Old Vise info
by A310 - 11/16/19 10:18 PM
2003 Ranger Radiator Replacement: Which Coolant?
by chucky2 - 11/16/19 08:55 PM
ATV axle removal
by supton - 11/16/19 07:45 PM
High speed chase
by P10crew - 11/16/19 07:28 PM
Oil for Daily Beater Camry
by Speak2Mountain - 11/16/19 07:18 PM
Green coolant, future availability ?
by rubberchicken - 11/16/19 06:11 PM
Weird tire wear
by ledslinger - 11/16/19 04:50 PM
Why does Ford resell lemons?
by avacado11 - 11/16/19 04:07 PM
Slow initial response to loading web pages
by JHZR2 - 11/16/19 04:06 PM
Motorcraft FL-910S
by PW01 - 11/16/19 03:54 PM
Walmart ammo clearance
by redbone3 - 11/16/19 03:35 PM
GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
Weird fuel leak
by BeerCan - 11/16/19 01:02 PM
Sinopec 75w-90 Synthetic
by jdw1222 - 11/16/19 12:51 PM
Honda Oil Filter
by miden851 - 11/16/19 12:28 PM
VOA for QSAD 10w-40?
by natas - 11/16/19 12:02 PM
billad67, aka_Claus, Diverdown, natas, matt3540
69886 Registered Users
71 registered members (2015_PSD, Anthony, 69GTX, 77GrandPrix, 92saturnsl2, 4 invisible), 1,533 guests, and 23 spiders.
Topics297,521
Posts5,117,341
Members69,886
Most Online3,589
Nov 2nd, 2019
Another HONDA ATF thread :) #5242358 10/17/19 11:58 AM
M
maverickfhs Offline OP
M
So I have quite a few of these sealed ATF quarts laying around, attached picture.
In the past have always used Honda OEM ATF/ DW1.
Is that safe to use in a 2006 Honda Civic or 2007 Honda Accord, for drain and refill purposes?
Thanks for the help.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Another HONDA ATF thread :) [Re: maverickfhs] #5242361 10/17/19 12:02 PM
SubieRubyRoo Offline
Umm, no. Either recycle it or give it to someone who has an old Dexron trans.
Re: Another HONDA ATF thread :) [Re: maverickfhs] #5242369 10/17/19 12:09 PM
Chris Meutsch Offline
No way.
2005 Honda CR-V EX, 278k
Re: Another HONDA ATF thread :) [Re: SubieRubyRoo] #5242376 10/17/19 12:14 PM
J
jeepman3071 Offline
J
+1
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (52k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Another HONDA ATF thread :) [Re: maverickfhs] #5242378 10/17/19 12:18 PM
N
NoNameJoe Offline
N
[censored] no, Hondas are already finicky about the ATF they use, this looks like offbrand garbage made in 2017 that is suitable for old outdated specs, none of those specs pertain to Honda either.
I can't imagine anyone would seriously consider using these. Even if you saved a few dollars, is it worth it?
2015 Civic LX Coupe
Re: Another HONDA ATF thread :) [Re: maverickfhs] #5242390 10/17/19 12:25 PM
dippschtick Offline
I have a new unopened quart of DW1 I no longer need. Got it from Amazon, set up a return, refunded me my money, and told me to keep it.
OP, PM me your address and I'll send it to you.
Re: Another HONDA ATF thread :) [Re: maverickfhs] #5242393 10/17/19 12:27 PM
J
JeffKeryk Offline
J
I wouldn't.
It only takes 3 quarts to service most Honda transmissions.
Use the correct fluid.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Another HONDA ATF thread :) [Re: maverickfhs] #5242400 10/17/19 12:29 PM
M
M
Thanks everyone, decision made, to ignore this fluid and continue with DW1 smile
Re: Another HONDA ATF thread :) [Re: maverickfhs] #5242545 10/17/19 04:13 PM
N
nthach Offline
N
For a Honda of that era, you can use Dex/Merc fluid if you can't find Z-1/DW-1 "in an emergency" but stick to OEM or a high-viscosity "universal" fluid like Castrol IMV.
That stuff might look like off-brand stuff but I'd bet it's a Warren Performance Products or Warren Oil product. Check on the bottom of the bottle for a WPP stamp. I'd give it away to someone with an older car that uses Dexron/Mercon fluid.
Re: Another HONDA ATF thread :) [Re: maverickfhs] #5242577 10/17/19 05:00 PM
K
Kira Offline
K
You can also give it to a local transmission shop or even a local mechanic. They'll know to install it into a older vehicle.
I had 2 unopened gallons of the same spec fluid. Mine was a Valvoline product in a blue jug.
It was slated to go into my '99 Saab but I sold it rather unexpectedly.
AutoZone still had it in their computer so a refund as store credit (I had no receipt) was A-OK with me.
Re: Another HONDA ATF thread :) [Re: maverickfhs] #5242644 10/17/19 06:13 PM
slacktide_bitog Online Content
Online Content
That looks like one of those shady brands from PQIA hide
That being said, you don't have to use OEM DW1 from the dealer. You can use Maxlife or Castrol Full Synthetic with no problem smile
Re: Another HONDA ATF thread :) [Re: maverickfhs] #5242836 10/17/19 10:29 PM
A
AC1DD Offline
A
Unless I knew this came from a reputable oil producer I wouldn't use it in anything except a beater I was going to get rid of in a few months!
As far as using Dexron II or III spec fluids the last time that was "safe" was probably the early 90s in Honda automatics at the latest mid 90s.
Re: Another HONDA ATF thread :) [Re: maverickfhs] #5243401 10/18/19 01:01 PM
MolaKule Offline
Global Moderator
Global Moderator
if it specs DW-1 and before making a decision I would seriously look at the differences in chemistry between DW-1 and Valvoline MaxLife ATF:
Quote
Original Honda DW-1™ (Part # beginning with 08200-):
Boron - 272
Silicon - 4
Sodium - 3
Calcium - 353
Magnesium - 204
Phosphorus - 2
Zinc – 320
[email protected] – 6.93 cSt
Commentary and Opinion: The chemical signature for this ATF is essentially the same as Honda’s Z-1 fluid and is indicative of fluids used in Automated Manual transmissions. To the author’s knowledge, no Step-Shift ATF chemical signature compares. Notable is the level of the Zinc compounds needed for the internals of Automated Manual transmissions.
Owners’ of Step-Shift automatic transmissions should avoid using this product in any Step-Shift automatic transmission.
Label - Valvoline MaxLife™ (Part # beginning with 773):
Boron - 272
Silicon - 2
Sodium - 8
Calcium - 230
Magnesium - 3
Phosphorus - 579
Zinc – 3
[email protected] – 5.91 cSt
Commentary and Opinion: The chemical signature for this ATF is indicative of the later Dexron and Dex/Merc series of ATF’s based on the original Dexron through the Dexron III(H)) and Dexron VI series of ATF’s. It is closely comparative to the GM Dexron VI formulations as well as to their own Dexron VI offering, and can be classified as a low Viscosity ATF. What is notable is a boost in the Ant-Wear Phosphorus compound of about 200 ppm.
The manufacturer claims coverage, or “Suitable for Use in” (no equivalency claims) for Honda/Acura’s Z-1 and DW-1. I do not see how this could be the case when compared to the DW-1 analysis above.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5169998/three-atfs-analyzed#Post5169998
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: Another HONDA ATF thread :) [Re: maverickfhs] #5243640 10/18/19 06:22 PM
A
AC1DD Offline
A
@Molakule
Do you have the analysis from Castrol Import Multi-Vehicle ATF? (non-synthetic) How does it compare to DW-1 ?
Castrol states suitable for use in applications using Honda Z-1 and DW-1 too.
Re: Another HONDA ATF thread :) [Re: AC1DD] #5243654 10/18/19 06:42 PM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by AC1DD
@Molakule
The Castrol Import Multi-vehicle ATf's additive signature is very close to the Idemitsu H-Plus
Boron - 40
Silicon - 2
Sodium - 3
Calcium - 260
Magnesium - 2
Phosphorus - 255
Zinc – 3
[email protected] – 6.5 cSt
I would say there is still no comparison to the DW-1 additive signature because if you examine the Zinc-to-Phosphorus ratios you will see the major difference.
Charlie Eppes:
