Originally Posted by Dickl
It was my understanding that there was a "cost savings" change made to these engines....2.0 TFSI.
Initially sounded like with the improvement in machining technology they reduced the piston / cylinder clearance
in order to eliminate or reduce the qty of rings. Supposedly they reverted back to the original design after 2015.
Can you point me to the ring recall notification? The Audi dealer claims no knowledge and says the oil usage in "normal"
Thanks
There was no cost savings. New rings were installed in mid 2012, not after 2015. There was no change in design.
Audi dealer is saying it is normal bcs. it is up to 1qt per 1,000 miles. That could be very well for two reasons:
1. PCV
2. Oil brand/grade. What oil is he using?
From my understanding, those who had done recall had higher consumption. You can find more information on Audizine or similar Audi web forums.
Thanks
1. PCV
