2001 Toyota Sequoia
by Tlhfirelion - 11/14/19 11:02 AM
Creation date
by Duffyjr - 11/14/19 10:36 AM
Rescuing a critically sluged 6.4 F-350
by NDServices - 11/14/19 10:02 AM
New Fram boxes
by FordBroncoVWJeta - 11/14/19 10:00 AM
My dad bought a 2017 F150.
by dan_erickson - 11/14/19 09:52 AM
You ever spray paint inside the house?
by atikovi - 11/14/19 09:48 AM
recent experience with Adv Auto
by windeye - 11/14/19 08:59 AM
Lifted Trucks
by Passport1 - 11/14/19 08:56 AM
Fleet oil intervals to save money?
by Todd00000 - 11/14/19 08:44 AM
Motive power brake bleeder
by Redright9 - 11/14/19 08:25 AM
*GRAPHENE* a new oil-additive????
by cadchris - 11/14/19 08:21 AM
STP mulit purpose motor treatment + fuel stabalizer
by Chris142 - 11/14/19 08:08 AM
"Universal" electric coolant circulation pump
by Superflan - 11/14/19 07:32 AM
Thermostat question
by nicholas - 11/14/19 07:13 AM
why michelin changed their tire lineup?
by edwardh1 - 11/14/19 07:12 AM
how do you mark your name on key fob?
by edwardh1 - 11/14/19 07:08 AM
contraption22, Caydel, Bull58, Koncrete_Cam, DirtyTony
69863 Registered Users
99 registered members (69Torino, atikovi, bdcardinal, Bailes1992, BBDartCA, 8 invisible), 2,344 guests, and 30 spiders.
Topics297,407
Posts5,114,769
Members69,863
Most Online3,589
Nov 2nd, 2019
ATF Life in Sealed Bottle #5246598 10/21/19 10:34 PM
Z
ZeeOSix Offline OP
Z
I've got quite a few quarts of Pennzoil DEXRON III ATF in the bottle that has never been opened, but I think it's got to be at least 20 years old, maybe 25. eek
Was thinking of using it to swap out the power steering fluid on my 2005 Tacoma, since DEXRON III is what the Tacoma manual calls out for the power steering.
But is there any risk to use ATF that has been sealed in the plastic bottle that long?
How much fluid you think it would take to do a "suck out and refill" of the reservoir in order to get most of the original power steering fluid changed out?
Re: ATF Life in Sealed Bottle [Re: ZeeOSix] #5246600 10/21/19 10:46 PM
O
Oro_O Offline
O
I checked w/Valvoline a few years ago on this as I found I still had some sealed Dex II. They said no shelf life, really, if sealed and not over-heated. They suggested jokingly to toss it out when it got to 100 years old. Really. I put it in a 4wd transfercase and had no worries (which was Dex II spec'd and little used).
You can date it by checking the spec - DexIIIF, '93. DexIIIG, '98. DexIIIH, '03. Not that it matters terribly, but maybe out of curiosity you can see how old it really is.
Three "suck and fills" (as you have now forever labeled it ;0 ) should get you to 85% new fluid roughly. Most systems are only a quart total and you can get about a pint out if you pull the hose and drain, then re-attach and re-fill (easier than a baster, just put paper towels and a small-ish peice of tupperware to catch).
I do a single reservoir drain/fill whenever I service the trans fluid; easy to remember to do both at the same time.
Re: ATF Life in Sealed Bottle [Re: ZeeOSix] #5246601 10/21/19 10:49 PM
Chris142 Offline
If it can work in a transmission for 20+ years sitting unopened on your shelf is ok. Shake it up and use it.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: ATF Life in Sealed Bottle [Re: ZeeOSix] #5246639 10/22/19 12:34 AM
K
KneeGrinder Offline
K
^ This, I have some Valvoline Dex/Merc that is 15+ years old and will be putting it in the ford this spring.
08 Tribeca 90k PUP 5w30
06 Accord 137k PP 0w20
03 Acura CL-S 90k M1 AP 5W20
02 Acura TL-S 241k ST 5W30
02 Accord EX 155k PP 0W20
02 K3500 99k M 1 ESP 5w40
00 F350 139k M 1300 15w40
Re: ATF Life in Sealed Bottle [Re: ZeeOSix] #5246688 10/22/19 05:20 AM
J
JC1 Online Content
Online Content
J
Probably less than 2 quarts for the whole system. I got some free ATF from someone at work. Three quarts, I'm using it for my penetratimg fluid, just mix with acetone.
2015 Grand Caravan SXT Plus 5w-20 Eco-Power/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: ATF Life in Sealed Bottle [Re: Chris142] #5246727 10/22/19 06:19 AM
H
hallstevenson Offline
H
That is so true but why do people never think about this or consider it ?
Re: ATF Life in Sealed Bottle [Re: ZeeOSix] #5246780 10/22/19 07:41 AM
drtyler Offline
There is still a lot of fluid left in the hoses and the steering rack. It would be more effective to drain the fluid out of those as well, and then refill.
Re: ATF Life in Sealed Bottle [Re: hallstevenson] #5247140 10/22/19 01:47 PM
Z
ZeeOSix Offline OP
Z
But who's to say or prove that 25 year old ATF in a transmission hasn't degraded some from time? Just because the car still moves doesn't mean the ATF is still perfect.
Some motor oil manufacturers say their bottled oil has some kind of shelf life (way less than 25 years), so why not ATF?
Re: ATF Life in Sealed Bottle [Re: drtyler] #5247142 10/22/19 01:49 PM
Z
ZeeOSix Offline OP
Z
Doesn't the typical power steering system recirculate the fluid as the steering is operated?
Re: ATF Life in Sealed Bottle [Re: ZeeOSix] #5247177 10/22/19 02:17 PM
J
Jetsfan421 Offline
J
You could send a sample off for analysis, but that would defeat the purpose of being frugal and using what's on hand. Also the best way to flush a PS system is to unhook the return line and with the car off and jacked up steer lock to lock and continue filling reservoir until desired cleanliness is achieved. It's relatively mess free and as close to a 100% as you can get. It does require an extra set of hands though.
Re: ATF Life in Sealed Bottle [Re: ZeeOSix] #5247414 10/22/19 05:54 PM
N
nascarnation Offline
N
The atf in my 67 Camaro Powerglide was by all indications original when I did a full restoration of the car 5 years ago.
The transmission functioned properly (as it should have for 37,000 miles) but I did a full teardown just to be sure.
Same thing with the rear axle lube.
If this stuff doesn't get hot, it doesn't oxidize.
Re: ATF Life in Sealed Bottle [Re: ZeeOSix] #5248093 10/23/19 01:11 PM
N
NASTI Online Content
Online Content
N
[Linked Image] [Linked Image]
I found a bottle of Dexron III/Mercon from 1999. Should I be worried to use this?
2005 Subaru Impreza WRX STI
2015 Audi S3
2008 Lexus RX350
2000 Lexus ES300
Re: ATF Life in Sealed Bottle [Re: NASTI] #5248119 10/23/19 01:53 PM
A
AC1DD Offline
A
Quote
Is it sealed?
I'd be most concerned about WHO actually produced this stuff, it is is bottled by a reputable oil company I wouldn't hesitate to use it.
I agree with making sure you shake it well and then perhaps let it sit in the sun for some hours before you pour it into the transmission.
