I have a broken rear coil spring in the Escalade. They don't make the spring the goes with that truck anymore so I'm forced to install an alternate.
The old progressive springs seems to be the same on both sides.
The new progressive OEM springs (made for 02-06 tahoes, suburbans) appears to be tighter wound on one side vs the other.
Is there a top and bottom? Does it matter?
