I have an old RadioShack handheld CB I use with a BNC-to-PL259 adapter going to a mag mount antenna attached to the windowsill of my bedroom window to listen to Superbowl 6 when I'm too lazy to go out and sit in my car.
This little radio works great but if you let it sit longer than 3 days almost every time the batteries in it corrode and it looks like I'm trying to make my own Miracle-Gro powder.
The other day I spend almost 45 minutes with a wire brush scrubbing all the corrosion off the contacts in the battery back just so it would make good enough contact for the radio to turn on.
I tried using rechargable batteries in it but those do not have enough power for the radio if I try to transmit with them.
Is there something I can do to prevent the corrosion or should I just remove the battery back when the radio is not in use? Or is there possibly another underlying cause??
