'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Looking for a soft riding car
by Nayov - 11/18/19 04:00 PM
Do you use one filter brand or many?
by wemay - 11/18/19 02:43 PM
ATV engine oil
by supton - 11/18/19 02:02 PM
10w30 HDEO or 15w40, others. What's in your engine?
by 53' Stude - 11/18/19 01:47 PM
GM dealer oil change: Who makes their oil?
by Benzadmiral - 11/18/19 01:45 PM
Don't Fix Your Car!
by Y_K - 11/18/19 01:18 PM
best LL01 oil (for F10 M5/S63Tu)?
by vafan13 - 11/18/19 12:55 PM
Stripped oil pan
by dosmom - 11/18/19 12:35 PM
HyunKia Wix 51334XP $6.73 @ Amazon
by SlavaB - 11/18/19 12:18 PM
spiffy63, WhiteMega1227, ak2az, vafan13, Breezeknees
69908 Registered Users
130 registered members (ABerns, 4WD, 2015_PSD, 645ja, 01rangerxl, 69GTX, 18 invisible), 2,064 guests, and 21 spiders.
Topics297,607
Posts5,119,049
Members69,908
Most Online3,589
Nov 2nd, 2019
2008 Mustang V6 ATF #5245844 10/21/19 09:58 AM
Sixxer Offline OP
I have used Amsoil previously, but I am looking to use something I can pickup at the store without issue. I’ve used Castrol import in the wife’s Mazda and can’t decide between Castrol or MaxLife. The car is at 135,000 and is driven mostly highway/stop and go traffic on the return from work. I haven’t noticed any transmission issues as of yet.
Thanks in advance
2008Mustang
Current fill: RoyalPurple
Current stash:15RoyalPurple 10QSUD 19Peak 5NxtGN 5SSAmsoil 5PU 10PP
Re: 2008 Mustang V6 ATF [Re: Sixxer] #5245860 10/21/19 10:15 AM
MolaKule Offline
Global Moderator
Global Moderator
Which Amsoil, ATF or ATL?
What is the ATF specification for transmission, Mercon LV?
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: 2008 Mustang V6 ATF [Re: Sixxer] #5245863 10/21/19 10:17 AM
bdcardinal Offline
Mercon V was the spec. The hardest part about these transmissions is filling the unit through the drain plug.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2008 Mustang V6 ATF [Re: Sixxer] #5245870 10/21/19 10:20 AM
Sixxer Offline OP
MERCON V Is the spec and yes they are a pain to service. My concern was that many of the fluids I see specify LV and not V and a quick google search tells me not to mix them. Some people have private messaged Valvoline and we’re told it would be okay, but why isn’t it listed on the bottle? Just looking for feedback from those that have had success Yes Amsoil ATF
2008Mustang
Re: 2008 Mustang V6 ATF [Re: Sixxer] #5245907 10/21/19 11:12 AM
Silverado12 Offline
I use NAPA Merc V. I'm assuming you have the special fitting to fill through the drain plug, because if not you'll need that. You can find them on eBay, etc. I think my 2010 GT took about 5 quarts with a new filter.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: 2008 Mustang V6 ATF [Re: Sixxer] #5245925 10/21/19 11:27 AM
J
Jimzz Offline
J
Maxlife should work fine, used it in several rangers and other ford vehicles that called for Mercon-V
If worried then supertech Mercon-V will work also.
yup
Re: 2008 Mustang V6 ATF [Re: Sixxer] #5246066 10/21/19 01:10 PM
69GTX Online Content
Online Content
I'm in the same boat with my 2001 Lincoln. And in all the research I did I didn't see anything that suggested moving down from a Mercon V medium viscosity of 7.5 cSt @100 C to a LV (Dex 6) at 5.8 cSt was a great idea. Most regular Mercon V's are semi-synthetic and will shear down over a 20,000-30,000 mile OCI to about an LV spec. But there are full synthetic Merc V's that will stay up at 6.8-7.2 during their lives. Mobil 1 ATF and the Amsoil or Redline syn ATF's are of the correct viscosities and will not shear down much. MaxLIfe ATF is a great fluid....but it's not medium viscosity. Until I see a ton of evidence that the Merc V vehicles ran 150K-200K miles on "only" Max LIfe fluid, I'm not convinced it's a correct substitute.
Despite all that I use the Super Tech Mercon V (semi-syn) and have used Amalie Mercon V as well. The only ones that I know have the Ford Merc V approval are Super Tech and Castrol Merc V. I change out my ATF every 15K-25K miles based on color/appearance.
Whatever your Mercon V fluid is, change it every 20k-30k miles and you shouldn't have a problem. If you go to a Quick Lube place be aware they might put in the older Mercon/Dex 3. They've done that to me. So now I just change my own fluid 2-1/2 to 3 yrs.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
