Possible to balance a bent steel wheel?
by johnnyh55 - 11/22/19 06:33 AM
Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
hunter9296, Corslayth, oildud, Kylefl1, JDee71
69937 Registered Users
78 registered members (007, 4WD, andyd, alchargo, anthonym6, Aero540T, 9 invisible), 1,679 guests, and 23 spiders.
Topics297,761
Posts5,122,062
Members69,937
Most Online3,589
Nov 2nd, 2019
Rate Thread
Oil Fuel Dilution - Saturation Point? #5245608 10/21/19 05:28 AM
T
Tjbouwhu Offline OP
T
Vehicle: 2018 Honda CRV 1.5l (GDI Turbo)...yes it is a fuel diluter
Recommend Oil: 0W20...I now use 0W30
Sump Capacity: 3.7qts with filter change
OCI: 5000mi
Driving Style: Rural...minimum 10mi drive (one way) every time the vehicle is used. 20k mi per year, so I change the oil like every three months. My wife drives this, and has a lead foot for sure.
So, after an oil change the oil level quickly rises (after say 500 - 600 miles) 3/8โ€ on the dip stick which equates to about 0.6qts...and seems to stay at that level till the next oil change. I know that 3/8โ€ on the dipstick equals about 0.6qts because I measure the oil I drain out after a change. I realize that cold weather and short trips enhance the issue...but this vehicle never sees short trips and this past oil change was over the summer so no cold weather.
So my question - is there a saturation point where only so much fuel can collect in the oil, at that point the rest burns off?
Tom
Re: Oil Fuel Dilution - Saturation Point? [Re: Tjbouwhu] #5245753 10/21/19 08:26 AM
J
jbutch Offline
J
My wive's 2018 Civic with the 1.5T was recalled a few months ago, is it possible your CRV is under that recall?
Back to your question, long highway rides at operating temp would be the best way to burn off the excess fuel. High temperature is the only way to control fuel dilution, not the quantity of fuel in oil.
2015 Forester XT @ 100k km
Current fill: Rotella T6 Multi Vehicle 5w-30 with Fram Ultra XG7317
Re: Oil Fuel Dilution - Saturation Point? [Re: Tjbouwhu] #5245761 10/21/19 08:35 AM
M
Mad_Hatter Offline
M
It'll just continue to form a homogeneous mixture right?.. what burns off, burns off but as long as fuel is added you'll basically have a "Foil" instead of an oil?๐Ÿ˜‚
Re: Oil Fuel Dilution - Saturation Point? [Re: Tjbouwhu] #5246510 10/21/19 08:27 PM
Ded Mazai Offline
I'd be more concerned about the fuel dilution itself and how to prevent it. Bumping up the oil viscosity is not going to solve the problem.
Re: Oil Fuel Dilution - Saturation Point? [Re: Mad_Hatter] #5246571 10/21/19 09:47 PM
PimTac Offline
Is this helpful?
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Oil Fuel Dilution - Saturation Point? [Re: PimTac] #5246655 10/22/19 03:44 AM
T
Tjbouwhu Offline OP
T
Is this helpful?
Yes, sort of what I was thinking...the fuel that absorbs in the oil does not seem to readily burn off.
Tom
Re: Oil Fuel Dilution - Saturation Point? [Re: Ded Mazai] #5246658 10/22/19 03:48 AM
T
Tjbouwhu Offline OP
T
Yes I am concerned about fuel dilution which is why I am asking...the higher viscosity doesnโ€™t solve the problem, but gives me more โ€œcushionโ€ to keep the motor lubricated as the fuel cuts back the oils starting viscosity.
Tom
Re: Oil Fuel Dilution - Saturation Point? [Re: PimTac] #5246686 10/22/19 05:11 AM
M
Mad_Hatter Offline
M
Is this helpful?
You mean like when someone asks a question about dealer oil change/practices and your ONLY comment in the thread is this๐Ÿ‘‡...Hypocrite/troll...
They are all out to get you.
GDA
And yes, per the OP it was helpful. Sorry you couldn't see it PimTac..๐Ÿ˜‰
Re: Oil Fuel Dilution - Saturation Point? [Re: Tjbouwhu] #5247472 10/22/19 06:38 PM
J
JAG Offline
J
The rate of evaporation of fuel out of the oil is proportional to the concentration of fuel in the oil. That causes the fuel concentration to increase most rapidly when there is no fuel in the oil and over time, the concentration keeps increasing but at a slower and slower rate, until it reaches an uneasy equilibrium. I say uneasy because any changes to the system will cause fluctuations in the fuel concentration, like doing more short trips, changing air temperatures, driving habits, etc.
Re: Oil Fuel Dilution - Saturation Point? [Re: JAG] #5247543 10/22/19 07:54 PM
T
Tjbouwhu Offline OP
T
Thank you for this...I suspected something such as this was going on.
Tom
