Motive power brake bleeder
by Redright9 - 11/14/19 08:25 AM
*GRAPHENE* a new oil-additive????
by cadchris - 11/14/19 08:21 AM
STP mulit purpose motor treatment + fuel stabalizer
by Chris142 - 11/14/19 08:08 AM
"Universal" electric coolant circulation pump
by Superflan - 11/14/19 07:32 AM
Thermostat question
by nicholas - 11/14/19 07:13 AM
why michelin changed their tire lineup?
by edwardh1 - 11/14/19 07:12 AM
how do you mark your name on key fob?
by edwardh1 - 11/14/19 07:08 AM
"New EV Battery Can Charge in 10 Minutes..."
by wemay - 11/14/19 05:52 AM
TDS review
by Espada - 11/14/19 03:30 AM
SD40 Guide Rod ?'s
by GumbyJarvis - 11/14/19 01:08 AM
How many steps a day are you getting?
by P10crew - 11/14/19 12:45 AM
Pics - Top Piston Cleaning - Lexus CT200h
by KerryB - 11/14/19 12:14 AM
Valvoline Full Synthetic Maxlife 10w30
by KerryB - 11/13/19 11:38 PM
Toyota 1MZ-FE burning lots of oil
by Speedinsweede - 11/13/19 11:27 PM
Castrol Magnatec
by dosmom - 11/13/19 10:51 PM
How do you feel about buying tires with different DOT's?
by Speedinsweede - 11/13/19 10:23 PM
Toys for the Caprice
by ls1mike - 11/13/19 09:08 PM
7.62x39 AR anyone?
by sw99 - 11/13/19 09:07 PM
Chrysler EcoDiesel Class Action Suit
by JeffKeryk - 11/13/19 07:45 PM
PaulDouglas, DanF350man, Jasonoff, Speedinsweede, JeffS
69856 Registered Users
105 registered members (4WD, 53' Stude, 1978elcamino, 10ecfarmer, 64bawagon, 2015_PSD, 6 invisible), 2,157 guests, and 23 spiders.
Topics297,393
Posts5,114,557
Members69,856
Most Online3,589
Nov 2nd, 2019
Mercedes IDI 30 wt. vs. 40 wt. #5245795 10/21/19 09:13 AM
A
Alex_V Offline OP
A
My wife and I both drive Mercedes W123's with the OM617 turbodiesel. This is a 3.0L IDI 5-cylinder mill breathing through a Garrett T3 turbo that holds 2 gallons of oil and has an air>oil cooler.
On all the enthusiast forums they preach nothing but 40 weight - but there are also a lot of people that get nasty when you mention synthetic. "The synthetic is too thin for these old iron motors. They weren't designed for it. Go by the owner's manual." Well... the manual says this:
32F and up: SAE 30/20w40/20w50
23F and up: 15w40/15w50
-4 to 50F: 10w/10w30
All climates: 10w40/10w50
Both engines get good fuel economy, use no negligible oil, and get Schaeffer's 9000 5w40 changed every 5,000 miles. I don't want to risk the motors on a casual experiment, but will using a synthetic 10w30 (to the chagrin of the old-hat enthusiast crowd) run any risk of compromising the motors through the cooler months here in KY? My gut says no, the modern 30 weight will be in better shape after twice the miles that a 40 weight would've been in the 1980's - but I won't discount the opinion of people with more experience than myself just on a whim.
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Mercedes IDI 30 wt. vs. 40 wt. [Re: Alex_V] #5245800 10/21/19 09:19 AM
K
kschachn Online Content
Online Content
K
What Mercedes Benz approval is required for your engine? That dictates a minimum HTHS and subsequently the grade. Is there no approval for an engine that old?
People that preach grade when it is divorced from a required approval don't know what's important. Is your gut feeling an adequate replacement for approvals?
1994 BMW 530i, 250K
1996 Honda Accord, 280K
1999 Toyota Sienna, 425K
2000 Toyota ECHO, 284K
Re: Mercedes IDI 30 wt. vs. 40 wt. [Re: Alex_V] #5245815 10/21/19 09:33 AM
A
Alex_V Offline OP
A
I'm not finding any correlation of a MB spec. to the cars of this era - just the API ratings, at best. The 1980 owner's manual I have handy says "consult your Mercedes service center" or something along those lines, like the oil spec may change - which wouldn't be a bad move considering the evolving nature of motor oils and the possibility to back-spec a more modern oil after the cars leave the factory.
Re: Mercedes IDI 30 wt. vs. 40 wt. [Re: Alex_V] #5245819 10/21/19 09:37 AM
K
Online Content
K
Yeah, probably not.
How about a 229.5 oil? Or really any A3/B4 oil at Walmart.
1994 BMW 530i, 250K
Re: Mercedes IDI 30 wt. vs. 40 wt. [Re: Alex_V] #5245825 10/21/19 09:42 AM
A
Alex_V Offline OP
A
In a nutshell, what would be the benefits over the synthetic 5w40 I'm using now?
These engines run forever on... basically anything. The majority of people just default to T4, Delo, etc. 15w40. Usually what kills them is being run low/out of oil, or just succumbing to decades of only ~adequate~ maintenance.
Re: Mercedes IDI 30 wt. vs. 40 wt. [Re: Alex_V] #5245826 10/21/19 09:42 AM
Astro14 Online Content
Online Content
As a former W123 owner, I remember the wide viscosity range allowed in the owners manual. SF/CC was the spec listed I think. Hardly rigorous. Plenty of latitude in that manual.
If I still had a W123, the Rotella T6 synthetic (5W40, inexpensive, good slot control) would be my ‘year round choice.
A 10W30 in KY winters would be fine, too. It doesn’t need a boutique oil, it’s a tolerant engine. But good detergent/soot control are important.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Mercedes IDI 30 wt. vs. 40 wt. [Re: Alex_V] #5245836 10/21/19 09:51 AM
G
GSCJR Offline
G
MB 229.3 or 229.5 is required for those engines.
07 3.5L VQ35DE NAPA FS 5w-30 ProSelect 21358 148KM
10 3.5L 2GR-FE AGIP SS XL 5w-20 ProSelect 27047 174KM
Re: Mercedes IDI 30 wt. vs. 40 wt. [Re: Astro14] #5245866 10/21/19 10:18 AM
A
Alex_V Offline OP
A
Slot control?
Yes, the IDI's dirty the oil more quickly than others so keeping that under control is the biggest concern. With a tight, healthy engine with good oil pressure and no problems with a thinner oil slipping through the cracks (rings or gaskets) I don't see why a 10/30 wouldn't protect one just as well.
Re: Mercedes IDI 30 wt. vs. 40 wt. [Re: Alex_V] #5245904 10/21/19 11:10 AM
B
bullwinkle Offline
B
I cleaned up a coked up ‘82 300D turbo engine with Delvac 1 5W40 when I first bought it from an older guy that ran gasoline engine 20W50 in it (!), it did great, but it leaked it out pretty quickly. Any decent diesel rated HDEO would do great in those dirty old diesels, from 5W30 on up to 15W40.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Mercedes IDI 30 wt. vs. 40 wt. [Re: Alex_V] #5245943 10/21/19 11:43 AM
Online Content
Slot control?
Apple “correcting me” again.
Soot.
Variously corrected to “slot” or “shoot”.
Those engines make quite a bit of carbon that dirties up the oil. Good detergent is a must. (any diesel-rated oil will do).
They also pre-date MB 229.3 or 229.5, so while those are good specs, they’re not really a concern. Just get a modern diesel-rated oil.
10W30 Rotella, or Delvac, or Valvoline, or whatever, as long as it is diesel rated, would be fine.
32 Packard 15W40
05 MB S600 0W40 M1
Re: Mercedes IDI 30 wt. vs. 40 wt. [Re: Astro14] #5246155 10/21/19 02:21 PM
B
bullwinkle Offline
B
Slot control?
Soot.
Yes, DO NOT use a dual rated passenger car oil (like SF/CC, CD, or CF) like some of the manuals suggested-that’s what jammed up the rings on my old 300D, it couldn’t handle the soot buildup. After the Delvac 1, I ran whatever cheap 15W40 (summer) or 10W30 (winter) CI-4/+, CJ-4, or CK-4 oil I could find. Mostly Delvac 1300 & Rotella Triple Protection & T5.
Re: Mercedes IDI 30 wt. vs. 40 wt. [Re: bullwinkle] #5246478 10/21/19 07:59 PM
O
oakaro68 Offline
O
You ran only one oci of delvac 1 and it cleaned it up that drastically? If that's true that's pretty impressive. What were the indications it was coked up?
