/19 04:06 PM
Motorcraft FL-910S
by PW01 - 11/16/19 03:54 PM
Walmart ammo clearance
by redbone3 - 11/16/19 03:35 PM
GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
Weird fuel leak
by BeerCan - 11/16/19 01:02 PM
Sinopec 75w-90 Synthetic
by jdw1222 - 11/16/19 12:51 PM
Honda Oil Filter
by miden851 - 11/16/19 12:28 PM
VOA for QSAD 10w-40?
by natas - 11/16/19 12:02 PM
Ford v Ferrari - anyone seen the movie yet?
by Oro_O - 11/16/19 12:01 PM
billad67, aka_Claus, Diverdown, natas, matt3540
69886 Registered Users
92 registered members (ammolab, A310, Astro14, 2010Civic, Aichiguy, 9 invisible), 1,720 guests, and 25 spiders.
Topics297,520
Posts5,117,321
Members69,886
Most Online3,589
Nov 2nd, 2019
2003 BMW E46 M3 Rotella 15w40 #5248092 10/23/19 01:10 PM
M
Manners226 Offline OP
M
I have done lots of reading on here regarding the TWS recommended for the M3s and M5s. I just want some opinions on running Shell Rotella T4 15w40 in the S54. The car sees cold starts normally anywhere from 40-80 degree F weather. It is a day to day driver and it doesn't get pushed hard when oil temps are low, if ever. 6 speed manual. I am wanting to run a quality conventional oil in the car for a few OCIs. I have always liked this oil and I have lots of it on hand. I understand that not running 1060 in these cars is treason. I get that. Any educated opinions? Bear in mind this car has 200k miles on it, has had the rod bearings replaced and I have $4 grand in it. Thanks for the input.
2006 Chevrolet Corvette LS2
2003 BMW E46 M3 S54
2014 Toyota Tundra 4.6L
2007 Suzuki GSXR 600
Re: 2003 BMW E46 M3 Rotella 15w40 [Re: Manners226] #5248096 10/23/19 01:13 PM
B
BMWTurboDzl Offline
B
Sweet car. IJS.
435i
Re: 2003 BMW E46 M3 Rotella 15w40 [Re: Manners226] #5248152 10/23/19 02:35 PM
rooflessVW Offline
Many have switch or are switching to LL01 0W-40 in the S54 and beyond.
I think a dual-rated 15W-40 kept to a reasonable change interval would be more than adequate.
"Zed's dead baby, Zed's dead."
Re: 2003 BMW E46 M3 Rotella 15w40 [Re: Manners226] #5248236 10/23/19 04:44 PM
A
Audios Offline
A
You should be fine for a reasonable interval. The 10/60 was more of a bandaid at the beginning until the figured out the rod bearing issue. The 10/60 shears down a bit as well, so the weights wont be far off.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: 2003 BMW E46 M3 Rotella 15w40 [Re: Manners226] #5248572 10/24/19 02:09 AM
T
TrueTriumph Offline
T
My concerns are on the 15W - I would not advise using this heavy stuff.
Problem is, that on start-up the engine needs fastest possible lubrication. The sucking nozzle in the oil sump drains out with the engine shut off. A 15W oil will take too much time to be sucked up and then spread throughout the engine. Those machines die on starting not on revving - why a 0W40 works perfectly well unless use is race-like with permanent revs above the 6000-mark and temps well above 270°F permanently. In this case a 5W50 is more adequate.
Markus
running his S54 on 5W40 Motul 300 V series with no issues at all
Re: 2003 BMW E46 M3 Rotella 15w40 [Re: TrueTriumph] #5248826 10/24/19 09:23 AM
E
edyvw Offline
E
Markus
AT 40-60 degrees f he will not have issue with 15W. But I would agree that Motul would be better option, or Mobil1 5W50.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: 2003 BMW E46 M3 Rotella 15w40 [Re: edyvw] #5248913 10/24/19 11:28 AM
K
kschachn Offline
K
Yeah more of the rampant misunderstanding of what winter ratings mean.
1994 BMW 530i, 250K
1996 Honda Accord, 280K
1999 Toyota Sienna, 425K
2000 Toyota ECHO, 284K
Re: 2003 BMW E46 M3 Rotella 15w40 [Re: Manners226] #5249558 10/25/19 06:41 AM
M
M
Thanks guys. It has performed well thus far. About 300 miles in. I plan on using the Shell for 5 3k mile OCIs to help naturally clean the engine a bit. Temps and pressure seem great so far.
2003 BMW E46 M3 S54
