BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
101 registered members (4WD, 77GrandPrix, Anduril, ABN_CBT_ENGR, amblerman, 8 invisible), 2,051 guests, and 70 spiders.
Topics306,134
Posts5,288,099
Members71,604
What bearing grease for off road vehicle? #5247249 10/22/19 04:19 PM
E
Enigma Offline OP
E
I have a 2019 Can Am Maverick X3 side by side off road vehicle (similar to a Polaris RZR) I purchased some grease to service the wheel bearings. I mainly ride in the desert and sand. I will get some mud and snow from time to time as the normal packed down dirt trails get a bit muddy with rain. The owners manual does not mention grease specifications.
I purchased this product.
https://www.amazon.com/gp/product/B000CQ4DK0/ref=ppx_yo_dt_b_asin_title_o09_s03?ie=UTF8&psc=1
Is this a good choice or would you recommend something else?
06 Duramax CCSB 2500 HD
Re: What bearing grease for off road vehicle? [Re: Enigma] #5247263 10/22/19 04:31 PM
Yah-Tah-Hey Offline
That will work as good as any other #2 Lithium grease. Common application.
Re: What bearing grease for off road vehicle? [Re: Enigma] #5247267 10/22/19 04:33 PM
justintendo Offline
i have used belray waterproof grease for years in my dirtbikes..holds up great in off road conditions. wheel bearing, swingarms, linkages, pivots, steering heads, and dabs on my clutch and brake levers..
13 escape 2.0 awd mobil 1 10w30ep
08 fusion 2.3 mtx mobil 1 5w30ep/redline mt90
96 f150 4.9 2wd mtx mobil 1 10w30hm/redline ps fluid
99 kaw zrx 1100 redline 10w40
many husqvarnas 5w40 t6 rotella
Re: What bearing grease for off road vehicle? [Re: Enigma] #5247284 10/22/19 04:44 PM
K
krismoriah72 Offline
K
I have 1500 miles on my 2019 RZR Turbo after greasing with Mystik #2 when i first bought it.. I chose Mystik because of the excellent washout resistance.. i grease my sway bar with it also.. cant even spray it off with a pressure washer. Plus its like $4 a tube. I ride tons of creeks and streams and nasty mud..
That one you bought is rated GC so its good for wheel bearings. Not sure how good it is for washout. But looks like thats not an issue for your riding.
Just dont overdo it, like where you push past the seals. And make sure you torque the castle nut back to specs and no worries.
Re: What bearing grease for off road vehicle? [Re: Enigma] #5247321 10/22/19 05:25 PM
U
userfriendly Offline
U
The price is higher than I would pay for a comparable product. A #2 GCLB is the correct grade and specification. I use #1 GCLB in the great white north year round.
Some "synthetic" grease such a Pet-Can Gold is listed as a 1.5
Re: What bearing grease for off road vehicle? [Re: Enigma] #5247328 10/22/19 05:34 PM
Chris142 Offline
Make sure to grease the shock pivots. Ours as well as my friends Poolaris ones were installed dry from the factory.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: What bearing grease for off road vehicle? [Re: Enigma] #5260311 11/06/19 10:20 PM
SteveG4 Offline
I am not a shill for Lucas, but I do like this product: Lucas X-TRA Heavy Duty Grease
https://www.amazon.com/Lucas-Oil-Ounce-10301-Grease/dp/B000IG20RW/ref=sr_1_3?crid=411G0EWG5WQB&keywords=lucas+x-tra+heavy+duty+grease&qid=1573097331&sprefix=Lucase+X-tra+%2Caps%2C209&sr=8-3
It has an excellent 4.4 star rating on Amazon (430 ratings today) and the price is right.
My Prime price is $4.98 for a 14.5 oz tube.
And, I've never had it separate in a grease gun as well... I rate it highly.
Somewhere between Alaska and Wisconsin...
2006 4WD Silverado LT Crew Cab & 2013 AWD Equinox
