2004 Cummins 480 CE Marine Engines
CT
So I did some oil samples on a boat we are looking to purchase. It has dual Cummins 480 CE 8.3 engines. This was one of the results I got back. The mechanic seems to think the high iron content is because the boat sat for several months and was started multiple times to show people at the slip but never completely warmed up or run. Oil was over a year old. What are your thoughts? Really nice boat and want to make it work but also do not want to be doing a motor in several months. It seems Polaris Labs ear on the cautious side versious other labs like HO Penn. Thoughts?
I am not sure how useful a UOA is for an engine that been sitting for awhile, started a few times but not really run. You also don't know much for sure. They can say anything that want about the oil but take all that with a grain of sand.
UOA are basically for trending on engines you own or manage.
Originally Posted by bullwinkle
How was the result for the other engine? If it was caused by cold starts, shouldn't it be the same?
yes virtually the same
When the sample was taken the engine were warmed up to operating temp and then taken but prior to that the engines were started and shut down multiple times over a series of months.
Anything alarming you guys see on these or does it sound accurate?
Might as well through this in the mix as its all part of the package. This is the Generator oil sample. Same situation hasnt been running consistently for a long time and allowed thermal cycles. Sounds fine, runs fine. thoughts
[Linked Image]
I would wonder if Cummins would be the best resource for answers in this case. Pricey engines !! I don't even want to think about the cost of the Boat !!! I saw the trans uoa . Are there service records?
I tend to agree with this reply. In 2016 I bought a 2005 Sea Ray that had the Cummins 480CE engines (~800 hours on each) and an Onan genset. I paid the local Cummins dealer to perform an engine survey, which included UOAs. The UOAs were worthless because the oil only had a few hours on it. I bought the boat and used it for three years, doubling the engine hours before selling the boat a year ago.
As for the boat in question, the mechanic's speculation about the high iron seems a bit dubious, but who knows? Weigh all the evidence you've accumulated about the condition of the boat before deciding the roll the dice. I wish you good luck.
Originally Posted by jmichels
[Linked Image]
Star Board Engine
I liked the suggestion for the Analytical Ferrogram. More information would help make a good purchase decision. 133 ppm of Iron would trigger me to make an oil change, but isn't excessive.
No Lead in the sample is a good sign there is no bearing distress.
No water in the sample is a good sign.
[Linked Image]
Star Board Engine
So would you say its just old oil and a lot of dry starts?
Thanks. How did you like the boat? What model was it. Why did you sell?
[Linked Image]
Star Board Engine
The high Iron and Copper may indicate old oil. I don't suppose the seller had a log book telling how many hours at the last oil change?
I was hoping that the analytical ferrogram would say it's a lot of iron oxide, so would probably be surface iron coming off the cylinder liners.
[Linked Image]
Star Board Engine
Unfortunately no log book. The owner only had the boat almost 2 years. When the mechanics changed the oil they said it looked very dirty and old , especially the gear oil in the transmissions. Im hoping that's all it was. Unfportunately though there is no way to get 50 hours on the boat and retest for survey purposes so I have to make a judgement call to proceed or not. Thats where I am torn.
That's already planned for however short of doing a compression test Im not sure how they would really know whats going on inside if all specs are inline
