'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Looking for a soft riding car
by Nayov - 11/18/19 04:00 PM
Do you use one filter brand or many?
by wemay - 11/18/19 02:43 PM
ATV engine oil
by supton - 11/18/19 02:02 PM
10w30 HDEO or 15w40, others. What's in your engine?
by 53' Stude - 11/18/19 01:47 PM
GM dealer oil change: Who makes their oil?
by Benzadmiral - 11/18/19 01:45 PM
Don't Fix Your Car!
by Y_K - 11/18/19 01:18 PM
best LL01 oil (for F10 M5/S63Tu)?
by vafan13 - 11/18/19 12:55 PM
Stripped oil pan
by dosmom - 11/18/19 12:35 PM
HyunKia Wix 51334XP $6.73 @ Amazon
by SlavaB - 11/18/19 12:18 PM
spiffy63, WhiteMega1227, ak2az, vafan13, Breezeknees
69908 Registered Users
135 registered members (92saturnsl2, 4WD, ARB1977, ABerns, 2015_PSD, alchargo, 13 invisible), 2,005 guests, and 24 spiders.
Topics297,607
Posts5,119,056
Members69,908
Most Online3,589
Nov 2nd, 2019
School me..1200 amp jumper #5244440 10/19/19 06:19 PM
Schmoe Offline OP
Got a 1200 amp portable battery jumper. Now, if i connect a low amp 12V oil pump, the kind with alligator clips you connect to a 12V battery, would it blow it up? I mean, i can connect that jumper to my seadoo which uses less amps and works fine. If I'm way off here electronically, be GENTLE!!! I mean like connect alligator clips to jumper cables and turn it on.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: School me..1200 amp jumper [Re: Schmoe] #5244445 10/19/19 06:25 PM
R
Rand Offline
R
depends. also 1200amp jumper means nothing.. some of these companies would rate an AA battery 500 amps.
Re: School me..1200 amp jumper [Re: Schmoe] #5244451 10/19/19 06:29 PM
Schmoe Offline OP
It's one if those Stanley models from walmart.
06 Accord EX-L V6
2018 CRV EX-L
Re: School me..1200 amp jumper [Re: Schmoe] #5244463 10/19/19 06:40 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
The supply needs to match the load, and vice-versa. You can’t push 1200A through a load too resistive to take it. 1200A is practically laughable, that’s a ton of current and so it’s a peak instantaneous supply under some ideal condition.
I highly doubt that your jumper has enough ENERGY to run an oil pump for any appreciable amount of time. These things are designed to provide peak pulsed power for a few seconds, and anything else is the equivalent of a USB port 5-10W.
Re: School me..1200 amp jumper [Re: Schmoe] #5244473 10/19/19 06:58 PM
Schmoe Offline OP
That's what i was thinking, peak energy supply for a short period.
06 Accord EX-L V6
2018 CRV EX-L
Re: School me..1200 amp jumper [Re: Schmoe] #5244492 10/19/19 07:27 PM
R
Rand Offline
R
btw: what is a low amp 12volt oil pump exactly?
Re: School me..1200 amp jumper [Re: Schmoe] #5244505 10/19/19 07:47 PM
Dave9 Offline
No you won't blow it up. Voltage pushes current through this resistive load, not the other way around, so your ~12V supply merely has to be capable of the current the load (the pump) draws at 12V. It could have infinitely high amperage and not hurt anything.
1200A is a fictitious number, years ago they would have rated (practically) the exact same jump starter pack closer to 400A but then the (insert low quality foreign country here lol) generics came along and change the game by lying about true amperage, so everyone else started using dubious rating systems too.
You can probably run the pump for quite a while from that battery pack. Something rated for 1200 faux-amps, at least from a major brand, probably has at least a 20Ah battery in it, so at least a few hours but don't drain it too low if it's lead acid or you'll hurt its lifespan.
Re: School me..1200 amp jumper [Re: Schmoe] #5244533 10/19/19 08:25 PM
P
Papa Bear Offline
P
1200 amps @ 12 volts dc is 14,400 watts (babycakes) - that's a lot of heat in a hurry hide
2016 Dodge GC Deep Cherry 5W-30 Dino
2013 SYM Wolf Classic 150 T4 15W-40
2009 V-Star 250 Black Cherry 20W-50 Dino
https://www.hogsforhospice.com/
Friend of Bill W. since '89
Re: School me..1200 amp jumper [Re: Schmoe] #5244590 10/19/19 09:47 PM
KJSmith Offline
If you put a inline fuse sized for the load you will be fine.
Re: School me..1200 amp jumper [Re: Schmoe] #5244624 10/19/19 11:34 PM
Chris142 Online Content
Online Content
It will only put out as many amps as required. Up to 1200. If your 12v accessory only uses 5a that's all it will put out.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: School me..1200 amp jumper [Re: Schmoe] #5244732 10/20/19 06:43 AM
J
joegreen Offline
J
The pack won't push 1200a into the oil pump. Think of the jump pack as a Walmart and the oil pump as a person. The oil pump goes into Walmart and buys what it needs. Walmart does not force the oil pump to buy every item. Therefore if the oil pump needs 10a of current that is all it will draw out of the 1200a reserve.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: School me..1200 amp jumper [Re: Schmoe] #5244749 10/20/19 07:06 AM
T
thastinger Offline
T
It'll work just fine.
Keep in mind that these jump boxes have a 12V 20AH battery inside them (some have 16AH batteries inside), so the capacity is not large to run significant loads for very long
Re: School me..1200 amp jumper [Re: Chris142] #5244793 10/20/19 08:07 AM
A
alarmguy Offline
A
^^that^^
How many amps a power source can deliver means nothing in your case, 12 volts DC is 12 Volts DC you can have a source capable of 12,000 amps at 12 volts, makes no difference.
Example, you plug in a 110 volt 7 watt led light bulb in your house on a 20 amp circuit, the light bulbs draws 0.0636 Amps and 7 watts even though the source can deliver 20 AMPS and 2,200 watts,
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: School me..1200 amp jumper [Re: Schmoe] #5245483 10/20/19 09:33 PM
Schmoe Offline OP
Thanks...good education.
06 Accord EX-L V6
2018 CRV EX-L
Re: School me..1200 amp jumper [Re: alarmguy] #5245706 10/21/19 07:39 AM
Dave Sherman Offline
^^that^^
X3. It can deliver UP TO 1200 amps. The battery in your car can deliver hundreds of amps to power a high-current load like the starter. The keyless entry system is running off the same battery constantly, but it only takes a very small current (maybe 0.05 amp) because that's all it needs to power the radio receiver.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
