Mystik JT-6 Hi-temp vs. synthetic iso 220?
WA
Ok this is a follow up to the 4Runner driveline thread. I was going to just bite the bullet and get two grease guns but I'm rethinking that. I'm probably just going to use the Mystik JT-6 Hi-temp No.2, but would the Synthetic ISO 220 be a better choice? I'm only going to use this twice a year at most and it's going to be sitting. I don't want a grease that's going to sit here and separate and leak all over.
Thanks!
My concern with JT-6 high temp. It is only good down to -10 degrees F.
What happens if I travel somewhere that is colder? This is my cold weather vehicle, that is why I run a 0w oil.
Haven't greased my T4R yet, but plan to soon.
Wonder what the drop point of it is - when the red liquid leaks out, after the first month in the tube.
Originally Posted by Snagglefoot
Mystik is sold in Mini-tubes as well. You could by a mini-gun for a low price.
I found a tube of the JT-6 Hi-Temp No.2, seems like it meets the spec's of the manual so I hit all the fittings yesterday. I'm probably just going to give em all a shot every oil change or every other. If I can find a small tube of the moly I wouldn't be against a small harbor freight gun just for the sliders.
Thanks
