Motive power brake bleeder
by Redright9 - 11/14/19 08:25 AM
*GRAPHENE* a new oil-additive????
by cadchris - 11/14/19 08:21 AM
STP mulit purpose motor treatment + fuel stabalizer
by Chris142 - 11/14/19 08:08 AM
"Universal" electric coolant circulation pump
by Superflan - 11/14/19 07:32 AM
Thermostat question
by nicholas - 11/14/19 07:13 AM
why michelin changed their tire lineup?
by edwardh1 - 11/14/19 07:12 AM
how do you mark your name on key fob?
by edwardh1 - 11/14/19 07:08 AM
"New EV Battery Can Charge in 10 Minutes..."
by wemay - 11/14/19 05:52 AM
TDS review
by Espada - 11/14/19 03:30 AM
SD40 Guide Rod ?'s
by GumbyJarvis - 11/14/19 01:08 AM
How many steps a day are you getting?
by P10crew - 11/14/19 12:45 AM
Pics - Top Piston Cleaning - Lexus CT200h
by KerryB - 11/14/19 12:14 AM
Valvoline Full Synthetic Maxlife 10w30
by KerryB - 11/13/19 11:38 PM
Toyota 1MZ-FE burning lots of oil
by Speedinsweede - 11/13/19 11:27 PM
Castrol Magnatec
by dosmom - 11/13/19 10:51 PM
How do you feel about buying tires with different DOT's?
by Speedinsweede - 11/13/19 10:23 PM
Toys for the Caprice
by ls1mike - 11/13/19 09:08 PM
7.62x39 AR anyone?
by sw99 - 11/13/19 09:07 PM
Chrysler EcoDiesel Class Action Suit
by JeffKeryk - 11/13/19 07:45 PM
PaulDouglas, DanF350man, Jasonoff, Speedinsweede, JeffS
69856 Registered Users
100 registered members (4WD, alarmguy, 1978elcamino, 10ecfarmer, 64bawagon, 2015_PSD, 8 invisible), 2,089 guests, and 23 spiders.
Topics297,393
Posts5,114,541
Members69,856
Most Online3,589
Nov 2nd, 2019
John Deere Low Viscosity Hygard vs.Mobil 1 synthetic ATF? #5243609 10/18/19 05:29 PM
V
Vigilant Offline OP
V
Greetings. I have a 2013 John Deere X500 lawn tractor with the Kawasaki Tuff Torq K72B transaxle and currently 271 hours. I have been using John Deere Low Viscosity Hygard trans oil per Deere specs. I have read a few posts here from people who substitute synthetic engine oil for Hygard, but I'm a little nervous about going that route. I do want to cut down on transaxle heat if I can do so without any negative effects on the unit. What are y'awl's thoughts on running Mobil 1 full synthetic ATF in place of Hygard? It would cost a little more, but I don't mind that. Any input you can offer would be appreciated.
Thanks in advance.
2006 F-150 5.4 3V 4X4. M1 EP 5W20, Motorcraft oil filter. Changing to Fram Ultra next oil change.
2006 F-150 4.6 2V 4X2. Same as above.
Re: John Deere Low Viscosity Hygard vs.Mobil 1 synthetic ATF? [Re: Vigilant] #5243613 10/18/19 05:32 PM
B
BlakeB Offline
B
The low viscosity hygard is pretty cheap, $3-$4 per quart where I live. If it isn’t causing any problems I’d just stay with that. You have a 6, going on 7 year old mower. The low vis hygard will most likely keep it going as long as you want to keep it. Just my $0.02...
Re: John Deere Low Viscosity Hygard vs.Mobil 1 synthetic ATF? [Re: Vigilant] #5243616 10/18/19 05:39 PM
B
BlakeB Offline
B
If you have a chevron distributor nearby, I wouldn’t hesitate to use Chevron Synthetic All-Weather THF in place of a J20D oil.
Another J20D thread
Re: John Deere Low Viscosity Hygard vs.Mobil 1 synthetic ATF? [Re: Vigilant] #5243634 10/18/19 06:10 PM
W
walterjay Offline
W
Use what JD specs. You will always know that you are using the correct stuff and you will sleep better. And do you now what the replacement cost is for those trannys?
Re: John Deere Low Viscosity Hygard vs.Mobil 1 synthetic ATF? [Re: Vigilant] #5243643 10/18/19 06:25 PM
G
gman2304 Offline
G
Tuff Torq recommends the JD low vis Hygard for your k72 on their website. I personally wouldn’t use ATF. Having said that, I have used Mobil1 15w50 engine oil in my 1998 K61 and it performs as new with an estimated 2,000 hours, but I’ve never used ATF in it.
Re: John Deere Low Viscosity Hygard vs.Mobil 1 synthetic ATF? [Re: Vigilant] #5243656 10/18/19 06:46 PM
R
Rand Offline
R
The JD fluid is good stuff. I would have swapped over my tractor fleet but they say its incompatible with the org. spec type F ATF fluid..
So since they are 30+ years old I figured if it aint broke dont fix it and just use Type F.
No way would I ever put generic fluid in a JD X500, the JD fluid is not priced overly high.. and a premium product well worth using.
Re: John Deere Low Viscosity Hygard vs.Mobil 1 synthetic ATF? [Re: walterjay] #5243690 10/18/19 07:31 PM
V
Vigilant Offline OP
V
Bout 1500 from what I hear.
Re: John Deere Low Viscosity Hygard vs.Mobil 1 synthetic ATF? [Re: Vigilant] #5243705 10/18/19 07:47 PM
G
gman2304 Offline
G
. $1,840 shipped from Mulligans Parts Company......Ouch!
Re: John Deere Low Viscosity Hygard vs.Mobil 1 synthetic ATF? [Re: Vigilant] #5246539 10/21/19 09:06 PM
cronk Offline
I dont think I'd mess with atf or engine oil. The hygard is good oil, if you really want a synthetic fluid, Amsoil makes one that should work nicely.
amsoil tractor fluid
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
