Ok, in typical fashion I left it for the last minute... I'm actually not that worried, one frost prediction for tonight and then it warms up again. All the same: I'm confused.
I've never had a sprinkler system, but I know it needs to be drained. So google to the rescue. All the info I come across talks about the anti-drainback valve on the outside of the house, with a pair of test ports. I don't have one, it seems. Inside the house there is a line off the water tank, a ball valve, then a simple one-way valve. Then the pipe goes up (I have a full basement), through the wall to the outdoors. Before it drops down to the ground there is a spigot. It then goes out to the control boxes where I see the valves for the seven zones (but no drain spigot). I don't see any fancy thing outside of the house.
I'm guessing I can hook up my air compressor to that spigot outside, select a zone, pressurize it to blow out the water, that seems simple enough. But am I missing something here?
