2019 i30 Nline 1.6T and first service (1500km)
by rov137 - 11/14/19 10:11 PM
Garbage Disposal Replacement
by bunnspecial - 11/14/19 09:58 PM
Nest thermostat
by miden851 - 11/14/19 09:06 PM
2011 G37X
by maverickfhs - 11/14/19 08:27 PM
Recommendations for oil filter
by dawgn86 - 11/14/19 07:38 PM
2001 Subaru Outback $2,300 OBO
by 14Accent - 11/14/19 07:16 PM
Brake Friction Code List
by 92saturnsl2 - 11/14/19 07:14 PM
Accord reached a milestone today!
by mclasser - 11/14/19 06:59 PM
Is an alignment absolutely needed after new tires?
by SouthDakotaDad - 11/14/19 06:11 PM
Redline Professional Series 5w20
by burla - 11/14/19 06:00 PM
Backup Camera
by George7941 - 11/14/19 05:26 PM
'11 Prius 15k OCI Amsoil 0W-20
by mdv - 11/14/19 05:16 PM
Lightweight easy up
by Redright9 - 11/14/19 05:00 PM
Thinking of getting a cat
by 53' Stude - 11/14/19 04:42 PM
Apple Watch users
by madRiver - 11/14/19 03:05 PM
It's here, arrived early still 1 week to wait
by BeerCan - 11/14/19 02:20 PM
Cooling leaks at hose to housing connections
by Fitz98 - 11/14/19 12:53 PM
Mercedes coolant mixed
by Rohan - 11/14/19 12:49 PM
rov137, Dorisy, DesktopDave, HPD, kildeth
69868 Registered Users
77 registered members (aquariuscsm, 2010Civic, atikovi, 14Accent, AZjeff, 7 invisible), 1,628 guests, and 36 spiders.
Topics297,430
Posts5,115,444
Members69,868
Most Online3,589
Nov 2nd, 2019
Another battery test results question #5247090 10/22/19 12:47 PM
Q
Quattro Pete Offline OP
Q
Using the HF/CenTech Digital Battery Analyzer, I get a test reading of 588 CCA on a 5-year old EverStart MAXX H8 900 CCA rated battery at 50F ambient temp.
On one hand, I don't want to unnecessarily buy a new battery, but on the other hand I don't want to get stranded in the middle of winter. The car is parked outside.
Replace it?
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Another battery test results question [Re: Quattro Pete] #5247104 10/22/19 01:00 PM
Donald Offline
Get it tested at a place with a Midtronics that does temp compensation. But I think you are borderline. Given where you live I would go for a new battery. 5 years from a Walmart battery is not bad.
Changing a battery in the middle of a cold spell where the wrenches freeze to your hands is not fun.
If wife's car then definitely.
2015 Ford F250 w/Powerstroke
Re: Another battery test results question [Re: Quattro Pete] #5247105 10/22/19 01:00 PM
B
bullwinkle Offline
B
Depends on how hard it is to start-my xB will start fine on only 300 CCA, even in winter. But, the IDI diesels in my sig need 2 850 CCA batteries, testing at 700 CCA or above, to start in the same conditions.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Another battery test results question [Re: Quattro Pete] #5247108 10/22/19 01:02 PM
F
Fawteen Offline
F
Personally I err on the side of caution with a battery. If there was the slightest question about its viability I wouldn't hesitate to replace it. Especially living in a cold/snow environment.
2014 Silverado
2014 Equinox
1972 Olds 442 Convertible
1918 Model T
Re: Another battery test results question [Re: Quattro Pete] #5247126 10/22/19 01:27 PM
E
eljefino Offline
E
Midtronics says 50% of original CCA replace, 60% consider it. By that logic, you're still good.
Re: Another battery test results question [Re: eljefino] #5247129 10/22/19 01:30 PM
Q
Q
Right, but Midtronics compensates for ambient temp. If I ran my test at 0F, I'm sure my CCA reading would be a lot lower.
Re: Another battery test results question [Re: Quattro Pete] #5247135 10/22/19 01:44 PM
G
Gimpy1 Offline
G
5 years is a long time for a battery that sits in your vehicle engine compartment which is a very hostile environment. If it where me I would go ahead and get a new battery while the weather is decent. How much does a new battery cost? Look at it this way if and when the battery fails how much will it cost to replace and how much time are you going to lose try to get your vehicle running in the middle of the night when its below freezing or first thing in the morning when your car won't start and you have to get to work. There is a reason why replacing a battery is preventative maintenance.
Re: Another battery test results question [Re: Gimpy1] #5247153 10/22/19 01:59 PM
Q
Q
The batteries on all three of the cars in my sig sit in the trunk.
My previous battery lasted 6 years, so this one is definitely getting there.
Quote
About $150, give or take.
Quote
I mainly use this car to drop my kid off at daycare in the morning. Theoretically, if it doesn't start, I could take my wife's car, which is garaged. Sometimes I do that if I don't feel like shoveling snow/deicing my car. smile
I could buy one of those jump start li-ion pack gizmos, but I think I'd rather just put the money toward a new battery.
Re: Another battery test results question [Re: Quattro Pete] #5247245 10/22/19 03:14 PM
G
Gebo Offline
G
Since it's coming up on winter, I'd replace it. If it was in my wife or daughter's car, I'd replace it asap .
Something I have been doing with very good success is buying my replacement batteries at the dealership. Great pricing and great warranty.
The only thing "my" dealerships can't compete on is tires.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Supertech Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Another battery test results question [Re: Quattro Pete] #5247276 10/22/19 03:38 PM
Donald Offline
Midtronics I thought compensated using actual battery temp.
Re: Another battery test results question [Re: Quattro Pete] #5247376 10/22/19 05:18 PM
B
bbhero Offline
B
Yeah.. I agree Quattro... Really good point.
I agree with Donald. I would replace it given your location.
Nissan Altima 3.5 Coupe
Cam2 Dexos1 Gen 2 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Another battery test results question [Re: Donald] #5247380 10/22/19 05:22 PM
B
bbhero Offline
B
Only thing about that Donald... Can it "really" replicate temperature at 0 degrees Fahrenheit???
I just would not totally trust that... Would that hand held computation device actually replicate -20°F accurately too ?? Again I just would not trust it...
Re: Another battery test results question [Re: Quattro Pete] #5247508 10/22/19 07:10 PM
B
bubbatime Offline
B
Seems like being stuck in 0 degree weather could be bad for your health.
I know what I would do. Id change it.
2019 Honda CRV 1.5T factory bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: Another battery test results question [Re: Quattro Pete] #5248439 10/23/19 08:16 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
588A is more than the car cranks more than likely...
588A x 9V = 5292W. Doubt your starter is more than 1.2-1.7kW.
Condemnation is usually 20% capacity loss or doubling of impedance. What’s the impedance value?
Re: Another battery test results question [Re: JHZR2] #5248677 10/24/19 06:31 AM
Q
Q
4.5 mOhm.
Another thing I forgot to mention, I've had issues with this battery since last year, unable to accept full charge. I suspect it's heavily sulfated. At this point, I'm leaning toward just getting a new battery.
