Originally Posted by ctechbob
Remember, its not just the timing belt, but there are also balance shaft belts to change while you're in there.
-snip-
Also, while you're in there, buy the $10 dorman (or other brand) balance shaft seal retainer. For some reason, the balance shaft seal likes to walk out on the F23 motors, no rhyme or reason, they sometimes do, and sometimes don't. If they do, the car will gush oil and you'll make it about 2 miles before the sump is empty. It happened to my wifes 2000 a couple months back and she continued to drive it. It survived, but who knows how long it would have lasted (was totaled a month later by an inattentive driver). Its a cheap part and it will ensure that it never happens and if you're in there anyways, why not. It is actually a dorman part that works.
https://www.dormanproducts.com/p-28216-917-006.aspx div>
That seems to be included with the Aisin timing belt kit
-snip-
