Quickjack BL-7000EXT
by The Critic - 11/18/19 08:27 PM
'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Looking for a soft riding car
by Nayov - 11/18/19 04:00 PM
Do you use one filter brand or many?
by wemay - 11/18/19 02:43 PM
ATV engine oil
by supton - 11/18/19 02:02 PM
10w30 HDEO or 15w40, others. What's in your engine?
by 53' Stude - 11/18/19 01:47 PM
GM dealer oil change: Who makes their oil?
by Benzadmiral - 11/18/19 01:45 PM
Don't Fix Your Car!
by Y_K - 11/18/19 01:18 PM
best LL01 oil (for F10 M5/S63Tu)?
by vafan13 - 11/18/19 12:55 PM
Stripped oil pan
by dosmom - 11/18/19 12:35 PM
spiffy63, WhiteMega1227, ak2az, vafan13, Breezeknees
69908 Registered Users
132 registered members (69GTX, 2010Civic, 01rangerxl, 14Accent, 4WD, 92saturnsl2, 10 invisible), 1,928 guests, and 18 spiders.
Topics297,608
Posts5,119,113
Members69,908
Most Online3,589
Nov 2nd, 2019
Vaccum Oil Extractor #5243254 10/18/19 10:50 AM
A
ad244 Offline OP
A
Hey BITOGERS!
I want to jump on the vaccum oil extractor bandwagon but I dont know where to start really. I suppose i should just pull the trigger on a cheapo from Amazon. I need at least 7qt capacity for the large sump Mercedes in my life.
Any opinions on this one? : https://www.amazon.com/gp/product/B...;linkId=8c1a60ab9710d33e1892b70b2e073df1
If there is another one I should be looking at under $100 please let me know
Re: Vaccum Oil Extractor [Re: ad244] #5243260 10/18/19 10:56 AM
double vanos Offline
Well, I use a Griots garage one but now there many on the market that just as well as my GG.
Here’s one at harbor freight: https://www.harborfreight.com/23-gal-manual-fluid-extractor-62643.html?_br_psugg_q=oil+sucker
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Vaccum Oil Extractor [Re: ad244] #5243265 10/18/19 10:58 AM
Re: Vaccum Oil Extractor [Re: ad244] #5243268 10/18/19 10:59 AM
G
Gimpy1 Offline
G
I got the OEM tools 5.3 L extractor, and it works great. I like that the pump mechanism is metal and comes with multiple hoses for a variety of openings. I also got the brake bleeding hose so It I can do my brakes, trans, and normal oil changes. I've had mine for about 2 years and its still working great.
Re: Vaccum Oil Extractor [Re: double vanos] #5243269 10/18/19 10:59 AM
A
ad244 Offline OP
A
Wow that one looks pretty good but its on the upper end of the price range. Its worked well for you over an extended time period?
I was looking at the Mitey Vac one as well.
https://www.amazon.com/gp/product/B...;linkId=eac6239eb9ebcbc1c1085f0de8b35d7f
Re: Vaccum Oil Extractor [Re: ad244] #5243274 10/18/19 11:02 AM
Squirrelee Offline
An idea or two if you already have a large shopvac:
The initial idea:
https://www.youtube.com/watch?v=eJK92UFEIu4
The initial idea modified for a larger catch container:
https://www.youtube.com/watch?v=Uk46vCOGTFI
Some guy's dog thinks I'm a good man.
Re: Vaccum Oil Extractor [Re: ad244] #5243360 10/18/19 12:21 PM
B
benjy Offline
B
most extractors DON'T fully drain your pan!!! i conventionally drain it HOT + jack accordingly to get the drain at the lowest point.
Re: Vaccum Oil Extractor [Re: ad244] #5243403 10/18/19 01:03 PM
B
BMWTurboDzl Offline
B
I used to use the Topsider for my 335d. Disadvantage is that you can't see how much has been pulled, the container itself won't crack/collapse and you can store it on a shelf.
link
435i
Re: Vaccum Oil Extractor [Re: benjy] #5243408 10/18/19 01:06 PM
B
BMWTurboDzl Offline
B
Nonsense. It depends on whether or not the dipstick tube is placed over the deepest section of the oil pan.
435i
Re: Vaccum Oil Extractor [Re: benjy] #5243450 10/18/19 01:52 PM
A
ad244 Offline OP
A
I dunno, mercedes says to use one despite having a sump drain
Re: Vaccum Oil Extractor [Re: benjy] #5243467 10/18/19 02:06 PM
2
2004tdigls Offline
2
Simply not true, you should go over to the TDI club web site (I am a member there too). various members have measured the oil removed by both methods and tdi engines give up more oil with an extractor
this is because almost half a liter oil sits up in the oil filter housing and can only be removed by an extractor
https://www.youtube.com/watch?v=RN93fWHL6zU
Re: Vaccum Oil Extractor [Re: ad244] #5243516 10/18/19 03:03 PM
A
atikovi Online Content
Online Content
A
Mity-Vac or you will replace the cheaper brands in a year or two.
Re: Vaccum Oil Extractor [Re: ad244] #5243530 10/18/19 03:19 PM
L
Lolvoguy Online Shocked
Online Shocked
L
Only do this if you plan on throwing your time and money away.
I purchased the one below from Marine West several years ago.
Been working great for everything from PS fluid, ATF, and engine oil.
Don't let capacity be a limiting factor. On vehicles with a larger sump, merely disconnect before it gets full and empty it before completing the drain process.
That's what I do on the Lexus as my sump is over 6 liters, but the pump only holds 5.5ish or so.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Vaccum Oil Extractor [Re: atikovi] #5243540 10/18/19 03:34 PM
P
Pelican Offline
P
Exactly !
Re: Vaccum Oil Extractor [Re: ad244] #5243543 10/18/19 03:37 PM
rooflessVW Offline
I have A Mityvac 7300. Uses shop air for the pump and has an 8.8 liter capacity.
"Zed's dead baby, Zed's dead."
