Quickjack BL-7000EXT
by The Critic - 11/18/19 08:27 PM
'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Looking for a soft riding car
by Nayov - 11/18/19 04:00 PM
Do you use one filter brand or many?
by wemay - 11/18/19 02:43 PM
ATV engine oil
by supton - 11/18/19 02:02 PM
10w30 HDEO or 15w40, others. What's in your engine?
by 53' Stude - 11/18/19 01:47 PM
GM dealer oil change: Who makes their oil?
by Benzadmiral - 11/18/19 01:45 PM
Don't Fix Your Car!
by Y_K - 11/18/19 01:18 PM
best LL01 oil (for F10 M5/S63Tu)?
by vafan13 - 11/18/19 12:55 PM
Stripped oil pan
by dosmom - 11/18/19 12:35 PM
spiffy63, WhiteMega1227, ak2az, vafan13, Breezeknees
69908 Registered Users
126 registered members (Astro14, 01rangerxl, 14Accent, 4WD, 92saturnsl2, AndyB, 10 invisible), 1,967 guests, and 18 spiders.
Topics297,608
Posts5,119,102
Members69,908
Most Online3,589
Nov 2nd, 2019
Oil consuming 2004 Mercury Marauder #5246939 10/22/19 10:09 AM
2
2013ecof150 Offline OP
2
I recently bought a 2004 Marauder, one owner with 80k miles. It seems to be using oil about 1 quart every 2500 miles. The last oil I used was Mobil 1 5w20 high mileage. No leaks that I can see anywhere. I was thinking of going a bit thicker to either
Mobil 1 10w30 or 10w40 high mileage to see if I can slow it down a bit.
I also have access ( for free) of Delcac 1300 15w40 or Rotella T 5w40 but I see that these aren’t rated for gas engines anymore. I live in Northern Va, it gets cold but nothing crazy.
What would you use ?
Re: Oil consuming 2004 Mercury Marauder [Re: 2013ecof150] #5246944 10/22/19 10:21 AM
N
NO2 Offline
N
Change the PCV valve first.
Re: Oil consuming 2004 Mercury Marauder [Re: NO2] #5246969 10/22/19 10:45 AM
2
2
I should have mentioned when I first got the car I changed all the fluids and filters including the pcv valve. The old one wasn’t gummed up and still rattled just fine.
Re: Oil consuming 2004 Mercury Marauder [Re: 2013ecof150] #5246971 10/22/19 10:48 AM
69GTX Offline
I'd use the 5w-30 high mileage semi-synthetic or a conventional oil like PYB. Even 10w-30 since your climate is moderate. I'd stay away from the synthetic and see how it goes.
Had a similar issue with my 4.6L DOHC 2002 Lincoln engine around 10 yrs ago. I went with what was on the oil cap, 5w-20. It only had 25K miles and was going through about a quart of Formula Shell 5w-20 every OCI. I then switched to conventional 5w-20 and the consumption dropped a bit. Eventually I found out this engine was designed on 5w-30 and only CAFE requirements put it on 5w-20. Ever since then I've been using 5/10w-30 in my V8 Fords/Lincolns with only minimal oil usage. Your engine will get every bit (or more) protection with the 5w-30. However, you might see a decrease in mileage of 0.0043% if you could even measure it in a controlled double-blind test.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Oil consuming 2004 Mercury Marauder [Re: 2013ecof150] #5246975 10/22/19 10:53 AM
Z
ZZman Offline
Z
Try a 5w-30. And 2500 miles isn't that bad.
2007 Hyundai Santa Fe AWD.
2005 Toyota Avalon XLS
Re: Oil consuming 2004 Mercury Marauder [Re: 69GTX] #5246984 10/22/19 11:04 AM
2
2
Yeah I figured the 5w20 was a fuel economy thing. The only reason I wanted to stay with synthetic was because someone actually engraved the words “ FULL SYNTHETIC “ on the valve cover next to the oil cap.
But I’m not opposed to trying a conventional or a blend either.
I’m only about 3000 miles into the oil change and at 2500 miles I dumped in a quart of regular 5w20 Mobil 1 because I didn’t have any of the high mileage oil left.
Is the 5w40 rotella a bad idea? Will it really poison the cats?
What about a 10w40 high mileage?
Re: Oil consuming 2004 Mercury Marauder [Re: 2013ecof150] #5247002 10/22/19 11:26 AM
H
Hoot_r Offline
H
Consider QSUD 5w30 -- on the thicker side of a 30wt with a pretty stout add pack.
2020 Kia Soul LX, 2.0L Atkinson-cycle I-4 (Nu)
Castrol Magnatec FS 5W30, OEM Filter
Re: Oil consuming 2004 Mercury Marauder [Re: 2013ecof150] #5247024 10/22/19 11:41 AM
B
benjy Offline
B
thinner xxw20 oils are for a very slight mpg increase to meet government standards + NOT better for ANY other reason. in warmer areas a 10-30 is better or a 5-30 for colder areas.
Re: Oil consuming 2004 Mercury Marauder [Re: 2013ecof150] #5247043 10/22/19 12:08 PM
1
14Accent Online Content
Online Content
1
My '03 Marauder burned ~ 1/2 QT per 5k mile OCI. That was at 225k miles. I ran Amsoil OE 5w30 for the entire 50k I had the car.
I would just run a good 5w30 and work the engine HARD. Mine saw redline multiple times daily and loved it. These are tough cars and you can really enjoy them.
Also, WE NEED PICS! Marauder's are getting more rare by the day.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Oil consuming 2004 Mercury Marauder [Re: 2013ecof150] #5247055 10/22/19 12:18 PM
A
andyd Offline
A
Use whatever you see fit. BUT make part or all of the last qt MMO. You are after some gentle ring cleaning. If you get a blue cloud evry cold start, it likely needs valve seals. In days of yore 302s,etc were notorious for the valve seals breaking up and jamming the oil pump drive grin2
Thick oil is better grin2
Re: Oil consuming 2004 Mercury Marauder [Re: 14Accent] #5247080 10/22/19 12:39 PM
2
2
Oh trust me I floor the heck out of it! Anyone who is familiar with NOVA traffic knows how hard it is to find open space to safely take your car out and stretch its legs!
I bought the car May 1st of this year. I think I’ve only seen 2 of them on the road in the last 5 and a half months. You just simply don’t see them all that often.
I can take some pics but I have absolutely no idea how to post them on this site frown I could take them and send them to someone.
Re: Oil consuming 2004 Mercury Marauder [Re: 2013ecof150] #5247107 10/22/19 01:01 PM
69GTX Offline
Photos are easy. If you can store a photo on your computer's Picture Library or have them as a file on your IPhone....you can get them here with a couple clicks.
There's an attach file link via the "picture uploader" on the bottom left corner of the page. Click on that and it will then ask you where to go to select a file. Go to your computer's pictures. Click on that picture or "open" it. It then gets linked to your post. Click "done."
1969 Ply GTX/RRs
Re: Oil consuming 2004 Mercury Marauder [Re: 2013ecof150] #5247481 10/22/19 06:42 PM
A
Anduril Offline
A
My Mustang had the 2 valve version of that motor and needed valve seals at the end of last year. Was burning a quart of 5w-40 every 1k or less, after change them it has no.l noticeable consumption with 5w-20.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: Oil consuming 2004 Mercury Marauder [Re: 2013ecof150] #5247539 10/22/19 07:47 PM
super20dan Offline
that engine isn't desighned for 20w oil . cars from this era use 10w 30
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: Oil consuming 2004 Mercury Marauder [Re: 14Accent] #5248210 10/23/19 04:04 PM
2
2
Also, WE NEED PICS! Marauder's are getting more rare by the day.[/quote]
Here are a few pics of the car. Good from far but far from good. But I enjoy driving it. Flew out to Indianapolis and drove it back to VA. Totally stock other than a 93 octane custom tune.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
