STP mulit purpose motor treatment + fuel stabalizer
by Chris142 - 11/14/19 08:08 AM
"Universal" electric coolant circulation pump
by Superflan - 11/14/19 07:32 AM
Thermostat question
by nicholas - 11/14/19 07:13 AM
why michelin changed their tire lineup?
by edwardh1 - 11/14/19 07:12 AM
how do you mark your name on key fob?
by edwardh1 - 11/14/19 07:08 AM
"New EV Battery Can Charge in 10 Minutes..."
by wemay - 11/14/19 05:52 AM
TDS review
by Espada - 11/14/19 03:30 AM
SD40 Guide Rod ?'s
by GumbyJarvis - 11/14/19 01:08 AM
How many steps a day are you getting?
by P10crew - 11/14/19 12:45 AM
Pics - Top Piston Cleaning - Lexus CT200h
by KerryB - 11/14/19 12:14 AM
Valvoline Full Synthetic Maxlife 10w30
by KerryB - 11/13/19 11:38 PM
Toyota 1MZ-FE burning lots of oil
by Speedinsweede - 11/13/19 11:27 PM
Castrol Magnatec
by dosmom - 11/13/19 10:51 PM
How do you feel about buying tires with different DOT's?
by Speedinsweede - 11/13/19 10:23 PM
Toys for the Caprice
by ls1mike - 11/13/19 09:08 PM
7.62x39 AR anyone?
by sw99 - 11/13/19 09:07 PM
Chrysler EcoDiesel Class Action Suit
by JeffKeryk - 11/13/19 07:45 PM
2015 Mazda 6 Auto-RX rinse Castrol EDGE 0W20
by bulwnkl - 11/13/19 07:45 PM
Where's Trav 2.0?
by user52165 - 11/13/19 07:20 PM
Siphoning Fuel
by Spetz - 11/13/19 06:34 PM
PaulDouglas, DanF350man, Jasonoff, Speedinsweede, JeffS
69856 Registered Users
86 registered members (Andrei, alarmguy, 64bawagon, 1978elcamino, 4WD, 53' Stude, 8 invisible), 2,009 guests, and 17 spiders.
Topics297,389
Posts5,114,522
Members69,856
Most Online3,589
Nov 2nd, 2019
3.2 V6 Cayenne oil help #5242891 10/18/19 03:16 AM
A
Abax25 Offline OP
A
2007 cayenne 3.2, I had it serviced when under warranty at the dealer and at random places since. Always full synthetic, Changed at 5-6k intervals, but who knows which weights were used. I think it calls for either a 0w-40 or 5w-30.
Little under 200k miles, and still running great. Peeking in the fill hole, it’s dark and gunky looking. I own various other vehicles that I’ve had since new with higher miles. None appear this nasty, one still looks new.
Anyways, looking to change my oil own from now on to keep this thing on the road for as long as possible. I still love it.
Known to have timing chain issues, so not sure a certain weight oil would even help with this?
Mobil 1 suggests 5w-30 ESP. Not much info online, but VW people like to use rotella t6. Unsure how different the motors are, but a 15w-40 diesel oil seems too heavy?
Re: 3.2 V6 Cayenne oil help [Re: Abax25] #5242917 10/18/19 04:32 AM
rooflessVW Online Content
Online Content
Mobil 1 FS 0W-40
"Zed's dead baby, Zed's dead."
Re: 3.2 V6 Cayenne oil help [Re: Abax25] #5242961 10/18/19 05:45 AM
danez_yoda Offline
take a look with a borescope (cheap from amazon) and see how bad it it. At 12 years and 200K miles i would be very hesitant to change anything to clean the gunk. You start adding solvents and additives to clean the gunk and it very well might spring a leak or worse break off a big chunk that clogs up an already partially clogged oil port.
Gunk could be coolant as well. you will want to keep an eye on coolent loss and maybe a UOA looking for coolent in the oil. You are correct, synthetic should not gunk up like that.
PCV as well.
Its not going to last forever but I've seen some slow declines where they consume oil, sputter spit but still go for ever. If you never plan on getting rid of the truck eventially you will see its last day. Of course the last day is only defined by when you stop putting money into it. smile Of course in theory you could over the years replace everything except the frame and make it last forever if you want. << insert Scotty Kilmer laugh >>
Re: 3.2 V6 Cayenne oil help [Re: Abax25] #5243041 10/18/19 07:06 AM
K
kschachn Offline
K
Your manual may recommend a grade but it requires an approval. Whatever that is (A40?) the grade is largely irrelevant. Do not focus on grade, focus on the approval.
1994 BMW 530i, 250K
1996 Honda Accord, 280K
1999 Toyota Sienna, 425K
2000 Toyota ECHO, 284K
Re: 3.2 V6 Cayenne oil help [Re: kschachn] #5243134 10/18/19 08:35 AM
P
paoester Offline
P
For an older Porsche, you could use about anything that says Porsche A40 on it. Walmart has those. For some unknown reason, Porsche originally said to use Porsche C30 or VW 504 oil which is lower saps for low sulphur fuel, which was rare in N. America 10 years ago but now is a common enough, so Porsche C30 is also of course fine (example Mobil1 ESP 0w30 or 5w30) now in 2019 with low sulphur fuel common.
Really any name synthetic brand oil with HTHS between 3.3 and 4.0 would work well in an older Porsche.
It is a good time to use what The_Critic used recently. It cleans out all the carbon junk on the pistons in an older engine using POE and AN with Premium Blue detergents, great cleaner:
https://www.bobistheoilguy.com/forums/ubbthreads.php/ubb/printthread/Board/1/main/316395/type/thread
Of course that is drastic and maybe too much for your needs, so you could just do a couple of short 3,000 mile oil changes on walmart 0w-40 (castrol or mobil1 varieties).
15w-40 is not too heavy for that engine. Rotella T6 isn't a bad idea either. Both have HTHS in the 3.3 to 4.0 range for you.
2019 VW Tiguan S 4Motion, Pennzoil Platinum 0w-20, VW Mann oil filter
Re: 3.2 V6 Cayenne oil help [Re: Abax25] #5243141 10/18/19 08:40 AM
A
Audios Offline
A
These motors do great on almost anything, 0/40-15/40. SHorter runs with the 15.40 will help clean it all out, usually the HD oils have extra detergents.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: 3.2 V6 Cayenne oil help [Re: Abax25] #5243144 10/18/19 08:44 AM
K
kschachn Offline
K
1994 BMW 530i, 250K
Re: 3.2 V6 Cayenne oil help [Re: Abax25] #5243150 10/18/19 08:50 AM
P
paoester Offline
P
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5228520/1
If you do the Valvoline special oil, its a good idea to change the oil filter at the first 1,000 miles into it. Just the filter at that point.
Re: 3.2 V6 Cayenne oil help [Re: Abax25] #5243203 10/18/19 09:49 AM
Z
Zolton Offline
Z
VR6 is tough on oil, but not picky.
If climate allows, just use HD oil like Rotella or Delo, a 10w-30 maybe mixed with 15w-40. Change it out frequently until you need a winter oil, then use a 5w-40 HD. 0w-40 or spec oil is pointless in this engine except maybe extended drains. Porsche A40 and VW 502 are the same, JUNK that you pay extra for the junkie approval.
With the weak sealing systems of the VR6, I would also consider a good 10w-40 hi miles, like Maxlife, which quiets the lifters nicely.
Re: 3.2 V6 Cayenne oil help [Re: Zolton] #5243411 10/18/19 01:08 PM
A
Abax25 Offline OP
A
Upon further inspection, it’s not “terrible” But far from a clean cylinder head.
Rotella t6 has changed so many times over the years, it’s hard to keep up with it. Good to see it’s still being recommended.
I will go the 5w-40 T6 route, and lower my intervals to 4500-5500
Thanks guys
Re: 3.2 V6 Cayenne oil help [Re: rooflessVW] #5243415 10/18/19 01:12 PM
J
JC1 Offline
J
Originally Posted by rooflessVW
Mobil 1 FS 0W-40
+1
2015 Grand Caravan SXT Plus 5w-20 Eco-Power/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: 3.2 V6 Cayenne oil help [Re: Zolton] #5243493 10/18/19 02:42 PM
Online Content
LOL
Mobil 1 FS 0W-40 is $5 a quart all day, every day - same as Rotella T6.
OP, I'd be very surprised if your engine was anything but spotless inside, especially if it has been serviced as you say.
Re: 3.2 V6 Cayenne oil help [Re: Abax25] #5243795 10/18/19 10:43 PM
Z
Zolton Offline
Z
Rotella 10w-30 is about the same as 5w-40 in the cold anyway, so no real need for a "synth" oil in these Euro non-turbo engines, not even DI ones.
HT/HS of 3.5cP and good additives is all you need, HD 10w-30 weight has it for $10/g.
Re: 3.2 V6 Cayenne oil help [Re: rooflessVW] #5243800 10/18/19 10:54 PM
Z
Zolton Offline
Z
LOL
lol, do you really think with Mobil 1 you're not paying for the label? Wow, ok.
[Linked Image from i.imgur.com]
Re: 3.2 V6 Cayenne oil help [Re: Abax25] #5243863 10/19/19 04:37 AM
Online Content
You're a fool to think that an HDEO 10W-30 and a properly formulated oil with European approvals are even in the same league.
M1 FS 0W-40 is an approved lubricant for his engine and has been used in every Porsche (including their race cars) for 10+ years.
HDEO 10W-30 is for agricultural equipment.
