AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1¢ at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
24 registered members (ctechbob, A_A_G, FordBroncoVWJeta, CharlieBauer, 53' Stude, 2 invisible), 699 guests, and 16 spiders.
Topics297,569
Posts5,118,205
Members69,899
Most Online3,589
Nov 2nd, 2019
Painted calipers - brake cleaner #5245731 10/21/19 08:07 AM
H
hallstevenson Offline OP
H
I've contemplated painting the brake calipers on my car, either black or a 'cast iron' (silver, grey, etc) color - something relatively subtle, not red or yellow or anything like that ! When people do this, how do you deal with using a product like Brakleen when doing brake work ? I've already contacted Brakleen and they said it will probably remove the paint. I'm not talking about factory, powder-coated brake components as that's technically not "paint".
I could see avoiding spraying the caliper itself but something like the caliper bracket would be pretty unavoidable.
Re: Painted calipers - brake cleaner [Re: hallstevenson] #5245739 10/21/19 08:16 AM
K
KGMtech Offline
K
If the paint was applied to a clean surface, the brake clean solution should not damage it in any way, however if there was any oil / dirt on the metal before the paint was applied, these areas might lift off.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Painted calipers - brake cleaner [Re: hallstevenson] #5245742 10/21/19 08:20 AM
P
Pew Offline
P
It will dull the caliper paint.
Just an fyi, factory calipers are either painted or anodized, not powder coated (if we're talking about the nice floating calipers.) I haven't come across one that came powder coated from the factory.
Re: Painted calipers - brake cleaner [Re: hallstevenson] #5245806 10/21/19 09:25 AM
W
WondrousBread Offline
W
I painted my calipers using VHT Caliper Paint, and after using brake cleaner I only noticed a slight dulling. If you're careful, I'm sure you can avoid getting it on anything too noticeable.
Re: Painted calipers - brake cleaner [Re: hallstevenson] #5246110 10/21/19 01:52 PM
N
NoNameJoe Offline
N
I find that with most caliper paints that are formulated as actual caliper paint (not just random paint) they resist brake cleaner. The key term here is "resist" not impervious. The other thing I noticed is that if the paint is fresh, it's easier to remove or damage it with brake cleaner. Once you've had the caliper paint on for weeks or months, it's pretty much extremely resistant.
I used the POR-15 caliper paint in the little pint cans. Once that's been on for months, I could spray brake cleaner directly at it and even rub it with a towel and the only thing that comes off is dirt.
2015 Civic LX Coupe
Re: Painted calipers - brake cleaner [Re: hallstevenson] #5246458 10/21/19 07:38 PM
P
P10crew Offline
P
Por 15 and follow the directions on the can to a T and you will be plenty pleased.
Re: Painted calipers - brake cleaner [Re: P10crew] #5246568 10/21/19 09:39 PM
H
H
I've considered using the brush-on paints and this POR-15 looks nice. Did either of you use the full-blown kit with the degreaser, metal prep, rust preventative, and the paint itself or just the paint only ?
Re: Painted calipers - brake cleaner [Re: hallstevenson] #5246595 10/21/19 10:28 PM
P
P10crew Offline
P
That is the kit that I refer to. It’s a cleaner, pickeling juice, por 15 and their top coat. The finger drag test is critical because you need the base por 15 to have some bite left for the top coat. I’ve only used the black kit and I can tell you for sure that brake fluid will not attack it.
Re: Painted calipers - brake cleaner [Re: hallstevenson] #5246623 10/21/19 11:50 PM
N
NoNameJoe Offline
N
I did not follow the directions for POR-15. I was looking to do it quick and dirty LOL.
If you follow the directions it should come out even better. Since I didn't basecoat with POR-15 like the instructions said, I do get small amounts of rust appearing every now and then, I just brush it off and paint another layer on from the same can.
I didn't use the rest of the stuff either. For prep all I did was brush all of the rust off with a brass and steel brush and degrease. No etching, nothing. Then masked it and away I went.
2015 Civic LX Coupe
