2001 Toyota Sequoia
by Tlhfirelion - 11/14/19 11:02 AM
Creation date
by Duffyjr - 11/14/19 10:36 AM
Rescuing a critically sluged 6.4 F-350
by NDServices - 11/14/19 10:02 AM
New Fram boxes
by FordBroncoVWJeta - 11/14/19 10:00 AM
My dad bought a 2017 F150.
by dan_erickson - 11/14/19 09:52 AM
You ever spray paint inside the house?
by atikovi - 11/14/19 09:48 AM
recent experience with Adv Auto
by windeye - 11/14/19 08:59 AM
Lifted Trucks
by Passport1 - 11/14/19 08:56 AM
Fleet oil intervals to save money?
by Todd00000 - 11/14/19 08:44 AM
Motive power brake bleeder
by Redright9 - 11/14/19 08:25 AM
*GRAPHENE* a new oil-additive????
by cadchris - 11/14/19 08:21 AM
STP mulit purpose motor treatment + fuel stabalizer
by Chris142 - 11/14/19 08:08 AM
"Universal" electric coolant circulation pump
by Superflan - 11/14/19 07:32 AM
Thermostat question
by nicholas - 11/14/19 07:13 AM
why michelin changed their tire lineup?
by edwardh1 - 11/14/19 07:12 AM
how do you mark your name on key fob?
by edwardh1 - 11/14/19 07:08 AM
"New EV Battery Can Charge in 10 Minutes..."
by wemay - 11/14/19 05:52 AM
TDS review
by Espada - 11/14/19 03:30 AM
contraption22, Caydel, Bull58, Koncrete_Cam, DirtyTony
69863 Registered Users
100 registered members (alarmguy, Andrei, alchargo, Alfred_B, 7 invisible), 2,333 guests, and 23 spiders.
Topics297,404
Posts5,114,737
Members69,863
Most Online3,589
Nov 2nd, 2019
Propene, polymer with ethene use in motor oil #5246908 10/22/19 09:29 AM
DrDanger Offline OP
This is from a mixed review moly engine oil additive I used. Only contents are oil, moly and this, however there may be "nonhazardous additions".
Then again it would not be pronene with ethene if it had some buddies with it right?
What would Propene, polymer with ethene be used for in an oil/additive scenario?
Is it a solid?
3.2 Mixtures
· Description: Mixture of substances listed below with nonhazardous additions.
CAS: 9010-79-1
EC number: 618-455-4
1-Propene, polymer with ethene 9–12%
Re: Propene, polymer with ethene use in motor oil [Re: DrDanger] #5246943 10/22/19 10:20 AM
K
kschachn Online Content
Online Content
K
It is a polymer, yes. One would assume it is polymerized. Looks like more than one monomer.
A VII?
1994 BMW 530i, 250K
1996 Honda Accord, 280K
1999 Toyota Sienna, 425K
2000 Toyota ECHO, 284K
Re: Propene, polymer with ethene use in motor oil [Re: DrDanger] #5246978 10/22/19 10:57 AM
DrDanger Offline OP
Was thinking along the lines of a ligand or a carrier substance(makes less sense), but then again I only just passed my high school chemistry(a while back) smile
You can make tons of things from Propene, polymer with ethene , but all my engine oil explanations require additional chemicals/reactions... thus the question.
Re: Propene, polymer with ethene use in motor oil [Re: kschachn] #5247026 10/22/19 11:45 AM
E
edhackett Online Content
Online Content
E
A VII?
It's not in the classes of rubber used as VII. A bit of research shows that the most appropriate use related to oils/additives would be to make the bottle.
ExxonMobil makes it and does not list any use with regards to oils.
Quote
1. Chemical Identity
ExxonMobil Chemical’s VistamaxxTM Performance Polymers are propylene based copolymers. These copolymers are made from the catalytic polymerization of propylene (C3) and ethylene (C2).
CAS No.: 9010-79-1
Chemical Name: Ethylene – Propylene Copolymer
2. Product Uses
These resins can be found in a wide variety of products including molded consumer articles, food or non-food packaging containers and films, compounds, hygiene products, and hot melt adhesives.
3. Physical / Chemical Properties
ExxonMobil Chemical’s VistamaxxTM Performance Polymers are white to off-white solids and can be clear or opaque. These resins are either in pellet or granule form and are stable solid polymers. They are generally safe at ambient conditions, due to their high molecular weight, minimal toxicity and general inertness. These resins are considered hazardous in their base form by the U.S. according to OSHA due to the possibility that they can form a combustible dust in the workplace.
Ed
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
Re: Propene, polymer with ethene use in motor oil [Re: edhackett] #5247057 10/22/19 12:18 PM
K
Online Content
K
Thanks, my minor in chemistry was failing me there .
1994 BMW 530i, 250K
Re: Propene, polymer with ethene use in motor oil [Re: DrDanger] #5247344 10/22/19 04:51 PM
MolaKule Offline
Global Moderator
Global Moderator
OCP's can be used in a number of products and in a number of forms but Lubrizol thinks it is the Olefin co-polymer used as a VII:
Quote
The subject product is a liquid additive used to control viscosity in a number of industrial formulations including heavy duty diesel engine oil packages
Dissolved in an oil carrier it is a VII.
In dry form it can be used to make plastic bottles, window casings, etc.
For every action there is an equal and opposite opposite criticism. shrug
Re: Propene, polymer with ethene use in motor oil [Re: DrDanger] #5247944 10/23/19 10:12 AM
DrDanger Offline OP
Thanks all for the info. Will try for something more interesting in future posts smile
Re: Propene, polymer with ethene use in motor oil [Re: DrDanger] #5248471 10/23/19 08:53 PM
E
Online Content
E
Well, it looks like it was my degree that failed me. I completely missed that this compound was an OCP. It also illustrates why I avoided the organic side of chemistry as much as I could. There are ten thousand names for the same compound and they all stank. grin
Thanks for the lesson, MolaKule.
Ed
Re: Propene, polymer with ethene use in motor oil [Re: DrDanger] #5251809 10/28/19 12:41 AM
N
Nyogtha Offline
N
There is the IUPAC naming convention, but it is relatively unpopular with marketing forces. The USA is absolutely not alone in this, Europeans use gas oil as a synonym for diesel fuel; in the USA gas oil is a petroleum distillation fraction from both atmospheric and vacuum dustillation processes too heavy to be used for diesel, but too light to be used as asphalt, and is the primary feed source for most fluid catalytic cracking units and hydrocracking units. The German name for gasoline (petrol) is benzin; benzene is the commin name for the compound with formula C6H6 which while having a high octane rating, is restricted in most countries to a low maximum percentage in gasoline.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
