Fleet oil intervals to save money?
by Todd00000 - 11/14/19 08:44 AM
Motive power brake bleeder
by Redright9 - 11/14/19 08:25 AM
*GRAPHENE* a new oil-additive????
by cadchris - 11/14/19 08:21 AM
STP mulit purpose motor treatment + fuel stabalizer
by Chris142 - 11/14/19 08:08 AM
"Universal" electric coolant circulation pump
by Superflan - 11/14/19 07:32 AM
Thermostat question
by nicholas - 11/14/19 07:13 AM
why michelin changed their tire lineup?
by edwardh1 - 11/14/19 07:12 AM
how do you mark your name on key fob?
by edwardh1 - 11/14/19 07:08 AM
"New EV Battery Can Charge in 10 Minutes..."
by wemay - 11/14/19 05:52 AM
TDS review
by Espada - 11/14/19 03:30 AM
SD40 Guide Rod ?'s
by GumbyJarvis - 11/14/19 01:08 AM
How many steps a day are you getting?
by P10crew - 11/14/19 12:45 AM
Pics - Top Piston Cleaning - Lexus CT200h
by KerryB - 11/14/19 12:14 AM
Valvoline Full Synthetic Maxlife 10w30
by KerryB - 11/13/19 11:38 PM
Toyota 1MZ-FE burning lots of oil
by Speedinsweede - 11/13/19 11:27 PM
Castrol Magnatec
by dosmom - 11/13/19 10:51 PM
How do you feel about buying tires with different DOT's?
by Speedinsweede - 11/13/19 10:23 PM
Toys for the Caprice
by ls1mike - 11/13/19 09:08 PM
7.62x39 AR anyone?
by sw99 - 11/13/19 09:07 PM
PaulDouglas, DanF350man, Jasonoff, Speedinsweede, JeffS
69856 Registered Users
107 registered members (14Accent, 4WD, 2015_PSD, 53' Stude, 1978elcamino, 10ecfarmer, 5 invisible), 2,206 guests, and 20 spiders.
Topics297,394
Posts5,114,575
Members69,856
Most Online3,589
Nov 2nd, 2019
Mobil1 5W-30, 8,200mi, 2017 Expl 2.3EBBB #5242633 10/17/19 06:01 PM
W
Whimsey Offline OP
W
This is the fourth UOA I've done with our Explorer. This one was from May 1 till Sept 26 for a total of 8,200 miles. This was mainly everyday commuting with some "local" vacation driving. Before this OC I had a timing cover leak "repaired" under warranty, it's leaking again less than 10,000 miles after the "repair". Any way I ran the dealer new oil from the repair for 1,300 miles and then changed it myself to this oil in the UOA. At the same time I put in a new Motorcraft air filter. I'm pleased with the wear metals but a bit surprised with the insoluble level of 0.4. This is the highest I've ever had in any UOA's. The oil filter was a new Mobil 1 oil filter. Considering this is a small turbo DI engine in a heavy vehicle I think it's performing well. Even using regular gasoline it has plenty of "pep", more than our 2005 4.6 V-8 Explorer. And the mpg is almost twice as much as the V-8 Explorer. Yes, using premium fuel will give you a bit more "zip" and an extra mpg but at $0.60/gallon extra for premium fuel it's not worth it for us. Comments are welcome grin2.
Whimsey [Linked Image]
Re: Mobil1 5W-30, 8,200mi, 2017 Expl 2.3EBBB [Re: Whimsey] #5242701 10/17/19 07:22 PM
G
geeman789 Offline
G
Under the ... "not sure it really matters ... " category.
The M1 5w30 has thinned out a fair bit. It starts at 11.0 cSt, and is down to 9.1. This seems fairly common in many Resource Conserving oils ...
Maybe try a NON - resource conserving 5w30 next time, typically a Euro oil, or maybe a 40 grade, like M1 0w40 FS.
Or don't worry about it ... UOA seems decent.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Mobil1 5W-30, 8,200mi, 2017 Expl 2.3EBBB [Re: Whimsey] #5242914 10/18/19 04:29 AM
dnewton3 Offline
Global Moderator
Global Moderator
You're averaging 2.3ppm of Fe / 1k miles. That ain't bad at all! The other wear metals are so low it's just moot. Your longest OCI gave the lowest wear rate (typical of just about all engines as a generalization).
Don't worry too much about the insolubles count; it's fine. It's a visual reference test anyway; there's a tiny bit of subjectivity to it.
I would say running that lube out to 10k miles (or beyond) is no worry whatsoever.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Mobil1 5W-30, 8,200mi, 2017 Expl 2.3EBBB [Re: Whimsey] #5243651 10/18/19 06:37 PM
M
Mad_Hatter Offline
M
There's nothing in this report to set your hair on fire about; it's actually a great report. You ran the lube 8k miles and it's baaarely out of grade by the slimmest of margins but if your OM allows for a Xw20 it's a non starter IMO. TBN and FP are fine, no additive depletion and as was pointed out the Fe isn't anything to get worked up about after an 8k mile run.
Nice report!👍
Re: Mobil1 5W-30, 8,200mi, 2017 Expl 2.3EBBB [Re: Whimsey] #5246193 10/21/19 02:57 PM
N
nlife Offline
N
Glad to see that M1 5w30 is working in your Explorer. I'm running the same in my 3.5L EcoBoost, but haven't done any OAs on it.
Neil
Re: Mobil1 5W-30, 8,200mi, 2017 Expl 2.3EBBB [Re: geeman789] #5249677 10/25/19 08:42 AM
B
badtlc Offline
B
It wasn't the oil that thinned, it was the presence of fuel. All oils will have the same result in this engine unless premium is used.
2007 Ford Escape XLS 2.3L ATX, M1 AFE 0W20, Fram TG, 167k
2015 Chrysler T&C, 95k+, M1 5W30, Wix OF
2018 Forester Premium 10k+, M1 5W30, EcoGard Syn OF, ST 75W90
Re: Mobil1 5W-30, 8,200mi, 2017 Expl 2.3EBBB [Re: badtlc] #5249699 10/25/19 09:29 AM
J
jbutch Online Content
Online Content
J
In my experience it's both, but the non-rc oils stayed in grade better than their counterpart resulting in less wear metals in UOAs.
2015 Forester XT @ 100k km
Current fill: Rotella T6 Multi Vehicle 5w-30 with Fram Ultra XG7317
Re: Mobil1 5W-30, 8,200mi, 2017 Expl 2.3EBBB [Re: Whimsey] #5249702 10/25/19 09:38 AM
B
buster Offline
B
Nice results.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
