My gallon can of WD40 states you should "agitate contents before using". When I put it in a clear dispensing bottle I can see a white cloudy substance in the bottom before shaking. What is that stuff?? Thanks. Later, Rick.
Hard to say. Isn't WD-40 one of those products that is comprised of a list of special, "secret ingredients", that stays locked away in a safe, much like the formula for Coca-Cola?
The Unicorn tears are settling to the bottom and not correctly blended with the snake oil. As per directions, agitate to properly mix contents. I use obscenities to properly agitate things in my garage.
