"Universal" electric coolant circulation pump
by Superflan - 11/14/19 07:32 AM
Thermostat question
by nicholas - 11/14/19 07:13 AM
why michelin changed their tire lineup?
by edwardh1 - 11/14/19 07:12 AM
how do you mark your name on key fob?
by edwardh1 - 11/14/19 07:08 AM
"New EV Battery Can Charge in 10 Minutes..."
by wemay - 11/14/19 05:52 AM
TDS review
by Espada - 11/14/19 03:30 AM
SD40 Guide Rod ?'s
by GumbyJarvis - 11/14/19 01:08 AM
How many steps a day are you getting?
by P10crew - 11/14/19 12:45 AM
Pics - Top Piston Cleaning - Lexus CT200h
by KerryB - 11/14/19 12:14 AM
Valvoline Full Synthetic Maxlife 10w30
by KerryB - 11/13/19 11:38 PM
Toyota 1MZ-FE burning lots of oil
by Speedinsweede - 11/13/19 11:27 PM
Castrol Magnatec
by dosmom - 11/13/19 10:51 PM
How do you feel about buying tires with different DOT's?
by Speedinsweede - 11/13/19 10:23 PM
Toys for the Caprice
by ls1mike - 11/13/19 09:08 PM
7.62x39 AR anyone?
by sw99 - 11/13/19 09:07 PM
Chrysler EcoDiesel Class Action Suit
by JeffKeryk - 11/13/19 07:45 PM
2015 Mazda 6 Auto-RX rinse Castrol EDGE 0W20
by bulwnkl - 11/13/19 07:45 PM
Where's Trav 2.0?
by user52165 - 11/13/19 07:20 PM
Siphoning Fuel
by Spetz - 11/13/19 06:34 PM
AGM vs Traditional Battery
by jayjr1105 - 11/13/19 06:07 PM
PaulDouglas, DanF350man, Jasonoff, Speedinsweede, JeffS
69856 Registered Users
87 registered members (4WD, Andrei, alarmguy, 53' Stude, b1amgm47, AZjeff, 6 invisible), 1,895 guests, and 17 spiders.
Topics297,389
Posts5,114,517
Members69,856
Most Online3,589
Nov 2nd, 2019
Titan oil filter mount #5243773 10/18/19 09:49 PM
AZjeff Online Content OP
OP Online Content
2nd OC on the Titan and this time I had my phone handy to take a pic of the oil filter mount. First vehicle I've owned with an elaborate assembly to attach an oil filter. Seems odd to not have a lip to contain the gasket. The filter sits at a 45 degree angle and is easy to get to after removing a splash shield. Oil used is 7 quarts of QSUD 0w-20 with a NAPA Gold 7356. Lots of oil and a little filter. First OC was at 1k miles, this one at 5k. Might get a UOA at 10k and the oil was pretty dark as you can see.
[Linked Image]
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Titan oil filter mount [Re: AZjeff] #5243774 10/18/19 09:56 PM
clinebarger Offline
That's the Oil Cooler, I don't recall a lip to contain the gasket on any modern vehicle as that's the filters job.
2001 Chevy Camaro L92/4L80E
Re: Titan oil filter mount [Re: AZjeff] #5243776 10/18/19 09:58 PM
OP Online Content
It seems like most filter mounts on the block have a lip outside the gasket from the machining. Thought it might be the cooler.
Re: Titan oil filter mount [Re: AZjeff] #5243780 10/18/19 10:04 PM
clinebarger Offline
Small Block Chevies had a recessed oil filter pad, But didn't have anything to do with gasket support. Just the way it was cast & machined.
Re: Titan oil filter mount [Re: clinebarger] #5243885 10/19/19 05:22 AM
Convert Offline
2013 Toyota Tacoma 4lt. Has a lip on the oil filter / cooler housing .plus a drain hole to attach a hose
TOMB
TOMB
2006 Volvo XC90
2013 Toyota Tacoma TRD Sport
1976 Moto Guzzi Convert
Re: Titan oil filter mount [Re: AZjeff] #5243939 10/19/19 07:02 AM
T
thastinger Offline
T
Wife's Armada calls for 5-30. After many UOAs with many different brands/weights of oils, engine really likes M1 Euro 0-40, I use the M1 110 filter.
Re: Titan oil filter mount [Re: AZjeff] #5243942 10/19/19 07:07 AM
PimTac Offline
I’ve never had a vehicle with a lip on that part. Always smooth and machined.
Is that stamped steel?
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Titan oil filter mount [Re: clinebarger] #5243948 10/19/19 07:17 AM
L
Linctex Offline
L
That's a pretty fancy stacked-plate oil cooler.
Same here.... I have never seen any "Lip"....
and I AM GLAD,
...because I generally will spin on a larger filter (if it will fit).
Re: Titan oil filter mount [Re: PimTac] #5243951 10/19/19 07:19 AM
L
Linctex Offline
L
The threaded nipple appears to be the only steel part.
Everything else looks to be aluminum.
Re: Titan oil filter mount [Re: Linctex] #5243975 10/19/19 07:42 AM
PimTac Offline
You are probably right. My Mazda looks like aluminium but it’s thick and machined. I would be careful to not gouge that mating surface, especially on this stamped version.
2017 Mazda CX5
Roki OEM filter.
Re: Titan oil filter mount [Re: AZjeff] #5244101 10/19/19 10:21 AM
OP Online Content
Thanks for the replies. The assembly is all aluminum. A larger filter won't fit, wish it would, and not sure how it would ever get gouged but I'll be careful.
Re: Titan oil filter mount [Re: AZjeff] #5244128 10/19/19 10:55 AM
E
Elkins45 Offline
E
My 2019 Ford Fiesta also has an oil cooler assembly where the filter mounts. It looks a lot like that.
The only thing I dislike about the Titan is that you have to loosen all those bolts to remove the plastic shield. It makes removing the filter more work than I’m used to. Nissan should have installed a hatch for filter access.
