Originally Posted by atikovi
So the TW you apply to a dry car and wipe off with a towel while the Meguiar's you apply to a wet car, spray off with a hose (after initial application) and then dry the water off. Are there advantages for either of these techniques? I've only used the Meguiar's maybe 3 or 4 times and will run out soon. Thinking of trying the TW. Even if you dry the car first, there are always some places water hides and will drip out on the paint while wiping. Is this a problem if the towel get wet while applying the TW?
Having used both, I liked the Turtle Wax far far better. And no, the water doesn't hurt it as long as it isn't excessive
