Possible to balance a bent steel wheel?
by johnnyh55 - 11/22/19 06:33 AM
Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
Corslayth, oildud, Kylefl1, JDee71, trgfunds
69936 Registered Users
52 registered members (avi1777, atikovi, 97K15004WD, 2002 Maxima SE, ARB1977, anthonym6, 5 invisible), 1,290 guests, and 21 spiders.
Topics297,760
Posts5,122,001
Members69,936
Most Online3,589
Nov 2nd, 2019
Rate Thread
CRC Heavy Duty Pro Degreaser #5246100 10/21/19 01:43 PM
L
LeakySeals Offline OP
L
I bought this yesterday. Anybody use it? I'm a little gun-shy to use anything on the engine after Purple Power corroded aluminum under the hood.
http://www.walmart.com/ip/CRC-Heavy-Duty-Pro-Degreaser/821986826
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: CRC Heavy Duty Pro Degreaser [Re: LeakySeals] #5246126 10/21/19 02:03 PM
N
nthach Offline
N
Looking at the SDS of the non-aerosol version of the CRC stuff vs. the Purple Power there's quite a bit of a difference. PP has 25% lye(Sodium Hydroxide) which explains why it corroded your aluminum. pH seems to be same but I would trust the CRC stuff. I've been using Simple Green HD(purple liquid) or WD-40 Specialist Water-Based Degreaser for my underhood cleaning. They aren't as caustic to Al as Purple Power/Super Clean and its clones.
http://docs.crcindustries.com/msds/5484.pdf
https://docs.wixstatic.com/ugd/14ad0e_342940d078d94505b11d1358c997718c.pdf
Re: CRC Heavy Duty Pro Degreaser [Re: LeakySeals] #5246150 10/21/19 02:18 PM
K
krismoriah72 Offline
K
I use LA totally awesome.. $1 does all that i ever want out of a degreaser.
Re: CRC Heavy Duty Pro Degreaser [Re: LeakySeals] #5246493 10/21/19 08:15 PM
R
RDMgr Offline
R
I don't think the PP contains 25% NaOH. It contains 3-4% of a 25% NaOH solution or 0.75-1.0%. It is probably used to adjust pH for solubility and clarity which is a common practice is water based cleaner/degreasers.
