I was curious about the max boost pressure on my vehicle. Found it went to 14+psi. The curious thing is that would be approximately 250 engine HP. And yet at 0 psi turbo the vehicle is maybe 50+ mph on a level road. I think the gauge is likely accurate...bc when windmillint (coasting) the gauge is at -11 psi.
Here is the question... I am speculating that the engine is producing no more than 60 or so HP at that speed (50+ mph). Yet that "should" be half load (125 HP) one would "logically" assume that the engine is not very efficient at 6000 rpm. But that can't be true since at half the theoretical load (0 psi) the engine is actually pulling much less---60HP. The only conclusion is that turbo is very efficient. But its not possible it can be 'that" efficient. I'll think about it later since right now I have stuff to do.
Thoughts?
Thoughts?
