Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
34 registered members (bbhero, 3311, blufeb95, ArrestMeRedZ, carlprop, 4 invisible), 999 guests, and 22 spiders.
Topics301,684
Posts5,200,462
Members70,756
Page 1 of 3 1 2 3
Hyundai Engine Oil Selection #5243910 10/19/19 06:17 AM
STIcandy Offline OP
HI all! I've been lurking around here for a while now looking for some answers.
I have a 2013 Hyundai Santa fe limited with the DI Lambda 3.3L V6 bought brand new in 2013. The first 100k kms on the car the oil was changed by the dealer with conventional oil at 6000km/6 month intervals as they required under the "Severe operation" maintenance schedule. It now has 123,000 kms on it and sees very short (10kms x 2) daily drives.
I have extended warranty on the vehicle to 160k so I still have to maintain the 6k/6month OCI. The biggest [censored] off is that even though I'm a licensed car and truck mechanic, the [censored] aftermarket warranty contract specifically states no DIY maintenance. I've fought with them to no end about this but they're not budging. Consequently I find my self wondering how well this warranty is going to go... But that's another story.
The more I've been reading, the more I've discovered what I believe is the timing chain tensioner rattle for 2-3 seconds on start up that has plagued the Hyundai v6 for years. I've been using OEM filters with Motul xclean 5W-30 since I took over the oil changes. Mainly because I'm running the 5W-40 Variant it in my Subaru STI and get it for $45 CAD/5L jug taxes in.
So my question is this. I have an impending oil change on the Santa fe and am contemplating my next move. Should I consider switching back to conventional Quaker State 5w-30 that the manual suggests? Maybe the synthetic oil is allowing the tensioner to bleed down? Too thin? The manual also states I can go to a 5w-40 under my climate. Should I try that Motul oil? Go to conventional 5w-40?
My biggest concern is with winter coming I'm not sure weather the 5W-40 will be too heavy or not. I know the 5W is the winter viscosity but 40 is a thicker oil regardless of how you spin it.
You guys are the pros here. Give me some input!
Re: Hyundai Engine Oil Selection [Re: STIcandy] #5243915 10/19/19 06:26 AM
skyactiv Offline
In my observation on here, Canadians tend to be more worried about viscosity and want to run a thicker grade than Americans. I'd use 5W30 in your Hyundai. I've never seen a conventional 5W40.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Hyundai Engine Oil Selection [Re: STIcandy] #5243940 10/19/19 07:05 AM
W
walterjay Offline
W
I have used 5-30 Quaker State syn in my 3.3 for 160,000 miles and the engine runs great and sounds like new.
Re: Hyundai Engine Oil Selection [Re: skyactiv] #5243941 10/19/19 07:06 AM
STIcandy Offline OP
Come to think of it you are right. I've never seen a conventional 5w-40 either. Do you think I should consider going back to a conventional oil?
Re: Hyundai Engine Oil Selection [Re: STIcandy] #5243945 10/19/19 07:14 AM
donnyj08 Offline
I would say stay synthetic and go with a 5w30. The price difference is so small these days. It’s also getting harder to find a true conventional oil these days.
If you choose to go conventional in the 5w30 grade it’s will likely be a blend anyway.
2008 Silverado LT Z71 99k PP 10w30
2016 Tucson Limited 1.6T AWD 32k M1 5w30 AP
2016 Yamaha XSR900 13k, Spectro 10w40, Yamaha Filter.
Re: Hyundai Engine Oil Selection [Re: STIcandy] #5243953 10/19/19 07:20 AM
L
Linctex Offline
L
I'd run a full synthetic 0W-30 in the winter and a conventional 5W-30 in the summer.
Re: Hyundai Engine Oil Selection [Re: STIcandy] #5243980 10/19/19 07:47 AM
G
Gebo Offline
G
You could always go back to the conventional Quaker State 5W-30 for one OCI and see if the noise disappears. Your OCI's are so short (and I love it!) you probably aren't getting any "real" advantage with the "full" synthetic. At least you would know if your oil is causing the noise.
Different oils will make the engine sound differently. Some really good oils will give some of my engines rattles. Sometimes, it seems oils high in moly will quieten engines.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Hyundai Engine Oil Selection [Re: STIcandy] #5243981 10/19/19 07:48 AM
B
bullwinkle Offline
B
You've hit the nail on the head as to why I would never buy an aftermarket extended warranty. Does Hyundai Canada have the 10 year/100,000 mile (roughly 161K KM) powertrain warranty that we have here in the USA? I think I would at least have a talk with my Hyundai dealer about the timing chain/tensioner noise-if it's like the modular Ford tensioners, it's not going to get better, although a silicone ADBV oil filter can help. Unless it's a cartridge filter. I'm sold on the Castrol Magnatec synthetic oil in both 5W20 & 0W20, it's the real deal for a long chain engine.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Hyundai Engine Oil Selection [Re: STIcandy] #5244039 10/19/19 08:54 AM
Ded Mazai Offline
I'd run 5W-40 in that car. In your area you will never see even -30 degrees in the winter. Even 10W-40 would be fine.
BRZ | M1 HM 5W-20, FU | PZ Synchromesh.
Re: Hyundai Engine Oil Selection [Re: bullwinkle] #5244056 10/19/19 09:08 AM
STIcandy Offline OP
In Canada it's 5yrs 100k kms (60k miles). Extended warranty takes it to 8 yrs 160k kms. I know I got suckered into the warranty. The bs part is the dealer sold me an aftermarket warranty at point of sale brand new! First and last time I'll ever buy this.
Unfortunately it's a cartridge style filter which I personally believe is half the problem. It doesn't have an adbv in the filter. I'd like to convert it to a spin on if anyone has any sources for that.
Re: Hyundai Engine Oil Selection [Re: STIcandy] #5244082 10/19/19 09:46 AM
M
Mad_Hatter Offline
M
I have the 3.8L Lambda V6 with the same start up rattle. It effects certain 3.3L & 3.8L Lambda engines. It's the hydraulic tensioner.. it takes a couple seconds for the oil pressure to build then the sound (slack) goes away. It seems to be the loudest at startup after the engine has sat for a long period (drain down). There's a TSB on it you can Google. Basically the TSB says it's considered "normal" unless the sound persists beyond like 90sec.
Over 160k+ miles I've ran dino, dino blend and full syn. The engine sound always goes away for me in the 2~3sec you described and I've not found a difference, that i could tell, in startup noise from a Xw20 to Xw30. I does seem, from my calibrated ear, that the engine runs quietest on the thicker Xw30 lubes than the 20 at operating temp.
Fwiw everything in the TC assembly on mine is still OE and the oil filter doesn't show any metal shedding even after 164k miles, and I've always kept my oci's to a 4~5k max.
Btw... can't you get a refund for the unused term of the extended warranty??? Obviously in the future never buy an aftermarket warranty.. and rolling it into the financing is doubly insane.
Re: Hyundai Engine Oil Selection [Re: Mad_Hatter] #5244125 10/19/19 10:49 AM
STIcandy Offline OP
Nope. I missed the widow on getting the money for the warranty back. I did mention the rattle to Hyundai and they kept it overnight. Once they heard it they told me it's likely the tensioner(s) and/or the cam phasers. Regardless the extended warranty company requires me to authorize the tear down and inspection and only if they find visual conformation of failure they'll replace it and cover the repair. The advisory basically told me this happens with all of them and they won't find any problems visually and I'll be on the hook for the repair.
I'm basically at the point of saying screw it and I'll do my own maintenance and ditch the warranty with a lesson learned. I mean for crying out loud I have a hoist in my garage with the required mechanics licenses but I can't change my own oil!!!
I'm thinking I might throw it up today and change the oil and filter to QSGB and drive it for the next week myself (I'll put 600kms on it). If there's no change I'll dump and fill back up with my synthetic and ride it out. Maybe consider the 5w-40 I have here. It's encouraging that you have the mileage on yours that you do.
Re: Hyundai Engine Oil Selection [Re: STIcandy] #5244183 10/19/19 12:02 PM
M
Mad_Hatter Offline
M
Yeah.. and that tear down is gonna lighten the wallet a bunch..screw that. At least the service advisor was honest with ya on how that would shake out. I'm sure he knows about the TSB and the warranty company knows about the TSB, so it would be a total scam to do the tear down. What a drag man.. sorry you're stuck in a shi##y deal. Honestly, I couldn't fault you for just saying the eff' with the extended warranty and doing the maintenance yourself at this point. Just do those oil changes on time and hopefully you'll have similar luck that I've had. That's the only thing I've done. I've not been particularly brand loyal, only make sure I use a Xw30 and keep the oci's under 5k like I mentioned... that's about it.
Re: Hyundai Engine Oil Selection [Re: STIcandy] #5244351 10/19/19 03:51 PM
STIcandy Offline OP
Thanks for the advice everyone! I'll post back on how I make out while experimenting with oils for anyone who may be interested.
Re: Hyundai Engine Oil Selection [Re: walterjay] #5244418 10/19/19 05:54 PM
ChrisD46 Offline
*I would run QSUD 5W30 as well ...
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Page 1 of 3 1 2 3
