'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Looking for a soft riding car
by Nayov - 11/18/19 04:00 PM
Do you use one filter brand or many?
by wemay - 11/18/19 02:43 PM
ATV engine oil
by supton - 11/18/19 02:02 PM
10w30 HDEO or 15w40, others. What's in your engine?
by 53' Stude - 11/18/19 01:47 PM
GM dealer oil change: Who makes their oil?
by Benzadmiral - 11/18/19 01:45 PM
Don't Fix Your Car!
by Y_K - 11/18/19 01:18 PM
best LL01 oil (for F10 M5/S63Tu)?
by vafan13 - 11/18/19 12:55 PM
Stripped oil pan
by dosmom - 11/18/19 12:35 PM
HyunKia Wix 51334XP $6.73 @ Amazon
by SlavaB - 11/18/19 12:18 PM
spiffy63, WhiteMega1227, ak2az, vafan13, Breezeknees
69908 Registered Users
143 registered members (alchargo, 4WD, 645ja, 01rangerxl, Al, 69GTX, 15 invisible), 2,109 guests, and 19 spiders.
Topics297,607
Posts5,119,039
Members69,908
Most Online3,589
Nov 2nd, 2019
Lift Master Remote RE-Programming #5246818 10/22/19 08:10 AM
G
Gebo Offline OP
G
I have 2 garage doors that use Liftmaster remotes. I was trying to program the door openers in one of my cars. Problem being I had 2 remotes that worked the same garage door. I need one of them to work one door and the other to work the other door. That way I can use the remotes to program the remotes in my car.
I took one of the remotes and followed the instructions as best as I could. I pressed the green button in the transmitter, light comes on, held the remote button down, light in transmitter flashes and turns off. I figure I'm done.
Well, now that remote works both doors. Both go up and both go down with one push.
Do I need to erase the remote somehow? I took out the battery and pressed the "on" button a bunch of times. Went back to program at the transmitter again but the doggone remote still opens both doors simultaneously.
The doors are 1994 editions and I can't find the owner's info.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Pennzoil Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Lift Master Remote RE-Programming [Re: Gebo] #5246825 10/22/19 08:16 AM
JohnnyJohnson Offline
2004 Corolla 136950
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76703
Out: T6 5W-40 XG9100 73705
In: Rotella Dino PH9100 11-3-19
Re: Lift Master Remote RE-Programming [Re: Gebo] #5246831 10/22/19 08:23 AM
G
Gebo Offline OP
G
After watching the video I’m assuming you cannot re-program a remote with just one button on it. All I did was just reprogram the other garage door to work with this remote’s signal.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Re: Lift Master Remote RE-Programming [Re: Gebo] #5246832 10/22/19 08:23 AM
G
Gebo Offline OP
G
Oh, thanks for the video. And no, my remote just has one key to press
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Re: Lift Master Remote RE-Programming [Re: Gebo] #5246840 10/22/19 08:32 AM
O
opus1 Offline
O
Maybe this will help?
You've done half the job and got the other unit to recognize the remote, but you still have to tell the first unit to forget that remote. In the process, you'll probably lose both remotes on that unit so you'll have to reprogram it to recognize the one you want to use for that.
Current Fleet:
2010 Hyundai Sonata GLS
2009 Chevy Cobalt SS Sedan (yes,the turbo)
2002 Dodge Dakota SXT Club Cab
1994 Ford Ranger XLT (RIP, Dad)
Re: Lift Master Remote RE-Programming [Re: Gebo] #5246851 10/22/19 08:45 AM
G
Gebo Offline OP
G
opus1, I saw that page and I'm trying to avoid it. I have 10 cars that are programmed to my garage doors and 4 of them aren't here.
I guess a remote just has one code and it can't be changed.
I'd rather spend a few $'s and get another newer remote. I'll call Chamberlain/Liftmaster.
Here's my remote:
[Linked Image]
[Linked Image]
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Re: Lift Master Remote RE-Programming [Re: Gebo] #5246883 10/22/19 09:08 AM
M
mk378 Online Content
Online Content
M
Something that old is likely to have its code set by switches inside. If you throw the switches to another code (just choose at random) it will stop working the first door, then you set the second door to recognize it.
Re: Lift Master Remote RE-Programming [Re: Gebo] #5246887 10/22/19 09:10 AM
G
Gebo Offline OP
G
opus1, I gotta do what you suggested. Erase and start over. I can keep these remotes or Chamberlain rep suggested I get a universal remote made by Chamberlain.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Re: Lift Master Remote RE-Programming [Re: mk378] #5246889 10/22/19 09:11 AM
G
Gebo Offline OP
G
I'll crack it open now.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Re: Lift Master Remote RE-Programming [Re: Gebo] #5246894 10/22/19 09:16 AM
G
Gebo Offline OP
G
No switches
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Re: Lift Master Remote RE-Programming [Re: Gebo] #5246918 10/22/19 09:43 AM
G
Gebo Offline OP
G
It was easy. Just deleted codes in one transmitter that opened with both remotes and then programmed the one remote to it.
Thanks for your help.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Re: Lift Master Remote RE-Programming [Re: Gebo] #5247160 10/22/19 02:06 PM
W
WhyMe Offline
W
if those are only single door remotes you might consider getting a new universal remote that can do both doors
https://www.amazon.com/Universal-Garage-Replacement-Chamberlain-Liftmaster/dp/B07NQCGNBF/ref=sr_1_107?crid=3O524W6LX04CC&keywords=garage+door+opener+remote&qid=1571774684&sprefix=garage+doo%2Caps%2C219&sr=8-107
Re: Lift Master Remote RE-Programming [Re: WhyMe] #5247226 10/22/19 03:01 PM
G
Gebo Offline OP
G
I'm considering. Only $30. But they are both working now.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Re: Lift Master Remote RE-Programming [Re: Gebo] #5247235 10/22/19 03:07 PM
E
edwardh1 Offline
E
off topic but the industry could do better.
my nissan homelink has one set of instructions in the car manual
the genie openner has another set
internet has a 3rd
all slightly different.
stupid
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
