"Medallion ATF" for Toyota WS
by TmanP - 11/15/19 01:37 PM
Ford Mustang Mach-E
by SlavaB - 11/15/19 01:26 PM
2005 Ford Taurus Fram Cabin Filter
by Snagglefoot - 11/15/19 12:15 PM
Is 10 microns concidered a bypass filter?
by jkhawaii - 11/15/19 12:09 PM
2018 Charger Hellcat 12,000 mile update
by mbacfp - 11/15/19 11:51 AM
Automotive Oscilloscope
by LazyDog - 11/15/19 11:42 AM
Let’s see how this looks after 4 seasons
by Bettez88 - 11/15/19 11:04 AM
Interstate batteries problems
by JimPghPA - 11/15/19 09:49 AM
2008 Dodge Ram 3500, first sample
by A_Harman - 11/15/19 09:44 AM
Steelers/Browns
by CourierDriver - 11/15/19 09:04 AM
Beard care in cold weather?
by pandus13 - 11/15/19 08:39 AM
Door Sill protection for new car - which one?
by henni - 11/15/19 08:18 AM
Exterior Home Security Cameras?
by Gebo - 11/15/19 08:13 AM
5w-20 ok for GMC 6.2l ?
by jdw1222 - 11/15/19 08:02 AM
M. Defender vs Cont. TrueContact Tour?
by lukejo - 11/15/19 07:53 AM
Alternative for Lexus Toyota WS
by Joephu - 11/15/19 06:19 AM
F1 - 2019 Brazilian Grand Prix
by gofast182 - 11/15/19 06:10 AM
2019 i30 Nline 1.6T and first service (1500km)
by rov137 - 11/14/19 10:11 PM
Garbage Disposal Replacement
by bunnspecial - 11/14/19 09:58 PM
Nest thermostat
by miden851 - 11/14/19 09:06 PM
DjS71, Akhunter, rov137, Dorisy, DesktopDave
69870 Registered Users
100 registered members (28oz, Anduril, 928, 14Accent, 2015_PSD, 13 invisible), 2,118 guests, and 34 spiders.
Topics297,445
Posts5,115,944
Members69,870
Most Online3,589
Nov 2nd, 2019
Motorkote, Amsoil test says it has lots of chlorine #5247725 10/23/19 04:53 AM
sdowney717 Offline OP
https://thebestsyntheticoil.com/pdf/TSB%20MO-2010-04-01_chlorine_oil_treatments.pdf
I was very interested in Motorkote, you will find videos like Project Farm showing a treated lawnmower engine ran for an hour without a failure when oil was drained and water filled crankcase.
But this chlorine can mix with water and from hydrochloric acid, so it soured me. I was all set to put some in a car I have. I could have gotten maybe 1-2 additional mpg. I had even been thinking of using it in my common rail diesel Ram.
Sure your going to find it works, but how long before it may dissolve a metallic surface by corrosion. I dont think its worth the risk. According to some videos, it causes an engine to run extremely smoothly and well, so I wonder if some have used it to help sell their car.
Re: Motorkote, Amsoil test says it has lots of chlorine [Re: sdowney717] #5247814 10/23/19 07:23 AM
CT8 Offline
How could you have gotten the maybe Mpg increase?
Re: Motorkote, Amsoil test says it has lots of chlorine [Re: sdowney717] #5247898 10/23/19 09:08 AM
PimTac Offline
Probably those “springy oil additives”. Like tiny rubber balls.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Motorkote, Amsoil test says it has lots of chlorine [Re: sdowney717] #5247951 10/23/19 10:22 AM
M
Mad_Hatter Offline
M
Never used it before and don't have any plans to but I coulda swore someone on the board claimed to have corresponded w/Motorkote and they (MK) claimed that they weren't using chlorinated paraffins [anymore]???
For whatever that's worth...
Re: Motorkote, Amsoil test says it has lots of chlorine [Re: sdowney717] #5248051 10/23/19 12:26 PM
Since it lowers friction, it must improve the mpg. I have read people says they gained from 1 to 3 mpg.
But if it does this safely then why are the car companies not using it to improve their fleet mpg, that tells me something about it is a problem.
https://pubs.lubesngreases.com/news/About-Face-EPA-Permits-Chlorinated-Paraffins-12147-1.html
Chlorinated paraffins are chlorinated alkanes that have carbon chain lengths ranging from 10 to 38, with varying degrees of chlorination. Those with lengths from C14 to C17 are classed as medium chain; from C18 to C20 as long chain; and C21 and higher as very long-chain. CPs are used in metalworking fluids as extreme-pressure agents, especially for difficult drawing, forming and removal operations.
Re: Motorkote, Amsoil test says it has lots of chlorine [Re: sdowney717] #5262661 11/09/19 04:18 PM
dave1251 Offline
The only way motorkote lowers friction is comparing it to an engine with no motor oil.
don't use.
Re: Motorkote, Amsoil test says it has lots of chlorine [Re: sdowney717] #5262711 11/09/19 05:25 PM
J
Jetsfan421 Offline
J
Due to the corrosive nature of chlorinated paraffin byproducts they serve absolutely no purpose in any motor oil. You may see a short period of increased gas mileage due to reduced friction, but the hydrochloric acid formed from combustion would wreck havoc inside the engine. These are what give additives a bad name.
