Pay Raise
by KeithS_NW_Ohio - 12/11/19 09:17 PM
75 registered members (Ag76, Astro14, Artem, adams355, 2strokeNorthstar, 4WD, 5 invisible),
1,264
guests, and 29
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,605
Posts5,139,007
Members70,106
Most Online3,589 Nov 2nd, 2019
Another battery test results question
#5247090
10/22/19 12:47 PM
Quattro Pete
OP
OP
Posts: 38,295 |
Using the HF/CenTech Digital Battery Analyzer, I get a test reading of 588 CCA on a 5-year old EverStart MAXX H8 900 CCA rated battery at 50F ambient temp.
On one hand, I don't want to unnecessarily buy a new battery, but on the other hand I don't want to get stranded in the middle of winter. The car is parked outside.
Replace it?
✰ 2002 530i ✰ 2015 Q5 3.0T ✰ 2018 Charger SRT
Re: Another battery test results question
[Re: Quattro Pete]
#5247104
10/22/19 01:00 PM
Donald
Posts: 23,261 |
Get it tested at a place with a Midtronics that does temp compensation. But I think you are borderline. Given where you live I would go for a new battery. 5 years from a Walmart battery is not bad.
Changing a battery in the middle of a cold spell where the wrenches freeze to your hands is not fun.
If wife's car then definitely.
2015 Subaru Forester 2.5 engine/CVT 2015 Ford F250 w/Powerstroke 2016 Subaru Crosstrek CVT (wife's)
[Re: Quattro Pete]
#5247105
10/22/19 01:00 PM
bullwinkle
Posts: 9,707 |
Depends on how hard it is to start-my xB will start fine on only 300 CCA, even in winter. But, the IDI diesels in my sig need 2 850 CCA batteries, testing at 700 CCA or above, to start in the same conditions.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
[Re: Quattro Pete]
#5247108
10/22/19 01:02 PM
Fawteen
Posts: 544 |
Personally I err on the side of caution with a battery. If there was the slightest question about its viability I wouldn't hesitate to replace it. Especially living in a cold/snow environment.
[Re: Quattro Pete]
#5247126
10/22/19 01:27 PM
eljefino
Posts: 34,994 |
Midtronics says 50% of original CCA replace, 60% consider it. By that logic, you're still good.
[Re: eljefino]
#5247129
10/22/19 01:30 PM
Quattro Pete
OP
OP
Posts: 38,295 |
Midtronics says 50% of original CCA replace, 60% consider it. By that logic, you're still good. Right, but Midtronics compensates for ambient temp. If I ran my test at 0F, I'm sure my CCA reading would be a lot lower.
[Re: Quattro Pete]
#5247135
10/22/19 01:44 PM
Gimpy1
Posts: 243 |
5 years is a long time for a battery that sits in your vehicle engine compartment which is a very hostile environment. If it where me I would go ahead and get a new battery while the weather is decent. How much does a new battery cost? Look at it this way if and when the battery fails how much will it cost to replace and how much time are you going to lose try to get your vehicle running in the middle of the night when its below freezing or first thing in the morning when your car won't start and you have to get to work. There is a reason why replacing a battery is preventative maintenance.
[Re: Gimpy1]
#5247153
10/22/19 01:59 PM
Quattro Pete
OP
OP
Posts: 38,295 |
5 years is a long time for a battery that sits in your vehicle engine compartment which is a very hostile environment. The batteries on all three of the cars in my sig sit in the trunk. My previous battery lasted 6 years, so this one is definitely getting there. If it where me I would go ahead and get a new battery while the weather is decent. How much does a new battery cost? About $150, give or take. Look at it this way if and when the battery fails how much will it cost to replace and how much time are you going to lose try to get your vehicle running in the middle of the night when its below freezing or first thing in the morning when your car won't start and you have to get to work. I mainly use this car to drop my kid off at daycare in the morning. Theoretically, if it doesn't start, I could take my wife's car, which is garaged. Sometimes I do that if I don't feel like shoveling snow/deicing my car.  I could buy one of those jump start li-ion pack gizmos, but I think I'd rather just put the money toward a new battery.
[Re: Quattro Pete]
#5247245
10/22/19 03:14 PM
Gebo
Posts: 3,615 |
Since it's coming up on winter, I'd replace it. If it was in my wife or daughter's car, I'd replace it asap .
Something I have been doing with very good success is buying my replacement batteries at the dealership. Great pricing and great warranty.
The only thing "my" dealerships can't compete on is tires.
'98 LEX LS400 300K '02 4Runner 245K '05 Lex LS430 85K '07 Lex GX470 65K
Shell Gas and Truck & Pennzoil Full Syn HM Toyota ATF's and Coolant Amsoil Gear Oil and Grease
[Re: Quattro Pete]
#5247276
10/22/19 03:38 PM
Donald
Posts: 23,261 |
Midtronics says 50% of original CCA replace, 60% consider it. By that logic, you're still good. Right, but Midtronics compensates for ambient temp. If I ran my test at 0F, I'm sure my CCA reading would be a lot lower. Midtronics I thought compensated using actual battery temp.
[Re: Quattro Pete]
#5247376
10/22/19 05:18 PM
bbhero
Posts: 7,211 |
Midtronics says 50% of original CCA replace, 60% consider it. By that logic, you're still good. Right, but Midtronics compensates for ambient temp. If I ran my test at 0F, I'm sure my CCA reading would be a lot lower. Yeah.. I agree Quattro... Really good point. I agree with Donald. I would replace it given your location.
Nissan Altima 3.5 Coupe Napa full synthetic 5w30 Wix 57356 Oil filter "Treat your family like your friends and treat your friends like your family."
[Re: Donald]
#5247380
10/22/19 05:22 PM
bbhero
Posts: 7,211 |
Midtronics says 50% of original CCA replace, 60% consider it. By that logic, you're still good. Right, but Midtronics compensates for ambient temp. If I ran my test at 0F, I'm sure my CCA reading would be a lot lower. Midtronics I thought compensated using actual battery temp. Only thing about that Donald... Can it "really" replicate temperature at 0 degrees Fahrenheit??? I just would not totally trust that... Would that hand held computation device actually replicate -20°F accurately too ?? Again I just would not trust it...
[Re: Quattro Pete]
#5247508
10/22/19 07:10 PM
bubbatime
Posts: 6,520 |
Seems like being stuck in 0 degree weather could be bad for your health.
I know what I would do. Id change it.
2019 Honda CRV 1.5T factory bulk 2017 Chrysler Pacifica SuperTech synthetic 5W20 2013 Yamaha XT250 Valvoline motorcycle 10W40 2006 GMC Sierra SuperTech high mileage 5W30
[Re: Quattro Pete]
#5248439
10/23/19 08:16 PM
JHZR2
Global Moderator
Global Moderator
Posts: 43,390 |
588A is more than the car cranks more than likely...
588A x 9V = 5292W. Doubt your starter is more than 1.2-1.7kW.
Condemnation is usually 20% capacity loss or doubling of impedance. What’s the impedance value?
[Re: JHZR2]
#5248677
10/24/19 06:31 AM
Quattro Pete
OP
OP
Posts: 38,295 |
What’s the impedance value? 4.5 mOhm. Another thing I forgot to mention, I've had issues with this battery since last year, unable to accept full charge. I suspect it's heavily sulfated. At this point, I'm leaning toward just getting a new battery.
