Quickjack BL-7000EXT
by The Critic - 11/18/19 08:27 PM
'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Looking for a soft riding car
by Nayov - 11/18/19 04:00 PM
Do you use one filter brand or many?
by wemay - 11/18/19 02:43 PM
ATV engine oil
by supton - 11/18/19 02:02 PM
10w30 HDEO or 15w40, others. What's in your engine?
by 53' Stude - 11/18/19 01:47 PM
GM dealer oil change: Who makes their oil?
by Benzadmiral - 11/18/19 01:45 PM
Don't Fix Your Car!
by Y_K - 11/18/19 01:18 PM
best LL01 oil (for F10 M5/S63Tu)?
by vafan13 - 11/18/19 12:55 PM
Stripped oil pan
by dosmom - 11/18/19 12:35 PM
spiffy63, WhiteMega1227, ak2az, vafan13, Breezeknees
69908 Registered Users
123 registered members (2010Civic, 01rangerxl, 14Accent, 4WD, 92saturnsl2, AndyB, 10 invisible), 1,938 guests, and 18 spiders.
Topics297,608
Posts5,119,102
Members69,908
Most Online3,589
Nov 2nd, 2019
Using a trim router for cutting sheetrock #5244479 10/19/19 07:09 PM
J
JLawrence08648 Offline OP
J
I have 2 routers, a larger corded router that needs two hands, and a smaller lighter Ryobi 18v hand held router.
Can I use the latter for cutting holes in sheetrock? What bit?
I will not buy a Roto-Zip or similar cut off tool.
Re: Using a trim router for cutting sheetrock [Re: JLawrence08648] #5244497 10/19/19 07:39 PM
P
P10crew Online Content
Online Content
P
Yes it will work. You can buy the same bit for a router.
Re: Using a trim router for cutting sheetrock [Re: JLawrence08648] #5244540 10/19/19 08:33 PM
R
Rand Offline
R
a 10$ drywall saw works pretty good, how many holes we talking about.
I would be worried about blowing up your router with it sucking in the dust.. plus a huge mess.
How about an oscillating multitool?
Re: Using a trim router for cutting sheetrock [Re: Rand] #5244618 10/19/19 10:52 PM
B
Blaze Offline
B
Quote
I recenty bought one for another project but cant wait to try it out for an upcoming sheet rock project.
Re: Using a trim router for cutting sheetrock [Re: JLawrence08648] #5244655 10/20/19 02:16 AM
F
FT92 Offline
F
it will work but a lot of dust
Re: Using a trim router for cutting sheetrock [Re: FT92] #5244670 10/20/19 04:05 AM
demarpaint Offline
+1
God Bless Our Troops
Re: Using a trim router for cutting sheetrock [Re: JLawrence08648] #5244718 10/20/19 06:21 AM
J
J
Sheetrock dust is such a killer wet/dry vacuums have a special filter they want you to buy to save the motor.
I have the smaller router it for smaller less powerful jobs, grab it and go. It was free with a Ryobi battery and charger purchase or vice versa.
I don't need to use it. Just seems from the videos with spiral cut out tools you get really nice straight edges and it's fast.
Re: Using a trim router for cutting sheetrock [Re: JLawrence08648] #5244751 10/20/19 07:09 AM
M
maxdustington Offline
M
I've vacuumed probably hundreds of pounds of drywall dust with a Ridgid vacuum and the filter that comes with it. You needn't anything special to protect the motor. It is destructive like any fine abrasive dust, but that's what the vacuum is for.
Get a drywall square and a 19mm Olfa, or a 3 1/2" holesaw for potlights. Those and a drywall saw are all you need.
Scoring with a straight edge will give you a straight edge. No need for any fancy tools.
97 GMC RCLB K2500LD L30/4L60
99 Toyota Tercel CE 5EFE/C151
Re: Using a trim router for cutting sheetrock [Re: JLawrence08648] #5244809 10/20/19 08:24 AM
J
JetStar Offline
J
If you are hanging a lot of drywall, then a roto-zip or similar makes sense. Fast and perfect cuts every time. I don't think they work well with the blue plastic boxes. I usually use the beige fiberglass boxes.
2019 Road King Special
2018 Kawasaki Z900RS
2016 Suzuki DR650
2015 Road Glide
1978 Suzuki GS1000 (now 1085)
Re: Using a trim router for cutting sheetrock [Re: JLawrence08648] #5244817 10/20/19 08:36 AM
M
M
https://www.amazon.ca/Calculated-Industries-8105-Drywall-Electrical/dp/B00YX8KZGO
If you have a lot of boxes consider acquiring one of these kits. I've never seen them used but I've been tempted to pick them up. I am decent at measuring, but they could save a lot of time and amplify your abilities.
Re: Using a trim router for cutting sheetrock [Re: JLawrence08648] #5244939 10/20/19 11:30 AM
B
benjy Offline
B
being a retired pro i like the shark saw, just gotta measure good! roto zip type tools can be faster but theres a learning curve + a lotta dust + of course a utility knife for fast cut-snap straight cuts. prolly some vids on that but it too like anything takes practice. of course a drywall screw gun is best for fastening in either metal suds we used on construction or "dead wood" typical in house work! i laugh at myself as i did my old hose with a typical wood saw + keyhole saw, it dot done but today i would be much faster + efficient after 30 yrs as a pro carpenter doing mostly drywall many did not want because is it was heavy, usually fire rated 5/8" 10 + 12 feet long + production was key for getting more jobs from various contractors!!
