Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
53k miles on a Ford FA-1927
by BeerCan - 12/11/19 09:53 AM
Penzoil Platinum 100% Synthetic ????
by Talent_Keyhole - 12/11/19 09:50 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
96 registered members (Aero540T, 2015_PSD, 01rangerxl, 379KITTY, 2010Civic, 9 invisible), 1,894 guests, and 29 spiders.
Topics298,591
Posts5,138,768
Members70,104
Most Online3,589
Nov 2nd, 2019
How long is a reusable fluid pan gasket supposed to last? #5245506 10/20/19 10:36 PM
P
perfect_oil Offline OP
P
Transmission: GM 4T65E
Fluid Pan Gasket: FEL-PRO TOS18717 reusable type
After a few thousand miles, a drop of fluid will form on the tip of each individual bolt head. If I wipe the pan clean including all the bolt heads, the next day I can run my finger along the parting surface between the pan and the transmission and get a wet finger.
Questions:
- If these gaskets are reusable and never wear out, why are there new ones for sale?
- At which point do you replace yours?
- Do you replace yours with a reusable type, or do you prefer to go with a single use gasket doctored up with sealant?
Final comment:
Whenever I've used a rubber impregnated cork gasket coated on both sides with Permatex 2B, I've never had a leak. But I'm trying to stay with the OE type gasket because I'm trying stay OE as much as possible. We're supposed to trust the GM engineers.
Re: How long is a reusable fluid pan gasket supposed to last? [Re: perfect_oil] #5245507 10/20/19 10:46 PM
O
oldhp Offline
O
I'm sure they have a put on/take off number until they're no longer usable. That being said I've changed a lot of them and never had a leak. But I've never changed one more than maybe twice. I would think heat would affect them more than being taken off/on. If you changed it out every 50K miles and you had the car 200K miles......3 times. IDK.....
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: How long is a reusable fluid pan gasket supposed to last? [Re: perfect_oil] #5245523 10/20/19 11:39 PM
I
Ihatetochangeoil Offline
I
I do NOT have an answer for you, but I have personal experience. I currently own 3 vehicles with GM 4t65e transmissions; none of them leak anything, run like a top and 2 have well over 150K. I can tell you that I'm METICULOUS when I've changed fluid, carefully break the seal with a sharp putty knife while one side still has (loosened) bolts in it...Clean the gasket surface with a white linen rag damp with acetone and wipe until a rag comes off still white....Let the pan drip overnight into a drain pan, then swab every drip I can still find underneath...reuse the OEM gasket after wiping it down with dry rags until a white rag comes off white...tighten the pan bolts with an inch pound torque wrench and go around maybe 3 times until no bolts turn any more...I use no permatex or any sealer, it's not used OEM...
I have NO leaks, seeps, dry bolts a week or month later....Now all this being said, I prefer to change ATF after ~30K miles based on MolaKule's answer here: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/2605356/2
I'm also a fan of ZZPerformance and have their 4t65e pan with drain plug on 2 of 3 vehicles: https://zzperformance.com/collections/3800/products/4t65e-aluminum-transmission-pan It's so much less mess, but still drop the pan every other fluid change to swap filters. I think the car my daughter drives has had 4 fluid changes, OEM gasket...I've not replaced a gasket.
Re: How long is a reusable fluid pan gasket supposed to last? [Re: perfect_oil] #5245544 10/21/19 02:25 AM
demarpaint Offline
As long as the gasket retains its shape and has no tears or deformities it can be used again. I got 3 uses out of the transmission pan gasket on my 2000 Century before we gave the car to my son.
God Bless Our Troops
Re: How long is a reusable fluid pan gasket supposed to last? [Re: Ihatetochangeoil] #5245550 10/21/19 03:11 AM
L
Lubener Offline
L
A big term paper for a couple simple questions which really didn't get answered..
The "thinking" man's friend.
Re: How long is a reusable fluid pan gasket supposed to last? [Re: perfect_oil] #5245583 10/21/19 05:02 AM
K
Kira Offline
K
Would the OP please provide a description of the gasket?
There's "almost paper" looking stuff.
There's formed black neoprene on a metal frame
There's the crushed cork and black stuff (mentioned above)
There's a blueish one I just got with my Hastings TF110 filter kit (for a Ford 5R55E)
My term paper will about finding "whatever" after 15 years.
Re: How long is a reusable fluid pan gasket supposed to last? [Re: perfect_oil] #5245609 10/21/19 05:29 AM
Silverado12 Offline
The reusable gaskets look like a stiff gasket with double "o-rings" around it. I don't think any other type are considered reusable. Differential pan gaskets can be like that too. I've never had one leak, but for about 30 bucks or a little less you can replace it. Make sure your pan is flat with a straight-edge around the bolt holes.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: How long is a reusable fluid pan gasket supposed to last? [Re: perfect_oil] #5245620 10/21/19 05:42 AM
L
Linctex Offline
L
As long as it doesn't leak........
Re: How long is a reusable fluid pan gasket supposed to last? [Re: perfect_oil] #5245667 10/21/19 07:04 AM
A
atikovi Offline
A
I toss the reusable type and replace with RTV. That's what most of the manufacturers have switched to for no leaks or seepage.
Re: How long is a reusable fluid pan gasket supposed to last? [Re: Silverado12] #5245749 10/21/19 08:24 AM
W
WyrTwister Offline
W
That was one point I was thinking about . If the bolts are over tightened , the pan , metal around the bolt holes , may become distorted . And not seal correctly .
Wyr
God bless
Re: How long is a reusable fluid pan gasket supposed to last? [Re: Kira] #5245872 10/21/19 10:23 AM
P
P
It's a steel shim encapsulated with with rubber. It also has plastic grommets in the bolt holes to prevent over tightening.
Re: How long is a reusable fluid pan gasket supposed to last? [Re: perfect_oil] #5245937 10/21/19 11:37 AM
slacktide_bitog Offline
I don't know. I just drain with the drain plug smile
The good news is that Dorman makes an aftermarket transmission pan for your 4T65E that has a drain plug, making future ATF changes much easier, so you will never have to worry about reusing the gasket again smile
Re: How long is a reusable fluid pan gasket supposed to last? [Re: atikovi] #5246067 10/21/19 01:10 PM
N
nascarnation Offline
N
GM proved in the 80s (via a ton of warranty cost) that RTV (even applied by robots) is a poor substitute for a good gasket design.
Re: How long is a reusable fluid pan gasket supposed to last? [Re: perfect_oil] #5246070 10/21/19 01:13 PM
N
N
At Allison we determined that's the right way to go with a stamped pan...except the crush spacers need to be steel to be durable and take the load. Of course the elastomer has to be good stuff to take the heat. These days China can produce many kinds of substandard quality.
Re: How long is a reusable fluid pan gasket supposed to last? [Re: nascarnation] #5246091 10/21/19 01:30 PM
A
atikovi Offline
A
Can't compare 80's chemistry to today.
