Toys for the Caprice
by ls1mike - 11/13/19 09:08 PM
7.62x39 AR anyone?
by sw99 - 11/13/19 09:07 PM
Chrysler EcoDiesel Class Action Suit
by JeffKeryk - 11/13/19 07:45 PM
2015 Mazda 6 Auto-RX rinse Castrol EDGE 0W20
by bulwnkl - 11/13/19 07:45 PM
Where's Trav 2.0?
by user52165 - 11/13/19 07:20 PM
Siphoning Fuel
by Spetz - 11/13/19 06:34 PM
AGM vs Traditional Battery
by jayjr1105 - 11/13/19 06:07 PM
Mail in mailbox notification devices
by atikovi - 11/13/19 05:46 PM
Canned marinated artichoke hearts, good or bad?
by atikovi - 11/13/19 05:35 PM
Shattered glass
by bdcardinal - 11/13/19 05:11 PM
Oil filter Cutter, Pet Peeve
by 10ecfarmer - 11/13/19 05:05 PM
Reducing radiator air flow during winter
by Backstache - 11/13/19 04:30 PM
Mower thrown to the curb..
by Eric Smith - 11/13/19 04:29 PM
valve body torque difference
by HyundaiAbuser - 11/13/19 04:07 PM
Mahle OC 142 oil filter
by Fattylocks - 11/13/19 04:03 PM
12 Toyota Tacoma 2.7L 4cyl. 90,000 mi. M1 0W-20 EP
by wagsrk08 - 11/13/19 03:29 PM
Seeking Battery Charger Advice
by lancerplayer - 11/13/19 12:46 PM
2019 Consumer Reports Tire Tests
by SubLGT - 11/13/19 11:07 AM
2020 Camaro LT1 V8, Wow.
by dareo - 11/13/19 11:01 AM
PaulDouglas, DanF350man, Jasonoff, Speedinsweede, JeffS
69856 Registered Users
96 registered members (AdRock, 69Torino, 92saturnsl2, 2015_PSD, 12 invisible), 2,143 guests, and 19 spiders.
Topics297,372
Posts5,114,282
Members69,856
Most Online3,589
Nov 2nd, 2019
Milesyn SB 5w-30, 5100 miles, 07 Sienna V6 #5240419 10/15/19 03:53 PM
R
RayCJ Offline OP
R
This is Milesyn 5w-30 Synthetic Blend used for 5100 miles, all short trips between 5-10 miles in a 2007 Sienna V6 2GR-FE over a 6 month duration.
Vehicle is single-owner with 5-6k synthetic blend OCIs since day one. This UOA represents additives of 3oz LiquiMoly #2009 and 0.33oz (10ml) Max ZDDP. Oil capacity is 6.2 quarts. Filter was a Fram Ultra. Replacement oil was identical to above. Next spring, maybe I'll toss in a quart of 5w-40 to keep the viscosity in check.
Re: Milesyn SB 5w-30, 5100 miles, 07 Sienna V6 [Re: RayCJ] #5240439 10/15/19 04:20 PM
W
wemay Offline
W
Even if the viscosity thinned out, wear metals look great. I wouldn't change a thing.
2018 KIA Sportage LX AWD
MSS 5W30, PL14459
Next: MSHM 5W30, ST9688
2013 Hyundai Santa Fe Sport 2.0T
M1AP 5W30, OEM
Next: Same oil, ST9688
Re: Milesyn SB 5w-30, 5100 miles, 07 Sienna V6 [Re: RayCJ] #5240463 10/15/19 04:38 PM
demarpaint Offline
Looks good to me.
God Bless Our Troops
Re: Milesyn SB 5w-30, 5100 miles, 07 Sienna V6 [Re: RayCJ] #5240529 10/15/19 05:32 PM
PimTac Offline
The title of the thread says Milesyn uoa but then we discover that other products were added in. You are not the only one that does this but the analysis doesn’t truly represent Milesyn.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Milesyn SB 5w-30, 5100 miles, 07 Sienna V6 [Re: RayCJ] #5240582 10/15/19 06:02 PM
B
bullwinkle Offline
B
I would like to see the same run without the additional additives, I've thought Miles oil always looked like a pretty good deal. Although I've added a little LM Moly additive myself occasionally.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Milesyn SB 5w-30, 5100 miles, 07 Sienna V6 [Re: RayCJ] #5240600 10/15/19 06:18 PM
A
atikovi Offline
A
Looks like the other thread was locked. Is everybody so sensitive these days that you have to add a smiley face to anything remotely sarcastic?
Re: Milesyn SB 5w-30, 5100 miles, 07 Sienna V6 [Re: RayCJ] #5241398 10/16/19 01:12 PM
B
BKTX Offline
B
I have used about 25 qts of Milesyn Synthetic Blend 5W20 over past 1.5 years and oil analysis showed good results.
00 Windstar
04 Camry
08 MDX
12 MKZ
16 Corolla
Re: Milesyn SB 5w-30, 5100 miles, 07 Sienna V6 [Re: RayCJ] #5241441 10/16/19 01:48 PM
R
RayCJ Offline OP
R
FWIW: To the best of my recollection, I've been using Milesyn in 5 gallon pails for about 7 years if not longer. Several years ago, 5 gallon buckets of the synthetic blend was about $42 and full synthetic was running about $64. I purchased several each in two different grades (0-20 and 5-30). With 5 cars in the family, each requiring 2-3 OCs per year, I go thru 12-15 gallons a year. I don't bother paying extra for TBN results because at 5000 miles it's 2.1 and at 6500 miles it's at 1.8. It's my personal choice that I like to pump-up the Zinc, Phosphorous and Moly a tiny bit.
The price of Milesyn has steadily increased. I just used the last of my 5w-30 and bought a couple cases of Costo Prime brand for the last 3 cars that will need OCs before winter hits. I hate messing with quart bottles though and am hoping to find a sale on Milesyn.
Re: Milesyn SB 5w-30, 5100 miles, 07 Sienna V6 [Re: RayCJ] #5241571 10/16/19 03:50 PM
B
Brons2 Offline
B
I have 24 quarts of this sitting around, waiting for me to go through other oils in my stash. I'd like to see a report without the additives also.
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 5w & 10w30 seasonal, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Dealership Castrol 0w20, Mazda filter.
Re: Milesyn SB 5w-30, 5100 miles, 07 Sienna V6 [Re: Brons2] #5241614 10/16/19 04:48 PM
R
RayCJ Offline OP
R
It will be virtually identical to what's above but the Moly will be very low and phosphorous and zinc will be about 100-150 points lower. Max ZDDP comes with PPM dilution instructions. The 10ml of ZDDP I add is calculated to bump both values about 100-150 PPM. The carrier oil in LiquiMoly is straight 30 oil and 3oz will have no discernible impact on 6.2 quarts of oil.
Here's the VOA info that Milesyn posts. Those were the base values I used to calculate the concentrations. The lab results confirm that my calculations were accurate.
https://mileslubricants.com/product/show/24
BTW: I've posted many other Milesyn UOA's (with additives) here and they're all searchable.
Re: Milesyn SB 5w-30, 5100 miles, 07 Sienna V6 [Re: wemay] #5243661 10/18/19 06:48 PM
M
Mad_Hatter Offline
M
Yeah, I'd agree. It's just a shade under 9.3cSt for being an Xw30. If it bothers you terribly OP, sub a qt of oil for Xw40 or 50 even, or 8~16oz of a VII. But really, there's not much here to lose sleep over...
