Possible to balance a bent steel wheel?
by johnnyh55 - 11/22/19 06:33 AM
Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
hunter9296, Corslayth, oildud, Kylefl1, JDee71
69937 Registered Users
78 registered members (53' Stude, 01rangerxl, 2K2AcuraTL, avi1777, AndyB, anthonym6, 9 invisible), 1,488 guests, and 22 spiders.
Topics297,761
Posts5,122,037
Members69,937
Most Online3,589
Nov 2nd, 2019
Rate Thread
oil change interval effect on emissions #5245649 10/21/19 06:24 AM
R
ryan2022 Offline OP
R
Hi gang,
Wondering if anyone had any hard numbers on the effects of oil change intervals and emissions?
I know when they used to give you a readout up here, that fresh oil was always best, and that N0x and HC always dropped.
I'm thinking about running a green initiative here because we area small city FULL of long distance commuters. I've been toying with the idea of putting together an inexpensive bypass filtration kit for the masses, for our local home show.
Any thoughts are appreciated.
Thanks,
Ryan
2011 Subaru Impreza Hatchback 5w30 Mobil 1
2015 Subaru Outback 2.5 Limited 0w20 Mobil 1 AFE
1995 Nishiki Navajo mountain bike....some kind of chain oil.
Re: oil change interval effect on emissions [Re: ryan2022] #5245697 10/21/19 07:32 AM
Snagglefoot Online Content
Online Content
This is a stretch but some of the advertisers have made a link between a longer OCI coupled to less oil use and therefor a positive effect on global warming. I’m not making this up. And please don’t wreck the OP’s thread because of my global warming comment. smile
If you want the job done right......do it yourself.
Re: oil change interval effect on emissions [Re: ryan2022] #5245712 10/21/19 07:48 AM
Online Content
By the way, most used oil does not get recycled. The “ recyclers” sell most of it to get burned.
Re: oil change interval effect on emissions [Re: ryan2022] #5245814 10/21/19 09:32 AM
P
Pisto Offline
P
Engine braking with old oils is the biggest contributor to emissions.
Re: oil change interval effect on emissions [Re: ryan2022] #5245946 10/21/19 11:46 AM
DGXR Offline
Sorry I don't have any hard numbers. The reason I bother to comment is because, if an OCI is so long that it significantly affects fuel economy or emissions, the service interval needs revision. Engine oil should provide the same engine protection whether it's new or used, more or less. In fact, there are many reasons to believe that engine wear actually decreases as an oil run continues, to a point. (This has been discussed in other threads.)
Bypass filtration is a great way to safely extend OCI -- your idea definitely has merit. The question is, how many takers will you get?
Good luck... your heart is in the right place and I hope you are successful.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: oil change interval effect on emissions [Re: ryan2022] #5246785 10/22/19 07:44 AM
T
thooks Offline
T
Here's the problem with long OCIs and shorter commutes.... and it seems to not be discussed here much, if at all-
Condensation builds up in the crankcase....both with engine start/stop/cool down and just sitting still over the course of days....warm up with the sun, cool off with the night.
What you have with shorter trips and longer OCIs is more and more water builds up in the engine, water destroys bearings.
I have never seen anyone get concerned about global warming or the environment when their engine has bit the dust....
Re: oil change interval effect on emissions [Re: thooks] #5251652 10/27/19 07:30 PM
R
ryan2022 Offline OP
R
Thanks for the replies guys. Much appreciated.
I'm actually digging deeper into this, and am about to speak with my local emissions testing facility. If they still have their old testing equipment which actually measure Nox, HC and CO, I may voluntarily have our healthy 2011 Subaru impreza read before and after.
If I can make a claim for cleaner oil over the duration of an OCI contributing to lower emissions, along with the benefit of increasing the OCI, it might be a cool side project.
I'll post back here, if anyone is interested in following along.
Thanks again.
Ryan
Re: oil change interval effect on emissions [Re: ryan2022] #5251828 10/28/19 02:55 AM
L
Lubener Offline
L
As long as there is a PCV system, long OCI's will always have a negative effect on emissions.
The "thinking" man's friend.
